Need Help With 12 Volt Water System...
05-12-2006, 07:02
I also had my outside switch go bad. Don't know why it went bad- just 23
years old. I was forrever hunting down that probleem. Erniie-83pt40 in Texas
05-12-2006, 09:26
My water pump runs and pumps water, but very slowly. I could not find
any leaks or lose connections. It seems like the pump does not prime
it's self for some reason. The pump will run constantly.
I'm digging into it now. Does anyone have any advice to offer?
Thanks in advance.
James
78FC33SB
Kingman AZ (But not for long)
05-12-2006, 09:39
A couple thoughts. Does your Bird have the 12v water tank fill switch
that controls a Sporlan valve...that switch might be set to 'fill' and
should be set to 'off'...or the Sporlan valve is filled with junk and
needs to be cleaned out.
> Thanks in advance.
> James
> 78FC33SB
> YAHOO! GROUPS LINKS
05-12-2006, 09:54
Thanks for the reply, Curt.
I don't think it's a switch as it has worked properly for a long
time and I have not thrown any switches or turned any valves.
What I have discovered is that when I run the pump water begins to
exit out ot the water tank over flow.
I do not know what a Sporland valve is, however something being
fouled by junk is a possibility.
Could you expand on your thoughts for me so I can look for that
valve?
Thanks.
James
78FC33SB
Kingman AZ
switch
not find
prime
> > Thanks in advance.
> > James
> > 78FC33SB
> > YAHOO! GROUPS LINKS
web.
> > subject=Unsubscribe>
of
05-12-2006, 10:08
James,
A Sporlan valve is a 12V flow control valve. From what you have said I
don't believe you have that valve in your coach.
Let me think about what you have said. If I come up with something more
I'll get back to you. Good luck! Enjoy your trip East.
> valve?
> Thanks.
> James
> 78FC33SB
> Kingman AZ
05-12-2006, 10:12
Here's another thing...
When I put city water into the commercial intake, water immediately
starts to run out of the water tank overflow. I may be wrong but
the over flow appears to come out of the hot water tank. Does that
make any sense?
James
78FC33SB
Kingman AZ
--- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions"
> valve?
> Thanks.
> James
> 78FC33SB
> Kingman AZ
> switch
to 'fill'
> and
junk
> and
> not find
not
> prime
> > > Thanks in advance.
> > > James
> > > 78FC33SB
> > > YAHOO! GROUPS LINKS
> web.
Terms
> of
05-12-2006, 10:44
James,
There is a pressure relief valve on the hot water heater overflow.
Maybe it popped open and didn't seat itself. I think you should be
able to tap the stem of the overflow valve and see if that makes a
difference. The valve is mounted directly to the heater and the
overflow pipe is attached to it.
David Hollis Springfield,IL NO Bird
immediately
that
> make any sense?
> James
> 78FC33SB
> Kingman AZ
to
> > valve?
> > Thanks.
> > James
> > 78FC33SB
> > Kingman AZ
> > switch
> to 'fill'
> > and
> junk
> > and
could
> > not find
> not
> > prime
offer?
> > > > Thanks in advance.
> > > > James
> > > > 78FC33SB
> > > > YAHOO! GROUPS LINKS
> > web.
> Terms
> > of
05-12-2006, 11:02
James,
If you need it, look in the "Files" for the Sporlan Valve document
that gives diagrams, parts numbers and instructions on repairing them.
1991 WB40 "Texas Minivan"
> valve?
> Thanks.
> James
> 78FC33SB
> Kingman AZ
> switch
> and
> and
> not find
> prime
> > > Thanks in advance.
> > > James
> > > 78FC33SB
> > > YAHOO! GROUPS LINKS
> web.
> of
05-12-2006, 11:07
Hello, Dave!
I found the pressure relief valve. There is what looks to be a plug
coming out of the end of it. I rapped lightly on it with a bearing
hammer but no luck so far. Is the valve internal, or would I see
the end (plug looking thing) retract if it seats?
The bus is running great. I have more fun driving in this 'Bird
than I would in a Ferrari. Honestly. Drove 163W this morning in 95
degree heat, went up some major uprgrades, and the old 'Bird never
flinched, stayed nice and cool and ran strong all day.
Thanks again for selling me such a nice Wanderlodge. Practically
everyone that sees it stops and stares as if they were looking at a
space ship from Mars!
Oh well, back to do some more plumbing work.
James
78FC33SB
Kingman AZ
> James,
overflow.
be
> immediately
but
> that
> > make any sense?
> > James
> > 78FC33SB
> > Kingman AZ
long
begins
> to
being
that
> > > valve?
> > > Thanks.
> > > James
> > > 78FC33SB
> > > Kingman AZ
fill
> > > switch
> > to 'fill'
> > > and
> > junk
> > > and
> could
> > > not find
does
> > not
> > > prime
> offer?
> > > > > Thanks in advance.
> > > > > James
> > > > > 78FC33SB
> > > > > YAHOO! GROUPS LINKS
> the
> > > web.
> > Terms
> > > of
05-12-2006, 11:10
Sounds like a fill valve like Curt said and sounds like the water is
comming out of the overflow for the fresh water tank. If your
hotwater drain is open, the drain will run when you turn the 12V pump
on. The 12v Pump wont push water out of the tank overflow because it
takes and replaces it.
The water is drawn from the fresh tank by the pump, then the pump
pushes the water in the plumbing pipes to pressurise the system. The
Freshwater storage tank (FWST)is a appliance connected to the
presurized system. If the fill valve is open the FWST will be trying
to fill up but it is using the water it takes from the tank. This
Recycling will not allow pressure to build so other appliances like
sinks will only show a trickle. You may see other Motorhomes have a
tank fill port for the fresh water and another one for city water
port. MY BB has one hookup for citywater and I must flip a electric
switch to open the valve on the FWST appliance when I want to fill
the tank.
coming out of the overflow for the fresh water tank. If your
on.
pushes the water in the plumbing pipes to pressurize the system. The
pressurized system. If the fill valve is open the FWST will be
trying to fill up but it is using the water it takes from the tank.
This Recycling will not allow pressure to build so other appliances
like sinks will only show a trickle. You may see other Motorhomes
have a tank fill port for the fresh water and another one for city
water port. MY BB has one hookup for citywater and I must flip an
electric switch to open the valve on the FWST appliance when I want
to fill the tank.
If it is a FillValve. the Sporlan Valve in my 94 is under the bed
which is behind the fill port. The valve is a diaphragm type and
requires water pressure to close it off (much like a sprinkler
valve). When the bus sits without a city hookup and/or pump pressure,
the valve floats open and debris or calcium builds up on the
diaphragm this will not allow it to seat and close. The valves are
called "normal closed" but it is not passive. You need a charged
solenoid to open it up (toggle fill switch). The valve may differ on
your coach
When this happened to me I hooked up to city water and flipped the
fill switch several times while the tank was filling. It worked but
later JM cautioned me of waterhammer damage from a quick close. In
the future if I need to flip flip the switch under pressure, I will
open a sink valve in the coach
94pt40 Romoland CA
> make any sense?
> James
> 78FC33SB
> Kingman AZ
to
> > valve?
> > Thanks.
> > James
> > 78FC33SB
> > Kingman AZ
> > switch
> to 'fill'
> > and
> junk
> > and
> > not find
> not
> > prime
offer?
> > > > Thanks in advance.
> > > > James
> > > > 78FC33SB
> > > > YAHOO! GROUPS LINKS
> > web.
> Terms
> > of
