EL Inverter Testing
09-24-2006, 08:53
EL Inverter Testing
There is 12VDC going to the upper dash EL inverter (only one inverter).
Using a clamp-on meter, clamping round one inverter wire at a time,
should I get ACV reading from at least one of the wires? I tried this
and no ACV reading on the meter.
Could the rheostat cause a no load condition to the inverter, and in
turn cause the inverter to go bad?
Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif.
09-24-2006, 09:41
EL Inverter Testing
Curt: Where did you buy that clamp on meter? That's what I need, May save me
a lot of time.
Leroy Eckert
1990 WB-40
Niceville, FL
To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com
Sent: Sunday, September 24, 2006 3:53 PM
Subject: [WanderlodgeForum] EL Inverter Testing
09-24-2006, 10:05
EL Inverter Testing
Leroy,
I bought the clamp-on meter at Harbor Freight, Item 42369, $17.99.
Clamp around only one wire, not multiples.
me a lot of time.
>Leroy Eckert
>1990 WB-40
>Niceville, FL
