Reworked Alternator Tag
05-11-2006, 16:43
While fixing the problem I had with my cooling fan I decided to change
all the belts and since I was pulling all the belts I might as well
pull the alternator and have it gone thru. It is a Leece-Neville and it
has a label stuck over the data plate. It says "Reworked Alternator BB
no.08258 Standard Alternator Will Not Work Properly" Anyone know what
BlueBird reworked on their alternators? Also what is the normal life
span of the water pump on a 3208,it wouldn't take much to change it
now,The mileage on the coach is 71,000 and it looks like the cooling
system was well maintained.
Jim Matus 1984FC35SB Rescue CA
05-11-2006, 21:35
the little oil cooler hoses were the ones that started leaking on my FC. You
have to have a good swing radiator to get to those- or a body of a teenager.
Ernie-83pt40 in Texas
05-12-2006, 00:24
Miller knows what's up with the LN alternator. Do the water pump and change out
the oil cooler hoses. Don't forget to take your arrangement numbers to the Cat
parts house.
Mike Hohnstein
Germantown, WI
83FC35
Sent: Thursday, May 11, 2006 11:43 PM
Subject: [WanderlodgeForum] Reworked Alternator Tag
SPONSORED LINKS Recreational vehicles Recreational vehicle financing
Recreational vehicle repair
Recreational vehicle rental Recreational vehicle camper Recreational
vehicle rate
YAHOO! GROUPS LINKS
05-12-2006, 07:52
On the standard alternator, BlueBird removed the tab between the
voltage regulator terminal and the positive terminal. This is an
external strip/tab, the one on the negative side stays.
This allows the alternator to sense voltage remotely and charge the
batteries at a more accurate charging voltage when there is a heavy
load.
If you install an alternator with this tab NOT removed, turning off the
master 12v switch will cause the coach electrical systems to be powered
through this tab and a small (16AWG?) wire, will burn up the wire if
there is any significant load.
- Jeff Miller
in Holland, MI
--- In WanderlodgeForum@yahoogroups.com, "jim matus"
change
it
BB
05-12-2006, 09:02
Jeff,
I had the Motorola alternator rebuilt before our winter trip.
The master disconnect kill switch was in the "ON" position for over
three months. Upon returning home, I began to again use the master
disconnect switch. When switching to the "Off" position, there is
now a voltage leak in the system, some on the relays will chatter.
Especially the air step relays and the dash/ step/ open light will
flicker. It seems to be a less than 12 volt leakage.
To get a positive shut down, I now turn on a small load like a
heater fan, then switch the master disconnect to the "OFF" position.
Could this tab be my problem??
Is this tab on the Motorola??
Could the alternator rebuild shop have hooked up this tab??
Thanks,
Bill 88 FC Michigan
heavy
> load.
off the
powered
if
> - Jeff Miller
> in Holland, MI
> change
well
> it
Alternator
> BB
what
life
it
cooling
05-12-2006, 15:25
Not on the Motorola, I'm not aware of any '87-up coaches having this
arrangement but ??
I'd have to look at my '88 schematics to come up with a theory on
that one, not tonight I'm afraid.
- Jeff Miller
in Holland, MI
> Jeff,
over
> Thanks,
> Bill 88 FC Michigan
> the
> heavy
> > load.
> off the
> powered
> if
> > - Jeff Miller
> > in Holland, MI
> > change
> well
Neville
> and
> > it
> Alternator
> > BB
know
> what
> life
change
> it
> cooling
05-12-2006, 23:01
Jeff,
Are all the Leece NeVilles built with that little tab?
Thanks
Jay Darst
85PT40
Spfld, IL
heavy
> load.
off the
powered
if
> - Jeff Miller
> in Holland, MI
> change
well
> it
Alternator
> BB
what
life
it
cooling
05-13-2006, 15:25
Thanks Jeff, When I dropped the alternator off at the rebuild shop I
deal with the techs. there did not know what the rework might
consist of,but they said they would give it back to me in the same
configuration as it was. Now that I know I will make sure they don't
install the tie. Jim Matus 1984 FC35SB Rescue CA
heavy
> load.
off the
powered
if
> - Jeff Miller
> in Holland, MI
> change
well
> it
Alternator
> BB
what
life
it
cooling
