1980 Generator Slide Air Valve
05-18-2006, 14:45
I think I need the entire mechanism. In works but not out. Anyone know
the part number and where to get one? Tks, SDF 80FC35 Boulder |
05-20-2006, 06:20
Do you know if it is the valve/sol or the air slide cylinder. If it
is the valve/sol I think it is the same as the one used on the air step. I just replaced the one on my step. It is available at Grainger, if you need to replace the valve/sol I can give you the part numbers, just let me know. Thanks Bruce Campbell '83FCSB "Blue Skies" --- In WanderlodgeForum@yahoogroups.com, "shawn_fountain" <shawn_fountain@...> wrote: > > I think I need the entire mechanism. In works but not out. Anyone know > the part number and where to get one? > > Tks, > SDF > 80FC35 Boulder > |
05-22-2006, 01:20
Thanks for the email. I need the valve/sol.
Tks, SDF ----Original Message Follows---- From: "fl_bluebird_1983" Reply-To: WanderlodgeForum@yahoogroups.com To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: 1980 Generator Slide Air Valve Date: Sat, 20 May 2006 18:20:46 -0000 Do you know if it is the valve/sol or the air slide cylinder. If it is the valve/sol I think it is the same as the one used on the air step. I just replaced the one on my step. It is available at Grainger, if you need to replace the valve/sol I can give you the part numbers, just let me know. Thanks Bruce Campbell '83FCSB "Blue Skies" --- In WanderlodgeForum@yahoogroups.com, "shawn_fountain" <shawn_fountain@...> wrote: > > I think I need the entire mechanism. In works but not out. Anyone know > the part number and where to get one? > > Tks, > SDF > 80FC35 Boulder > |
