ridewell air suspension system.
08-01-2006, 15:00
After replacing the Forward heigth control valve, I took a good look
at all the air componets hidden in the frame of a 82 FC. There is a check valve and back pressure regulator on the cross seciton near the air dryer. This is the part tht appears to prevent air usagae of all aplinaces including the air bags if the pressure goes below 65 psi. On the forward cross member where the height control valve is located, there is one of the three air supension dump valves ( the other two are at the cross member behind the rear air bags.) on the passengers side of the cross member. Looking along the cross member toward the drivers side is a tee with the suspension dump sender for the light on the dash. Next dead center is a module above the Height control valve that I have no idea what it is for. Then comming around the corner and heading forward on the main frame drivers side is another small module that I have no idea what it is for. Then forwad of that ther is a larger module that I have no idea what it is for. Lots of fun. Does anyone out there have the superior knowledge to name the modules and their purpose. I feal like I am on a game show. Jim Hutchings 82 just like new 35RB Yorba Linda, CA |
08-01-2006, 15:10
Without knowing just what you're looking at, I'd have to guess it is
the parking brake valve, the proportioning valve, and the R-12 relay valve for the front brakes. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" wrote: > > After replacing the Forward heigth control valve, I took a good look > at all the air componets hidden in the frame of a 82 FC. There is a > check valve and back pressure regulator on the cross seciton near the > air dryer. This is the part tht appears to prevent air usagae of all > aplinaces including the air bags if the pressure goes below 65 psi. > On the forward cross member where the height control valve is located, > there is one of the three air supension dump valves ( the other two > are at the cross member behind the rear air bags.) on the passengers > side of the cross member. Looking along the cross member toward the > drivers side is a tee with the suspension dump sender for the light on > the dash. Next dead center is a module above the Height control valve > that I have no idea what it is for. Then comming around the corner > and heading forward on the main frame drivers side is another small > module that I have no idea what it is for. Then forwad of that ther is > a larger module that I have no idea what it is for. Lots of fun. Does > anyone out there have the superior knowledge to name the modules and > their purpose. I feal like I am on a game show. > > Jim Hutchings > 82 just like new 35RB > Yorba Linda, CA > |
08-01-2006, 15:21
Jim,
You going to attend the October rally in Buellton? Curt Sprenger 1987 PT38, Anaheim Hills, Calif. bluebird3208 wrote: > After replacing the Forward heigth control valve, I took a good look > at all the air componets hidden in the frame of a 82 FC. There is a > check valve and back pressure regulator on the cross seciton near the > air dryer. This is the part tht appears to prevent air usagae of all > aplinaces including the air bags if the pressure goes below 65 psi. > On the forward cross member where the height control valve is located, > there is one of the three air supension dump valves ( the other two > are at the cross member behind the rear air bags.) on the passengers > side of the cross member. Looking along the cross member toward the > drivers side is a tee with the suspension dump sender for the light on > the dash. Next dead center is a module above the Height control valve > that I have no idea what it is for. Then comming around the corner > and heading forward on the main frame drivers side is another small > module that I have no idea what it is for. Then forwad of that ther is > a larger module that I have no idea what it is for. Lots of fun. Does > anyone out there have the superior knowledge to name the modules and > their purpose. I feal like I am on a game show. > > Jim Hutchings > 82 just like new 35RB > Yorba Linda, CA > > |
