No horn
08-15-2006, 02:55
No horn
I just brought my new 78FC home and the main horn does not work. (not
the air or musical horns which I knew didn't work). I haven't looked yet, but does anyone know where the wire from the horn button on the steering wheel exits the stering column? The horn only beeped once while we were doing the final run through, so I assume there is a poor connection or the button has failed. Gardner 78FC33 |
08-15-2006, 03:35
No horn
Check the air/electric horn toggle switch on the dash, maybe it's in
the "air" position? Bob Janes, Greenville, SC --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > I just brought my new 78FC home and the main horn does not work. (not > the air or musical horns which I knew didn't work). I haven't looked > yet, but does anyone know where the wire from the horn button on the > steering wheel exits the stering column? The horn only beeped once > while we were doing the final run through, so I assume there is a poor > connection or the button has failed. > > > Gardner 78FC33 > |
08-15-2006, 04:03
No horn
Gardner,
On the '78 FC I had, I occasionally had to remove the horn button and push it back in. There was not a very good ground connection between the button and the steering wheel hub. David Hollis 84 FC35(with Jeff Miller and Ernie on its pedigree) Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > I just brought my new 78FC home and the main horn does not work. (not > the air or musical horns which I knew didn't work). I haven't looked > yet, but does anyone know where the wire from the horn button on the > steering wheel exits the stering column? The horn only beeped once > while we were doing the final run through, so I assume there is a poor > connection or the button has failed. > > > Gardner 78FC33 > |
08-15-2006, 05:40
No horn
Bob,
I flipped the switch between the trhee settings several times. I plan to follow the circuit and test continuity along the way. For now I only need the electric horn for state safety inspection so I may wire it around the switch if that is the problem. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > Check the air/electric horn toggle switch on the dash, maybe it's in > the "air" position? > Bob Janes, Greenville, SC > > --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > wrote: > > > > I just brought my new 78FC home and the main horn does not work. (not > > the air or musical horns which I knew didn't work). I haven't looked > > yet, but does anyone know where the wire from the horn button on the > > steering wheel exits the stering column? The horn only beeped once > > while we were doing the final run through, so I assume there is a > poor > > connection or the button has failed. > > > > > > Gardner 78FC33 > > > |
08-15-2006, 05:43
No horn
David,
I will check that as well. I suppose the horn button just 'pops' out with a little encouragement from a thin blade? I will be at the storage facility tonight and will see what I can do. Thanks Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "dthollis1961" > > Gardner, > > On the '78 FC I had, I occasionally had to remove the horn button and > push it back in. There was not a very good ground connection between > the button and the steering wheel hub. > > David Hollis 84 FC35(with Jeff Miller and Ernie on its pedigree) > Springfield,IL > > > --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > wrote: > > > > I just brought my new 78FC home and the main horn does not work. > (not > > the air or musical horns which I knew didn't work). I haven't looked > > yet, but does anyone know where the wire from the horn button on the > > steering wheel exits the stering column? The horn only beeped once > > while we were doing the final run through, so I assume there is a > poor > > connection or the button has failed. > > > > > > Gardner 78FC33 > > > |
08-15-2006, 07:34
No horn
In a message dated 8/15/2006 11:14:52 AM Central Daylight Time,
dthollis@... writes: > David Hollis 84 FC35(with Jeff Miller and Ernie on its pedigree) > Springfield,IL > David, I saw the pictures of our old coach at Clarks Rv sales. She still looks great!! Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
08-16-2006, 04:28
No horn
The horn works now, operator error. Ignition needed to be ON!
Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > In a message dated 8/15/2006 11:14:52 AM Central Daylight Time, > dthollis@... writes: > > > > David Hollis 84 FC35(with Jeff Miller and Ernie on its pedigree) > > Springfield,IL > > > > David, I saw the pictures of our old coach at Clarks Rv sales. She still > looks great!! > Ernie Ekberg > 83 PT40 > Livingston, Montana > > > > [Non-text portions of this message have been removed] > |
08-19-2006, 13:37
No horn
Well, it wasn't operator error after all. The horn works
intermittently. I have a second Bluebird horn button, but that is not the problem. I checked with an ohm meter and the button works fine. There is an intermittent connection between (I believe) the horn button and the dash switch. I noticed when the horn worked the air horn relay or solenoid clicked when the switch was in that position, and when the horn fails and I flip the switch, the air horn relay doesn't work either. Where does the horn wire exit the stering column? Does the circuit have a slip ring or other method of transfering the connection from the rotating steering column? Gardner 78FC33 (no beep) --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > The horn works now, operator error. Ignition needed to be ON! > > Gardner > 78FC33 > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > In a message dated 8/15/2006 11:14:52 AM Central Daylight Time, > > dthollis@ writes: > > > > > > > David Hollis 84 FC35(with Jeff Miller and Ernie on its pedigree) > > > Springfield,IL > > > > > > > David, I saw the pictures of our old coach at Clarks Rv sales. She > still > > looks great!! > > Ernie Ekberg > > 83 PT40 > > Livingston, Montana > > > > > > > > [Non-text portions of this message have been removed] > > > |
