tire pressure
05-31-2006, 01:45
tire pressure
i just put some bridgestone v-steel tires on my 35fcrb bb and was
wandering about tire pressure. what are people running front and rear. |
05-31-2006, 03:47
tire pressure
On our 86FC35RB I run 115lbs on the steers, and 85lbs on the drive, New
Michelin XZ-2. BUT that really does/should not mean ANYTHING TO YOUR APPLICATION. I am sure Bridgestone has a chart that will give you the model tire, and the air pressure based on the weight they have to carry. In order to make sense of this info, you MUST know the weight of the coach/ axles. Find a set of truck scales and go weigh the coach. Weigh the coach fully loaded, fuel, water, and "stuff" like you were leaving for a trip..the best way is to weigh each corner, but you may get by with just getting the front and rear weights. THEN from the weigh ticket match the weight to the appropriate pressure. NO OTHER WAY to be sure and correct. Tires are way to expensive to make an error here, not to mention the safety factor. ScottB 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "emc2jb6" > > i just put some bridgestone v-steel tires on my 35fcrb bb and was > wandering about tire pressure. what are people running front and rear. > |
05-31-2006, 11:23
tire pressure
---I put whatever pressure the tire states..nothing
less...eg....100psi front...then it's 100psi.......if 80psi duel..then it's 80psi dual etc. Hank Hannigan 90SP36(FOR SALE in Vegas) 80FC31 In WanderlodgeForum@yahoogroups.com, "emc2jb6" > > i just put some bridgestone v-steel tires on my 35fcrb bb and was > wandering about tire pressure. what are people running front and rear. > |
05-31-2006, 12:58
tire pressure
This has been discussed at length on the net for many years. Inlating
to the max. pressure on the sidewall is incorrect. Every mfr. publishes a load/inflation chart and that is your guide to proper pressure. There is some leeway for na RV to inflate a little beyond the listed psi. Michelin gives a full expalantion on their website. I will concede that on a heavy vehicle like a BB the max presures are very close. Especially on the front. But way off on the duallies. If you followed that theory on every vehicle you owned your pressures would be way too high in most cases. Say a duallie pickup. Bruce |
07-17-2006, 06:57
tire pressure
Hello,
I have followed several discussions in the past on tires, load ratings, and brands. However, not much has been said on tire pressure. A placard in my coach indicates 105 psi on front and 75 psi on rears. Is this the current thinking? 75 psi on the rear tires seems a little low esp when max pressure is over 100 psi. I have gotten some different advice locally, but I'm still running with the pressure as shown on the BB placard. Any comments appreciated. Alex Smith Tallahassee, FL 82FC35 --------------------------------- Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less. [Non-text portions of this message have been removed] |
07-17-2006, 07:30
tire pressure
Alex the prevailing wisdom here involves actual weight(s) and the use of
tire manufacturers tire guides. If you cannot weigh your coach at each wheel position then the next best is to weigh the axels. Once you have the weights you then proceed to the manufacturers tire guide (Michelin has one) and find your tire and size and the correct pressure for the load you are carrying. Front and tag axel weights divided by two and dual wheeled drive axel weight divided by four. On 17/07/06, Alex Smith > > Hello, > I have followed several discussions in the past on tires, load ratings, > and brands. However, not much has been said on tire pressure. > > A placard in my coach indicates 105 psi on front and 75 psi on rears. Is > this the current thinking? 75 psi on the rear tires seems a little low esp > when max pressure is over 100 psi. > > I have gotten some different advice locally, but I'm still running with > the pressure as shown on the BB placard. > > Any comments appreciated. > Alex Smith > Tallahassee, FL > 82FC35 > > > --------------------------------- > Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ > countries) for 2¢/min or less. > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
07-17-2006, 07:32
tire pressure
The air pressure should be consistent with the load ratings for the
brand of tire and the actual weight of your coach. While the BB manual has a chart in the owners manual (along with the required placard), it would be better to use the similar weight/air pressure chart provided by the tire manufacturer (usually accessible at the tire company web site). The placard is based on BB's estimated weight (with the OEM tires) -- you need to weigh your coach to determine the _actual_ tire pressure required with the normal load you carry. If you check your yellow pages for "public scales", hopefully you should find a scale reasonably close by*. You should load your coach as you would for a trip (full fuel, water tanks as you might normally have them, and food and baggage on board). The archives for this group probably have an explanation --- and I've seen several in RV-related magazines as well --- that explain precisely how to weigh the coach. You need to know the weight on each axle and on each wheel left vs. right. You want to be sure that the left-right load is reasonably balanced and that no axle is carrying more than its rated weight capacity. You should then inflate the tires for the weight of each axle per the tire mfgs table. The trade off is more air