EL Test Panel
10-03-2006, 04:07
EL Test Panel
The EL Test Panel that Stephen Birtles made up and sent to me proved the
upper dash inverter is bad. I used jumpers and hooked up a new
inverter...the upper dash works great.
THANKS STEPHEN!
*Greg O'Connor*, please send me your Romoland mailing address. I'll mail
the EL Test Panel to you. I believe Leroy Eckert is to get the panel
after you.
Curt Sprenger 1987 PT38 8V92, Anaheim Hills, Calif.
10-03-2006, 08:09
EL Test Panel
Curt, Glad you got it going. I was able to make my upper panel working also,
broken wire at the upper rheostat and one of the inverters. My radio panel does
not work. I expect a panel problem. That little test panel will help me
confirm.
Questions Please:
How many inverters power your upper panel? Is your upper panel two six foot
pieces? Does the upper rheostat operate only the upper panel.
If you do not know please do not take the time to figure it out. As long as my
inverters work I'll leave them alone.
Still trying to determine how many of those elusive blue squares are in my
bus.(only found 4 wired together on the upper rheostat) I refuse to tear out
the TV and A/C ducts to trace the 110 side of those inverters.
Thanks,
Leroy Eckert
1990 WB-40
Niceville, FL
To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com
Sent: Tuesday, October 03, 2006 11:07 AM
Subject: [WanderlodgeForum] EL Test Panel
THANKS STEPHEN!
after you.
10-03-2006, 10:28
EL Test Panel
Leroy,
Upper panel consists of two 3' pieces, one inverter (if the new inverter
goes bad I'll install two), rheostat operates the upper panels, lower
dash also has a rheostat.
confirm.
>Questions Please:
>Thanks,
>Leroy Eckert
>1990 WB-40
>Niceville, FL
> From: Curt Sprenger
> THANKS STEPHEN!
> after you.
>Yahoo! Groups Links
10-03-2006, 11:40
EL Test Panel
Curt The one inverters in the top dash is that one of Stephens. My
original one had two of the blue cubes
Don
89 SP 36'
Butler, PA
Leroy,
also, broken wire at the upper rheostat and one of the inverters. My radio
panel
does not work. I expect a panel problem. That little test panel will help me
confirm.
>Questions Please:
my inverters work I'll leave them alone.
>Thanks,
10-03-2006, 12:12
EL Test Panel
Thanks Curt
I'm going try running my top with one of his.
Don 89 Sp 36' Butler, PA
Don,
Don't know. New one that works I got from Stephen. I question if two
inverters are needed.
10-03-2006, 12:18
EL Test Panel
Sorry, I meant two 3' pieces. Hummm, there's something happening here, what it
is ain't exactly clear! Thanks for the info.
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Tuesday, October 03, 2006 5:28 PM
Subject: Re: [WanderlodgeForum] EL Test Panel
Leroy,
not work. I expect a panel problem. That little test panel will help me confirm.
>Questions Please:
bus.(only found 4 wired together on the upper rheostat) I refuse to tear out the
>Thanks,
>Leroy Eckert
>1990 WB-40
>Niceville, FL
> From: Curt Sprenger
> THANKS STEPHEN!
> after you.
>Yahoo! Groups Links
10-03-2006, 14:18
EL Test Panel
Leroy: Great CSNY quote! I saw them this summer.
Bruce
10-03-2006, 15:51
EL Test Panel
Don,
>Don
>89 SP 36'
>Butler, PA
>Leroy,
panel
>confirm.
>>Questions Please:
>>Thanks,
>Yahoo! Groups Links
10-03-2006, 15:54
EL Test Panel
it was Buffalo Springfield with Stephen Stills and Neil Young
Stephen 77fc35
> Bruce
10-04-2006, 01:05
EL Test Panel
Anyone have a black light and ???? LOL
Thanks,
Leroy Eckert
1990 WB-40
Niceville, FL
Sent: Tuesday, October 03, 2006 10:54 PM
Subject: [WanderlodgeForum] Re: EL Test Panel
Stephen 77fc35
> Bruce
