Accessory air sys
08-21-2006, 14:11
Accessory air sys
Jeff:
Now that I know I have an accessory air system, I assume it operates the air horns, dump valves, toilet, defrost baffles, air step, step cover, quick disconnect and???. There is also a schreder valve in the engine bay that I assume is used for shop purposes to pump the system up. I've never seen my accessory air tank. DO you know where it is? I put lanyards on my main tanks to drain them. Does the aux electric air pump go through the same control valve that protects the system because it charges my main tanks? Do you have a schematic of how these things are plumbed? If so I'll pay for a copy. Thanks; Leroy Eckert 1990 WB40 Niceville, FL |
08-21-2006, 15:08
Accessory air sys
Leroy,
I believe I have the schematic for our '87PT. Let me know if I should check on that and make a copy for you. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. jwasnewski wrote: > Jeff: > Now that I know I have an accessory air system, I assume it operates > the air horns, dump valves, toilet, defrost baffles, air step, step > cover, quick disconnect and???. There is also a schreder valve in the > engine bay that I assume is used for shop purposes to pump the system > up. I've never seen my accessory air tank. DO you know where it is? I > put lanyards on my main tanks to drain them. Does the aux electric air > pump go through the same control valve that protects the system because > it charges my main tanks? Do you have a schematic of how these things > are plumbed? If so I'll pay for a copy. Thanks; > > Leroy Eckert > 1990 WB40 > Niceville, FL > > |
08-22-2006, 13:37
Accessory air sys
Curt: Please, if it's not to much trouble. Send the bill to 1 Kristin Circle,
Niceville, FL. 32578 Glad you are back. Thought you fell out. Leroy Eckert 1990 WB40 Niceville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Monday, August 21, 2006 10:08 PM Subject: Re: [WanderlodgeForum] Accessory air sys Leroy, I believe I have the schematic for our '87PT. Let me know if I should check on that and make a copy for you. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. jwasnewski wrote: > Jeff: > Now that I know I have an accessory air system, I assume it operates > the air horns, dump valves, toilet, defrost baffles, air step, step > cover, quick disconnect and???. There is also a schreder valve in the > engine bay that I assume is used for shop purposes to pump the system > up. I've never seen my accessory air tank. DO you know where it is? I > put lanyards on my main tanks to drain them. Does the aux electric air > pump go through the same control valve that protects the system because > it charges my main tanks? Do you have a schematic of how these things > are plumbed? If so I'll pay for a copy. Thanks; > > Leroy Eckert > 1990 WB40 > Niceville, FL > > [Non-text portions of this message have been removed] |
08-23-2006, 03:03
Accessory air sys
Leroy,
Thanks. No, didn't fall out, just taking care of non Bird things the past two or three weeks. Regarding the air schematic(s)...After taking a look at what I have, I now recall diagrams (schematics) in my blue book not being up to date as far as what is installed on our coach. I'm also missing air diagram 10-13 sheet 1 & 2 (not sure what they should be). I called Bluebird, Bennie, more than a year ago, filled him on diagrams not up to date. Bennie sent me an updated Dual Air Brakes 38' & 40' diagram and part number/description/quantity sheets. That diagram shows the Wanderlodge Accessory Air, Auxiliary Air Compressor, and a total of 4 air tanks. I had that diagram enlarged, then color coded like components and listed the components, quantity and description. I suggest calling Bennie and explain your needs to him. He will most likely send you the updated diagram(s) along with the Part Number & Description sheets, free of charge. You may end up with something better than what I received. Let me know if that does not work and I'll make a copy of the enlarged diagram and the part/description sheets and get them to you. Please keep us posted. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Leroy Eckert wrote: > Curt: Please, if it's not to much trouble. Send the bill to 1 Kristin > Circle, Niceville, FL. 32578 Glad you are back. Thought you fell out. > > Leroy Eckert > 1990 WB40 > Niceville, FL > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, August 21, 2006 10:08 PM > Subject: Re: [WanderlodgeForum] Accessory air sys > > Leroy, > I believe I have the schematic for our '87PT. Let me know if I should > check on that and make a copy for you. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > jwasnewski wrote: > > > Jeff: > > Now that I know I have an accessory air system, I assume it operates > > the air horns, dump valves, toilet, defrost baffles, air step, step > > cover, quick disconnect and???. There is also a schreder valve in the > > engine bay that I assume is used for shop purposes to pump the system > > up. I've never seen my accessory air tank. DO you know where it is? I > > put lanyards on my main tanks to drain them. Does the aux electric air > > pump go through the same control valve that protects the system because > > it charges my main tanks? Do you have a schematic of how these things > > are plumbed? If so I'll pay for a copy. Thanks; > > > > Leroy Eckert > > 1990 WB40 > > Niceville, FL > > > > > > [Non-text portions of this message have been removed] > > |
08-23-2006, 05:12
Accessory air sys
Hi Curt,
If you are going to make a copy of that enlarged drawing, would you make a copy for me as well? Naturally, I'll be glad to pay for it. Maybe we should wait and see what Leroy gets back from Bennie. From what you have described, I believe that my couch is arranged very much like yours. Mine has a DATE OF MFG. 4-15-87 and a MFG BODY NO. 75392. Good to see you on the forum again. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 23, 2006 8:03 AM Subject: Re: [WanderlodgeForum] Accessory air sys Leroy, Thanks. No, didn't fall out, just taking care of non Bird things the past two or three weeks. Regarding the air schematic(s)...After taking a look at what I have, I now recall diagrams (schematics) in my blue book not being up to date as far as what is installed on our coach. I'm also missing air diagram 10-13 sheet 1 & 2 (not sure what they should be). I called Bluebird, Bennie, more than a year ago, filled him on diagrams not up to date. Bennie sent me an updated Dual Air Brakes 38' & 40' diagram and part number/description/quantity sheets. That diagram shows the Wanderlodge Accessory Air, Auxiliary Air Compressor, and a total of 4 air tanks. I had that diagram enlarged, then color coded like components and listed the components, quantity and description. I suggest calling Bennie and explain your needs to him. He will most likely send you the updated diagram(s) along with the Part Number & Description sheets, free of charge. You may end up with something better than what I received. Let me know if that does not work and I'll make a copy of the enlarged diagram and the part/description sheets and get them to you. Please keep us posted. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Leroy Eckert wrote: > Curt: Please, if it's not to much trouble. Send the bill to 1 Kristin > Circle, Niceville, FL. 32578 Glad you are back. Thought you fell out. > > Leroy Eckert > 1990 WB40 > Niceville, FL > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, August 21, 2006 10:08 PM > Subject: Re: [WanderlodgeForum] Accessory air sys > > Leroy, > I believe I have the schematic for our '87PT. Let me know if I should > check on that and make a copy for you. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > jwasnewski wrote: > > > Jeff: > > Now that I know I have an accessory air system, I assume it operates > > the air horns, dump valves, toilet, defrost baffles, air step, step > > cover, quick disconnect and???. There is also a schreder valve in the > > engine bay that I assume is used for shop purposes to pump the system > > up. I've never seen my accessory air tank. DO you know where it is? I > > put lanyards on my main tanks to drain them. Does the aux electric air > > pump go through the same control valve that protects the system because > > it charges my main tanks? Do you have a schematic of how these things > > are plumbed? If so I'll pay for a copy. Thanks; > > > > Leroy Eckert > > 1990 WB40 > > Niceville, FL > > > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
08-23-2006, 05:43
Accessory air sys
Hi Dick,
I'll keep that in mind. Yes, wait to hear what Leroy gets from Bennie. Tag outside by the entry door shows our coach date of mfg. is 5-87 (no day), and body no. 76383. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Richard Hayden wrote: > Hi Curt, > If you are going to make a copy of that enlarged drawing, would you > make a copy for me as well? Naturally, I'll be glad to pay for it. > Maybe we should wait and see what Leroy gets back from Bennie. From > what you have described, I believe that my couch is arranged very much > like yours. Mine has a DATE OF MFG. 4-15-87 and a MFG BODY NO. 75392. > > Good to see you on the forum again. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > |
08-23-2006, 06:47
Accessory air sys
Hi Curt: I just spoke with Bennie. He is sending me a schematic of my WB.
Apparently, there are some differences in the WB. He said there are 4 tanks. I have not seen but 2. I'll study the schematic when it arrives, then try to find my other tanks and expel any accumulated moisture. Everything is working but wouldn't hurt to know the system. If you want a copy I'll send you one. Leroy Eckert 1990 WB 40 Niceville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 23, 2006 12:43 PM Subject: Re: [WanderlodgeForum] Accessory air sys Hi Dick, I'll keep that in mind. Yes, wait to hear what Leroy gets from Bennie. Tag outside by the entry door shows our coach date of mfg. is 5-87 (no day), and body no. 76383. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Richard Hayden wrote: > Hi Curt, > If you are going to make a copy of that enlarged drawing, would you > make a copy for me as well? Naturally, I'll be glad to pay for it. > Maybe we should wait and see what Leroy gets back from Bennie. From > what you have described, I believe that my couch is arranged very much > like yours. Mine has a DATE OF MFG. 4-15-87 and a MFG BODY NO. 75392. > > Good to see you on the forum again. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > [Non-text portions of this message have been removed] |
08-26-2006, 09:53
Accessory air sys
Curt: I recieved a parts list and schematic on the air system today. If you
would like a copy, I' ll send it to you. Leroy 1990 WB-40 Niveville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, August 23, 2006 12:43 PM Subject: Re: [WanderlodgeForum] Accessory air sys Hi Dick, I'll keep that in mind. Yes, wait to hear what Leroy gets from Bennie. Tag outside by the entry door shows our coach date of mfg. is 5-87 (no day), and body no. 76383. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Richard Hayden wrote: > Hi Curt, > If you are going to make a copy of that enlarged drawing, would you > make a copy for me as well? Naturally, I'll be glad to pay for it. > Maybe we should wait and see what Leroy gets back from Bennie. From > what you have described, I believe that my couch is arranged very much > like yours. Mine has a DATE OF MFG. 4-15-87 and a MFG BODY NO. 75392. > > Good to see you on the forum again. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > [Non-text portions of this message have been removed] |
08-26-2006, 14:20
Accessory air sys
Leroy,
I'm good for now, but maybe some day. Thanks. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Leroy Eckert wrote: > > Curt: I recieved a parts list and schematic on the air system today. > If you would like a copy, I' ll send it to you. > > Leroy > 1990 WB-40 > Niveville, FL > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > Sent: Wednesday, August 23, 2006 12:43 PM > Subject: Re: [WanderlodgeForum] Accessory air sys > > Hi Dick, > I'll keep that in mind. Yes, wait to hear what Leroy gets from Bennie. > > Tag outside by the entry door shows our coach date of mfg. is 5-87 (no > day), and body no. 76383. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > Richard Hayden wrote: > > > Hi Curt, > > If you are going to make a copy of that enlarged drawing, would you > > make a copy for me as well? Naturally, I'll be glad to pay for it. > > Maybe we should wait and see what Leroy gets back from Bennie. From > > what you have described, I believe that my couch is arranged very much > > like yours. Mine has a DATE OF MFG. 4-15-87 and a MFG BODY NO. 75392. > > > > Good to see you on the forum again. > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > > > > > [Non-text portions of this message have been removed] > > |
