dash generator start/stop switch wiring
09-05-2006, 01:51
On my 78FC33 the gen start/stop switch would only stop the genset, not
start it. The wiring diagram shows a DPDT switch, one side used for start and the other used for stop. My kitches switch is wired that way, but the dash switchis different. My dash switch is a DPDT with two extra lugs (8 connections in all). It seems that both the stop and start is run from one side of the DPDT. I moved the three connections to the other side of the switch and now it works. So that solved the imediate problem. What I don't understand is what are the other two connections? There are wires connected, but I don't know where they go. Has anyone seen this style switch or know the function of the extra lugs? Gardner 78FC33 |
09-05-2006, 02:24
Glowplugs ???. is the extra side momentary? maybe the switch was a
after factory replacement???. I have a 110 light switch in one dumptruck that runs the fan overide, not a ford item. GregoryO'Connor 94ptRomoland--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > > On my 78FC33 the gen start/stop switch would only stop the genset, not > start it. The wiring diagram shows a DPDT switch, one side used for > start and the other used for stop. My kitches switch is wired that way, > but the dash switchis different. My dash switch is a DPDT with two > extra lugs (8 connections in all). It seems that both the stop and > start is run from one side of the DPDT. I moved the three connections > to the other side of the switch and now it works. So that solved the > imediate problem. > > What I don't understand is what are the other two connections? There > are wires connected, but I don't know where they go. Has anyone seen > this style switch or know the function of the extra lugs? > > Gardner > 78FC33 > |
09-05-2006, 03:45
Gardner:
84 blueprint shows an 8 pin switch. attached you will find a schematic drawing which is redrawn from the wiring diagram. Hope this helps. Bill 84FC35SB Terrace, B.C. Gregory OConnor Glowplugs ???. is the extra side momentary? maybe the switch was a after factory replacement???. I have a 110 light switch in one dumptruck that runs the fan overide, not a ford item. GregoryO'Connor 94ptRomoland--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > > On my 78FC33 the gen start/stop switch would only stop the genset, not > start it. The wiring diagram shows a DPDT switch, one side used for > start and the other used for stop. My kitches switch is wired that way, > but the dash switchis different. My dash switch is a DPDT with two > extra lugs (8 connections in all). It seems that both the stop and > start is run from one side of the DPDT. I moved the three connections > to the other side of the switch and now it works. So that solved the > imediate problem. > > What I don't understand is what are the other two connections? There > are wires connected, but I don't know where they go. Has anyone seen > this style switch or know the function of the extra lugs? > > Gardner > 78FC33 > --------------------------------- Share your photos with the people who matter at Yahoo! Canada Photos [Non-text portions of this message have been removed] |
09-05-2006, 05:18
Bill,
Thanks, I will check my e-mail when I get home. I have een going over my documentation/drawings with a magnifying glass (literaly)and I am slowly beginning to follow things. I just need to physically locate many of the junctions, dtc. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Gardner: > 84 blueprint shows an 8 pin switch. attached you will find a schematic drawing which is redrawn from the wiring diagram. Hope this helps. > > Bill 84FC35SB > Terrace, B.C. > > Gregory OConnor > Glowplugs ???. is the extra side momentary? maybe the switch was a > after factory replacement???. I have a 110 light switch in one > dumptruck that runs the fan overide, not a ford item. > > GregoryO'Connor > 94ptRomoland--- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > > > > > On my 78FC33 the gen start/stop switch would only stop the genset, > not > > start it. The wiring diagram shows a DPDT switch, one side used for > > start and the other used for stop. My kitches switch is wired that > way, > > but the dash switchis different. My dash switch is a DPDT with two > > extra lugs (8 connections in all). It seems that both the stop and > > start is run from one side of the DPDT. I moved the three > connections > > to the other side of the switch and now it works. So that solved > the > > imediate problem. > > > > What I don't understand is what are the other two connections? > There > > are wires connected, but I don't know where they go. Has anyone > seen > > this style switch or know the function of the extra lugs? > > > > Gardner > > 78FC33 > > > > > > > > > --------------------------------- > Share your photos with the people who matter at Yahoo! Canada Photos > > [Non-text portions of this message have been removed] > |
09-05-2006, 09:16
Bill,
There was not an attachment? It may have been deleted by the board, can you send it directly ( gcyeaw@... Thanks Gardner 78FC33 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Wilhelmus Schreurs Sent: Tuesday, September 05, 2006 11:45 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: dash generator start/stop switch wiring Gardner: 84 blueprint shows an 8 pin switch. attached you will find a schematic drawing which is redrawn from the wiring diagram. Hope this helps. Bill 84FC35SB Terrace, B.C. Gregory OConnor < Gregoryoc@... Glowplugs ???. is the extra side momentary? maybe the switch was a after factory replacement???. I have a 110 light switch in one dumptruck that runs the fan overide, not a ford item. GregoryO'Connor 94ptRomoland--- In WanderlodgeForum@yahoogroups.com > > On my 78FC33 the gen start/stop switch would only stop the genset, not > start it. The wiring diagram shows a DPDT switch, one side used for > start and the other used for stop. My kitches switch is wired that way, > but the dash switchis different. My dash switch is a DPDT with two > extra lugs (8 connections in all). It seems that both the stop and > start is run from one side of the DPDT. I moved the three connections > to the other side of the switch and now it works. So that solved the > imediate problem. > > What I don't understand is what are the other two connections? There > are wires connected, but I don't know where they go. Has anyone seen > this style switch or know the function of the extra lugs? > > Gardner > 78FC33 > --------------------------------- Share your photos with the people who matter at Yahoo! Canada Photos [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
