FUEL TANK SENDING UNIT REMOVE AND REPLACE
05-18-2006, 17:32
I have aquestion concerning replacing, the fuel tank sending unit on
my '82 FC35RB, please check out the photos at;
http://www.pbase.com/image/60408087
"REMEMBER SEPTEMBER 11, 2001"
John Finn
'82 35FCRB
BLUEBIRD WANDERLODGE
TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE
GO TO;
http://www.pbase.com/image/24977457
HOPKINS, SOUTH CAROLINA
05-18-2006, 17:47
Looks pretty tight John. Would a right angle screwdriver get in there? Will
the sending unit length be a problem because it will have to come out at an
angle. I had a similar tight situation earlier this year and had to enlarge
an access hole through eighth inch plate steel using one of Randy's hole
saws.
> John Finn
> '82 35FCRB
> GO TO;
> Yahoo! Groups Links
Rob, Sue & Merlin Robinson
94 WLWB
05-18-2006, 23:29
Been there, drop front of tank a little. Floor jack does the trick.
MH
Sent: Friday, May 19, 2006 12:32 AM
Subject: [WanderlodgeForum] FUEL TANK SENDING UNIT REMOVE AND REPLACE
John Finn
'82 35FCRB
GO TO;
SPONSORED LINKS Recreational vehicles Recreational vehicle financing
Recreational vehicle repair
Recreational vehicle rental Recreational vehicle camper Recreational
vehicle rate
YAHOO! GROUPS LINKS
05-19-2006, 01:29
John, Drill a hole above the screw, larger than the driver,but I wonder
if there is room to lift the sender out?
94pt40 Romoland CA
05-19-2006, 01:36
Thanks Mike,
That will be a job for another time, when the tank is not full and
just continue to refuel at between 500 and 600 miles just to make
sure that I don't run out of fuel, so far that has worked OK. I might
also look at enlarging the access hole as Rob suggested and making a
new cover for it afterward, that would not be that hard to do either
using a sawsall, with a shortened blade.
I got the idea to change it after I had the dash apart and found out
that the fuel gauge was in working order at the dash, but I want to
finish the dash first and I'll be leaving here in less than a month.
John Finn
'82 35FCRB
GO TO;
> MH
> From: John
REPLACE
on
> John Finn
> '82 35FCRB
> GO TO;
financing Recreational vehicle repair
Recreational vehicle rate
> YAHOO! GROUPS LINKS
of Service.
05-19-2006, 01:58
Make sure there is no frame member under the floor. Seems to me there is,
that's why the hole is off a little.
MH
Sent: Friday, May 19, 2006 8:36 AM
Subject: [WanderlodgeForum] Re: FUEL TANK SENDING UNIT REMOVE AND REPLACE
Thanks Mike,
John Finn
'82 35FCRB
GO TO;
> MH
> From: John
REPLACE
on
> John Finn
> '82 35FCRB
> GO TO;
> YAHOO! GROUPS LINKS
of Service.
vehicle rate
YAHOO! GROUPS LINKS
05-19-2006, 03:25
John,
A pneumatic auto body saw works well for cutting the floor plate. The
stroke is shorter/faster than the sawsall. I use a regular hand hacksaw
blade, cut in thirds...they last longer than the blades sold
specifically for the air saw.
John wrote:
> Thanks Mike,
> John Finn
> '82 35FCRB
> GO TO;
> > MH
> > From: John
> REPLACE
> on
> > John Finn
> > '82 35FCRB
> > GO TO;
> > YAHOO! GROUPS LINKS
> of Service.
> SPONSORED LINKS
les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\
onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\
c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w>
<http://groups.yahoo.com/gads?t=ms&k=Recr...eatio\
nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\
=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\
cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg>
+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\
creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\
+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ>
+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA>
+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ>
<http://groups.yahoo.com/gads?t=ms&k=Recr...#43;v\
ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\
eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\
ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw>
> YAHOO! GROUPS LINKS
05-19-2006, 05:42
Thanks again Mike,
You are right again, there is a cross member located just aft of the
access hole, that I can feel when I stick my fingers under there, so
lowering the front of the tank will be the way to do the remove and
replace whenever I decide to do that, but when I have a lot less fuel
in the tank, to deal with weight wise.
John Finn
'82 35FCRB
GO TO;
there is, that's why the hole is off a little.
> MH
> From: John
REPLACE
> Thanks Mike,
might
making a
either
out
to
month.
> John Finn
> '82 35FCRB
> GO TO;
trick.
> > MH
> > From: John
> REPLACE
unit
> on
> > John Finn
> > '82 35FCRB
> > GO TO;
camper
> > YAHOO! GROUPS LINKS
Terms
> of Service.
> YAHOO! GROUPS LINKS
of Service.
05-20-2006, 00:46
Curt, is there a tool you dont have
Greg
94PT Romoland CA
> John,
hacksaw
05-20-2006, 06:25
In a message dated 5/20/2006 4:19:25 P.M. Eastern Daylight Time,
billpatty@... writes:
Bill That's pretty good a through away funnel. That is always the way
with a funnel it is always dirty when you need it & you have to clean it.
Don
89 SP 36'
Butler, PA
Here is a tool that Curt may not have.
http://www.fastfunnel.com/
They are great, 3 for $.99
Bill 88 FC
