Polarity Lights Modification
08-23-2006, 10:54
I talked with Doug Hampton at PMMI today regarding the modification to
the polarity lights in the outside power connection panel. I mentioned our coach has the polarity lights in the galley panel as well. Doug said both panels need to be modified to stop tripping the 15/20 amp GFIs. Per Doug the galley panel modification is the same as the outside panel, but is more difficult to do. Has anyone removed the galley panel? Any pointers? -- Curt Sprenger 1987 PT38, Anaheim Hills, Calif. |
08-24-2006, 10:31
Curt,
I removed the Galley Panel on my 87FC35 without any problem it is very easy. I think about 6-8 screws to take the panel itself off, then a few more to take the voltmeters off the panel, and a few electrical connections (be sure to unplug the bus from any power sources first, and it doesn't hurt to shut down the master 12V switches too). The bad news - after replacing the polarity indicators in both the galley and by the power cord inlet, I still trip the GFI outlets. I'll have to troubleshoot that some more, maybe it is something else, like the battery charger or something. Rick 87FC35 Rochester, MN --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > I talked with Doug Hampton at PMMI today regarding the modification to > the polarity lights in the outside power connection panel. I mentioned > our coach has the polarity lights in the galley panel as well. Doug said > both panels need to be modified to stop tripping the 15/20 amp GFIs. Per > Doug the galley panel modification is the same as the outside panel, but > is more difficult to do. Has anyone removed the galley panel? Any pointers? > > -- > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > |
08-24-2006, 11:10
Thanks, Rick. I'll hang on to your post and others for when I get to
that project. I'm leaning toward sending the panels to PMMI for the mods. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Rick B wrote: > Curt, > > I removed the Galley Panel on my 87FC35 without any problem it is very > easy. I think about 6-8 screws to take the panel itself off, then a > few more to take the voltmeters off the panel, and a few electrical > connections (be sure to unplug the bus from any power sources first, > and it doesn't hurt to shut down the master 12V switches too). > > The bad news - after replacing the polarity indicators in both the > galley and by the power cord inlet, I still trip the GFI outlets. > > I'll have to troubleshoot that some more, maybe it is something else, > like the battery charger or something. > > Rick > 87FC35 > Rochester, MN > > --- In WanderlodgeForum@yahoogroups.com > > > > > > I talked with Doug Hampton at PMMI today regarding the modification to > > the polarity lights in the outside power connection panel. I mentioned > > our coach has the polarity lights in the galley panel as well. Doug > said > > both panels need to be modified to stop tripping the 15/20 amp GFIs. > Per > > Doug the galley panel modification is the same as the outside panel, > but > > is more difficult to do. Has anyone removed the galley panel? Any > pointers? > > > > -- > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > |
08-24-2006, 14:18
I was tripping the GFI, and started pulling the covers
off electrical receptacles, and found a loose ground wire in one in the bathroom. Tightenedâr up and havenât had a trip since. (tripped breaker that is) Ron, No. California 85PT36 __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
