Air in the water lines
04-15-2005, 13:50
I have this theory. When we're hooked up to shore water, we have
water pressure in the hose. When we want to unhook, we turn off the
water faucet at the campground, then snap off the hose from the quick-
release fitting on the coach and the hose spits water all over (me
included). So, here's my theory. After we turn off the water faucet,
we flip the fill switch to take pressure out of the hose, then turn
the fill switch off, disconnect the hose without getting wet. And it
works!
Only problem is, then we have air in the lines and water spits out of
the faucets. Why does this happen? What are your theories?
We want to unhook without getting spit on AND we want water pressure
without air in the lines.
Pen Sand & Jim O'Connor
83 PT35 (parked last night at Ernie's in Weatherford Texas
Ernie & Brenda are great hosts - they serve box wine)
04-15-2005, 14:01
Have you tried opening a faucet after you turn off the hose to
relieve pressure?
- Jeff Miller
http://www.wanderlodge.net
--- In WanderlodgeForum@yahoogroups.com, "jimocon"
quick-
faucet,
it
> works!
of
pressure
04-15-2005, 14:17
Jeff, do you mean turn on the kitchen faucet after turning the water
off at the campground and before disconnecting the hose? Haven't
tried that. Will do so next time we move.
Pen
83 PT 35
Wichita Falls TX tonite
> relieve pressure?
> - Jeff Miller
04-15-2005, 14:19
Yes, but the coach's outside faucet might be closer.
- Jeff Miller
water
> Pen
> 83 PT 35
> > relieve pressure?
> > - Jeff Miller
04-16-2005, 07:05
quick-
faucet,
turn
it
> works!
of
pressure
Hi Jim and Pen,
I have a thing....I guess it is called an "add a faucet". They are
available at camping supply places and at Walmart in the RV section.
It is a "T" with a male and female hose bib and a faucet. You screw
it on the campground faucet and then screw your hose on it. Then you
still have a faucet available at the campground faucet. I use this
to connect a hose to my spray flush nozzle on my black water tank
when I dump. Also very handy for hooking an additional hose to for
washing whatever. It can be used like Jeff suggested to releive
pressure when disconnecting but it is right there at your hose. No
going anywhere. One thing though. The one I bought was basically
junk. It broke in short order. I salvaged the faucet off it and went
to Home Depot and bought a heavy brass "T" and heavy duty male and
female hose bib fittings and made a new one. No trouble with it
since. I would suggest going to Home Depot or similar home
improvement place and assembling your own. Handy gizmo.
Sid Clark in Dallas-91WBSA40
04-16-2005, 09:44
Sid,
If I have read you right, what you are doing is in direct violation of
the code. There is to NEVER be a direct connection between any sewer
system and potable water. If you notice, at dump stations they have
two water sources, one for rinsing sewer/holding tanks and another.
located some distance away, for the potable water for filling your
potable water tank.
Making a direct connection could cause a serious medical problem for
someone.
George Lowry
Spearfish, SD
Sid Clark wrote:
> You screw
> when I dump.
04-18-2005, 11:03
George,
The spray nozzle has a built in check valve. I only hook up the hose
after the tank is empty and then unhook it when done. My first coach
appeared to be a factory installation. These spray systems are
available at Camping World and most all RV supply places. I beleive
the check valve meets code, but the hose should NEVER be left
connected.
--- In WanderlodgeForum@yahoogroups.com, George Lowry
> Sid,
violation of
sewer
have
another.
> potable water tank.
for
> someone.
> George Lowry
> Spearfish, SD
> Sid Clark wrote:
> > You screw
you
this
tank
> > when I dump.