pressure will carry more weight -- but more air pressure will make the ride less-smooth (that's why you don't want to carry more air than is necessary). While simply filling the tires to the maximum pressure (as shown on the sidewall) will certainly ensure that you haven't under-inflated the tire, it may make your vehicle ride more harshly and may degrade the handling. Remember, too, that air inflation measurements must be made when the tire is at ambient temperature as heat generated in driving will raise the pressure, potentially causing to be under-inflated when the tires are cool. *Note: state-run "weigh stations" generally do not want to see an RV pull in to their scales. In California, you run a risk of getting a ticket, especially at a busy weigh station. Some other states may be more forgiving and/or may even be willing to pull the several weights you need (axle by axle, etc.) It would be wise to telephone ahead before pulling into a state-run weigh station. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA On Jul 17, 2006, at 11:57 AM, Alex Smith wrote: > Hello, > I have followed several discussions in the past on tires, load > ratings, and brands. However, not much has been said on tire pressure. > > A placard in my coach indicates 105 psi on front and 75 psi on > rears. Is this the current thinking? 75 psi on the rear tires seems > a little low esp when max pressure is over 100 psi. > > I have gotten some different advice locally, but I'm still > running with the pressure as shown on the BB placard. > > Any comments appreciated. > Alex Smith > Tallahassee, FL > 82FC35 > [Non-text portions of this message have been removed] |
07-18-2006, 00:20
tire pressure
Thanks Rob for the reply. There is a scale available several miles down the
interstate. I'll get that done next time out. Alex Rob Robinson Alex the prevailing wisdom here involves actual weight(s) and the use of tire manufacturers tire guides. If you cannot weigh your coach at each wheel position then the next best is to weigh the axels. Once you have the weights you then proceed to the manufacturers tire guide (Michelin has one) and find your tire and size and the correct pressure for the load you are carrying. Front and tag axel weights divided by two and dual wheeled drive axel weight divided by four. On 17/07/06, Alex Smith > > Hello, > I have followed several discussions in the past on tires, load ratings, > and brands. However, not much has been said on tire pressure. > > A placard in my coach indicates 105 psi on front and 75 psi on rears. Is > this the current thinking? 75 psi on the rear tires seems a little low esp > when max pressure is over 100 psi. > > I have gotten some different advice locally, but I'm still running with > the pressure as shown on the BB placard. > > Any comments appreciated. > Alex Smith > Tallahassee, FL > 82FC35 > > > --------------------------------- > Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ > countries) for 2¢/min or less. > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] --------------------------------- How low will we go? Check out Yahoo! Messengerâs low PC-to-Phone call rates. [Non-text portions of this message have been removed] |
07-18-2006, 13:41
tire pressure
Thanks Pete for the information. I checked http://www.michelin-us.com and they have
some really good information. If anyone needs to know how to weigh an RV, this website shows just how to do it. Alex Pete Masterson pressure should be consistent with the load ratings for the brand of tire and the actual weight of your coach. While the BB manual has a chart in the owners manual (along with the required placard), it would be better to use the similar weight/air pressure chart provided by the tire manufacturer (usually accessible at the tire company web site). The placard is based on BB's estimated weight (with the OEM tires) -- you need to weigh your coach to determine the _actual_ tire pressure required with the normal load you carry. If you check your yellow pages for "public scales", hopefully you should find a scale reasonably close by*. You should load your coach as you would for a trip (full fuel, water tanks as you might normally have them, and food and baggage on board). The archives for this group probably have an explanation --- and I've seen several in RV-related magazines as well --- that explain precisely how to weigh the coach. You need to know the weight on each axle and on each wheel left vs. right. You want to be sure that the left-right load is reasonably balanced and that no axle is carrying more than its rated weight capacity. You should then inflate the tires for the weight of each axle per the tire mfgs table. The trade off is more air pressure will carry more weight -- but more air pressure will make the ride less-smooth (that's why you don't want to carry more air than is necessary). While simply filling the tires to the maximum pressure (as shown on the sidewall) will certainly ensure that you haven't under-inflated the tire, it may make your vehicle ride more harshly and may degrade the handling. Remember, too, that air inflation measurements must be made when the tire is at ambient temperature as heat generated in driving will raise the pressure, potentially causing to be under-inflated when the tires are cool. *Note: state-run "weigh stations" generally do not want to see an RV pull in to their scales. In California, you run a risk of getting a ticket, especially at a busy weigh station. Some other states may be more forgiving and/or may even be willing to pull the several weights you need (axle by axle, etc.) It would be wise to telephone ahead before pulling into a state-run weigh station. