Por 15
08-26-2006, 22:55
Por 15
Leroy Have you ever sprayed Por 15 ? I have my fan off & all cleaned up
& was thinking about spraying it. I think it says you can. Raining today hear. Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] |
08-27-2006, 03:29
Por 15
Don:
Yes sir I have many times. Take your time with two light coats and one finish coat. I have even dipped small parts with excellent results. It works well particularly if there is humidity. It flows out nicely. Good luck, let me know how the parts turn out. Leroy Eckert 1990 WB-40 Niceville, FL. ----- Original Message ----- From: dspithaler@... To: WanderlodgeForum@yahoogroups.com Sent: Sunday, August 27, 2006 9:55 AM Subject: [WanderlodgeForum] Por 15 Leroy Have you ever sprayed Por 15 ? I have my fan off & all cleaned up & was thinking about spraying it. I think it says you can. Raining today hear. Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-27-2006, 04:06
Por 15
Don, I have sprayed POR15. You need a reduced viscosity & a large tip
for your gun. Be sure that you clean your gun real good when you finish or that will be the last time you use it. Use their prep coating on the fan first for good adhesion. Be sure to wear gloves etc too (disposable ones). Terry Neal Bozeman, MT 82PT40 74FC34 dspithaler@... wrote: > Leroy Have you ever sprayed Por 15 ? I have my fan off & all cleaned up > & was thinking about spraying it. I think it says you can. Raining today > hear. > Don > 89 SP 36' > Butler, PA > > [Non-text portions of this message have been removed] > > |
08-27-2006, 07:00
Por 15
Leroy I guess that is why it flowed so well on the pipes that I hand
painted today. It is extra high humidity here in PA today. Thanks Don 89 SP 36' Butler, PA Don Yes sir I have many times. Take your time with two light coats and one finish coat. I have even dipped small parts with excellent results. It works well particularly if there is humidity. It flows out nicely. Good luck, let me know how the parts turn out. Leroy Eckert 1990 WB-40 Niceville, FL. [Non-text portions of this message have been removed] |
08-27-2006, 08:16
Por 15
Great I didn't know you could use the cheap foam. I though they would maybe
melt down. Don 89 SP 36' Butler, PA Hey Don: Alright, happy to hear the parts look great. You can even use cheap foam brushes and get a beautiful product. POR-15 loves moisture in the air. Leroy 1990 WB-40 Niceville, FL [Non-text portions of this message have been removed] |
08-27-2006, 11:19
Por 15
Hey Don:
Alright, happy to hear the parts look great. You can even use cheap foam brushes and get a beautiful product. POR-15 loves moisture in the air. Leroy 1990 WB-40 Niceville, FL ----- Original Message ----- From: dspithaler@... To: WanderlodgeForum@yahoogroups.com Sent: Sunday, August 27, 2006 6:00 PM Subject: Re: [WanderlodgeForum] Por 15 Leroy I guess that is why it flowed so well on the pipes that I hand painted today. It is extra high humidity here in PA today. Thanks Don 89 SP 36' Butler, PA Don Yes sir I have many times. Take your time with two light coats and one finish coat. I have even dipped small parts with excellent results. It works well particularly if there is humidity. It flows out nicely. Good luck, let me know how the parts turn out. Leroy Eckert 1990 WB-40 Niceville, FL. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
