8V92 Thermostat, Gasket, Seal
09-02-2006, 06:10
Dick,
I'm starting a new thread that matches the subject matter. My invoice has the new and the old numbers. Thermostat new 23503825 / old 5102651, gasket new 5117786 / old 5117438, seal 5132155 / no ref. to Old #. The thermostats are 180 degrees. Cost $120.06 plus tax. I haven't purchased the hoses. I like to take the old with me and do the matching thing at the big truck parts store. Under the bed in our coach is a spare length of hose, larger diameter, blue color. Might be more back there. I recall seeing the one hose when I had my head in that area cleaning out the water tank Sporlan valve. How many miles should we get out of the 8V92 water pump? Curt Sprenger 1987 PT38, Anaheim Hills, Calif. |
09-02-2006, 13:14
Thanks Curt for the numbers. Did you get the parts at a DD store? I presume
that you did. 180 deg. sounds good to me. Lucky you on the length of large diameter hose. Just hope that it is 3.5 inch and is silicone. Remember though, there are several preformed 90 deg. elbows. All of my silicon hoses "feel" and look good. My mechanic says they are ok for now. But the small, short hoses on the engine feel hard and should be replaced. Wouldn't you know, they are the hardest to get to. Will do them when I replace the thermostats as that should be "easier". I just paid some outrageous prices for the constant tension clamps. NAPA turned out to be the best price by a bunch. They didn't stock all of them and their supplier, Balkamp, didn't supply the larger clamps in that style. But he went to an outside source and got Breeze Clamps at a better price than I paid at Kenworth Northwest when I got in a hurry. I have never heard how long a DD water pump should last. But, I think I'm pushing it with 142,000 miles. No problems but makes me nervous. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Saturday, September 02, 2006 11:10 AM Subject: [WanderlodgeForum] 8V92 Thermostat, Gasket, Seal Dick, I'm starting a new thread that matches the subject matter. My invoice has the new and the old numbers. Thermostat new 23503825 / old 5102651, gasket new 5117786 / old 5117438, seal 5132155 / no ref. to Old #. The thermostats are 180 degrees. Cost $120.06 plus tax. I haven't purchased the hoses. I like to take the old with me and do the matching thing at the big truck parts store. Under the bed in our coach is a spare length of hose, larger diameter, blue color. Might be more back there. I recall seeing the one hose when I had my head in that area cleaning out the water tank Sporlan valve. How many miles should we get out of the 8V92 water pump? Curt Sprenger 1987 PT38, Anaheim Hills, Calif. [Non-text portions of this message have been removed] |
09-03-2006, 11:47
Dick,
Yes, I got the parts at Valley Power Products, a DD store. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Richard Hayden wrote: > Thanks Curt for the numbers. Did you get the parts at a DD store? I > presume that you did. 180 deg. sounds good to me. > Lucky you on the length of large diameter hose. Just hope that it is > 3.5 inch and is silicone. Remember though, there are several preformed > 90 deg. elbows. All of my silicon hoses "feel" and look good. My > mechanic says they are ok for now. But the small, short hoses on the > engine feel hard and should be replaced. Wouldn't you know, they are > the hardest to get to. Will do them when I replace the thermostats as > that should be "easier". > I just paid some outrageous prices for the constant tension clamps. > NAPA turned out to be the best price by a bunch. They didn't stock all > of them and their supplier, Balkamp, didn't supply the larger clamps > in that style. But he went to an outside source and got Breeze Clamps > at a better price than I paid at Kenworth Northwest when I got in a > hurry. > I have never heard how long a DD water pump should last. But, I think > I'm pushing it with 142,000 miles. No problems but makes me nervous. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > > wanderlodge@yahoogroups.com > > Sent: Saturday, September 02, 2006 11:10 AM > Subject: [WanderlodgeForum] 8V92 Thermostat, Gasket, Seal > > Dick, > > I'm starting a new thread that matches the subject matter. > > My invoice has the new and the old numbers. Thermostat new 23503825 / > old 5102651, gasket new 5117786 / old 5117438, seal 5132155 / no ref. to > Old #. > > The thermostats are 180 degrees. Cost $120.06 plus tax. > > I haven't purchased the hoses. I like to take the old with me and do the > matching thing at the big truck parts store. > > Under the bed in our coach is a spare length of hose, larger diameter, > blue color. Might be more back there. I recall seeing the one hose when > I had my head in that area cleaning out the water tank Sporlan valve. > > How many miles should we get out of the 8V92 water pump? > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > [Non-text portions of this message have been removed] > > |
09-04-2006, 10:00
Curt:
My water pump failed at 109,000 miles. One of the very few problems I have incurred. I found it was leaking on a pre-trip inspection. The trip? Infield at Daytona International Speedway prepaid one year earlier. There are no refunds at NASCAR. Expensive water pump! Leroy Eckert 1990 WB-40 Niceville, FL ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Sunday, September 03, 2006 6:47 PM Subject: Re: [WanderlodgeForum] 8V92 Thermostat, Gasket, Seal Dick, Yes, I got the parts at Valley Power Products, a DD store. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Richard Hayden wrote: > Thanks Curt for the numbers. Did you get the parts at a DD store? I > presume that you did. 180 deg. sounds good to me. > Lucky you on the length of large diameter hose. Just hope that it is > 3.5 inch and is silicone. Remember though, there are several preformed > 90 deg. elbows. All of my silicon hoses "feel" and look good. My > mechanic says they are ok for now. But the small, short hoses on the > engine feel hard and should be replaced. Wouldn't you know, they are > the hardest to get to. Will do them when I replace the thermostats as > that should be "easier". > I just paid some outrageous prices for the constant tension clamps. > NAPA turned out to be the best price by a bunch. They didn't stock all > of them and their supplier, Balkamp, didn't supply the larger clamps > in that style. But he went to an outside source and got Breeze Clamps > at a better price than I paid at Kenworth Northwest when I got in a > hurry. > I have never heard how long a DD water pump should last. But, I think > I'm pushing it with 142,000 miles. No problems but makes me nervous. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > > wanderlodge@yahoogroups.com > > Sent: Saturday, September 02, 2006 11:10 AM > Subject: [WanderlodgeForum] 8V92 Thermostat, Gasket, Seal > > Dick, > > I'm starting a new thread that matches the subject matter. > > My invoice has the new and the old numbers. Thermostat new 23503825 / > old 5102651, gasket new 5117786 / old 5117438, seal 5132155 / no ref. to > Old #. > > The thermostats are 180 degrees. Cost $120.06 plus tax. > > I haven't purchased the hoses. I like to take the old with me and do the > matching thing at the big truck parts store. > > Under the bed in our coach is a spare length of hose, larger diameter, > blue color. Might be more back there. I recall seeing the one hose when > I had my head in that area cleaning out the water tank Sporlan valve. > > How many miles should we get out of the 8V92 water pump? > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