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA On Jul 17, 2006, at 11:57 AM, Alex Smith wrote: > Hello, > I have followed several discussions in the past on tires, load > ratings, and brands. However, not much has been said on tire pressure. > > A placard in my coach indicates 105 psi on front and 75 psi on > rears. Is this the current thinking? 75 psi on the rear tires seems > a little low esp when max pressure is over 100 psi. > > I have gotten some different advice locally, but I'm still > running with the pressure as shown on the BB placard. > > Any comments appreciated. > Alex Smith > Tallahassee, FL > 82FC35 > [Non-text portions of this message have been removed] --------------------------------- See the all-new, redesigned Yahoo.com. Check it out. [Non-text portions of this message have been removed] |
07-19-2006, 00:34
tire pressure
Hi Alex,
Great advice from Pete. As you will want to follow his advice to weigh each tire separately, as you call to locate scales, you will have to specifically ask if they have that capability as most do not or will not. (They are Certified by Dept of Transportation therefore put up guard rails at scale sides so trucks have to weigh entire load and cannot drop off one side and receive a Certificate for a lighter weight than actual.) I have weighed individual tires in years past at the truck stop (Flying J, I think) in the vicinity of the Havana (Hwy 27) exit of I-10 near you. Pete probably assumed you knew all tires on the same axle should carry the same pressure. Meaning the heaviest tire position per axle will govern pressure, within the maximum limits of rim and tire casing. John Suter Jacksonville, FL --- Alex Smith > Thanks Pete for the information. I checked > http://www.michelin-us.com and they have some really good > information. If anyone needs to know how to weigh an > RV, this website shows just how to do it. > Alex > > Pete Masterson > The air pressure should be > consistent with the load ratings for the > brand of tire and the actual weight of your coach. > While the BB > manual has a chart in the owners manual (along with > the required > placard), it would be better to use the similar > weight/air pressure > chart provided by the tire manufacturer (usually > accessible at the > tire company web site). > > The placard is based on BB's estimated weight (with > the OEM tires) -- > you need to weigh your coach to determine the > _actual_ tire pressure > required with the normal load you carry. If you > check your yellow > pages for "public scales", hopefully you should > find a scale > reasonably close by*. You should load your coach as > you would for a > trip (full fuel, water tanks as you might normally > have them, and > food and baggage on board). > > The archives for this group probably have an > explanation --- and I've > seen several in RV-related magazines as well --- > that explain > precisely how to weigh the coach. You need to know > the weight on each > axle and on each wheel left vs. right. You want to > be sure that the > left-right load is reasonably balanced and that no > axle is carrying > more than its rated weight capacity. You should > then inflate the > tires for the weight of each axle per the tire mfgs > table. The trade > off is more air pressure will carry more weight -- > but more air > pressure will make the ride less-smooth (that's why > you don't want to > carry more air than is necessary). > > While simply filling the tires to the maximum > pressure (as shown on > the sidewall) will certainly ensure that you > haven't under-inflated > the tire, it may make your vehicle ride more > harshly and may degrade > the handling. > > Remember, too, that air inflation measurements must > be made when the > tire is at ambient temperature as heat generated in > driving will > raise the pressure, potentially causing to be > under-inflated when the > tires are cool. > > *Note: state-run "weigh stations" generally do not > want to see an RV > pull in to their scales. In California, you run a > risk of getting a > ticket, especially at a busy weigh station. Some > other states may be > more forgiving and/or may even be willing to pull > the several weights > you need (axle by axle, etc.) It would be wise to > telephone ahead > before pulling into a state-run weigh station. > > Pete Masterson > aeonix1@... > '95 Bluebird Wanderlodge WBDA 4203 > El Sobrante, CA > > On Jul 17, 2006, at 11:57 AM, Alex Smith wrote: > > > Hello, > > I have followed several discussions in the past > on tires, load > > ratings, and brands. However, not much has been > said on tire pressure. > > > > A placard in my coach indicates 105 psi on > front and 75 psi on > > rears. Is this the current thinking? 75 psi on > the rear tires seems > > a little low esp when max pressure is over 100 > psi. > > > > I have gotten some different advice locally, > but I'm still > > running with the pressure as shown on the BB > placard. > > > > Any comments appreciated. > > Alex Smith > > Tallahassee, FL > > 82FC35 > > > > [Non-text portions of this message have been > removed] > > > > > > > --------------------------------- > See the all-new, redesigned Yahoo.com. Check it > out. > > [Non-text portions of this message have been > removed] > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
