Ignition switch
05-05-2005, 05:44
Ignition switch
Glenn, being able to start and stop your coach, is indeed, a milestone. Now,
if I only had some extra bucks for fuel ~) Ernie-83PT40 in Texas
05-05-2005, 09:39
Ignition switch
Just a note to mark a personal milestone. Took the old ignition switch
out, replaced it with a new bolted post one and reassembled the part
of the console the previous owner had left. She now starts like a
dream. Thanks to Mike Hoenstein for the pointer on the bolted
terminals. Not the first repair, but the first correct one.
Little details impress me.
Glenn Shehorn
83FC35RB
Kansas City Mo
I think I am too easily amused
05-05-2005, 09:41
Ignition switch
I'm glad that worked out for you.
Mike Hohnstein
Sent: Thursday, May 05, 2005 4:39 PM
Subject: [WanderlodgeForum] Ignition switch
Glenn Shehorn
83FC35RB
Kansas City Mo
Yahoo! Groups Links
09-24-2006, 01:29
Ignition switch
If you use graphite, put a towel around the switch, as graphite will stain
your floorcovering. I have seen many hinges on doors that on the carpet directly
under the hinge, a black stain.
83 PT40
Livingston, Montana
09-24-2006, 04:14
Ignition switch
Does anyone know the ignition switch make for 2004 M380. I can start
the engine from the rear switch but not the ignition switch. The keys
have been a little sticky recently getting in. It seems to turn all
the way to start-nothing happens.
thanks,
Jim O'Neil
M380
09-24-2006, 05:00
Ignition switch
Jim,
Use compressed air with a spray tube and blow down into key opening.
Try a squirt of graphite powder in the key switch. Also check the key for a
burr.
Howard Truitt
Camilla, Ga.
86 PT40
Sent: Sunday, September 24, 2006 12:14 PM
Subject: [WanderlodgeForum] ignition switch
thanks,
Jim O'Neil
M380
Internal Virus Database is out-of-date.
Checked by AVG Free Edition.
Version: 7.1.405 / Virus Database: 268.12.3/445 - Release Date: 9/11/2006
09-24-2006, 07:48
Ignition switch
If the key turns all the way to "Start", the pins and sheer
would seem to me be working as a key lock should though.
Graphite powder would definitely help the stickyness.
Wonder? Is there a theft-proof feature on the front that is
not in the rear ignition circuit?
Bob Janes, Greenville, SC
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
> Jim,
key for a burr.
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> From: brystal9
start
keys
all
> thanks,
> Jim O'Neil
> M380
9/11/2006
09-24-2006, 08:35
Ignition switch
Jim,
Another thought, on my 86 PT40 you have to flip the toggle switch at the rear to
crank from the rear and while set to crank from the rear it will not crank from
the front. Happened to me.
Howard Truitt
Camilla, Ga.
86 PT40
thanks,
Jim O'Neil
M380
09-24-2006, 23:00
Ignition switch
found out can't start the bus from the front with the engine door open!
thanks to all for your suggestions.
Jim O'Neil
M380
05-12-2009, 06:16
Ignition switch
Just spent the last two days chasing my tail trying to find a replacement
ignition switch for my 97 WB. Seems it is the same switch used for a long time
and know it is used at least on the 85FC as well.
Truck dealers don't stock this switch. I have gone to Kenworth, Peterbuilt, Ford
truck, Freightliner and GMC truck.
The place to get the switch is INTERNATIONAL, especially the school bus dealers.
It appears that school buses (makes sense) use the same switch and the
International part number is: 1652306C91. I replaced mine today.
In the for what it's worth dept., I stopped by the BB bus dealer here and they
have sent most of their parts back and didn't have the switch nor one that they
could find in their parts book.
For the archive, the Pollak part is 31-139 and the International part is
1652306C91.
Now all I have to figure out is how to change the lock cylinder so the keys to
the front ignition is the same as the rear ignition switch now that I have
changed the front.
Paul
97WB43
Silver Spring, MD
