Proch Light
10-16-2006, 07:24
Proch Light
The porch light at the entry door stopped working. There is 12+ volts
at one of the 4 bulb pin sockets. Do I need bulbs (they look like new), inverter, ballast? After removing the 2 screws holding the fixture to the body, that black center gromet is holding the fixture. I've pulled on it some and it is not coming away from the coach body. Appreciate suggestions? |
10-16-2006, 07:41
Proch Light
--- In WanderlodgeForum@yahoogroups.com, "Curtis Sprenger"
>Curt-- My porch lite didnt work when I bought my coach, the switch on the bottom of the light assy it self was broken off. I bought a new one almost identical to the orig. at home depot. It had a water proff rubber boot on it. Thats what fixed mine. I think it would come out a few inches away from the side of the caach. hope this helps.. what year rig do you have? Ed Gardels 89sp Arlington Texas > The porch light at the entry door stopped working. There is 12+ volts > at one of the 4 bulb pin sockets. Do I need bulbs (they look like > new), inverter, ballast? > > After removing the 2 screws holding the fixture to the body, that > black center gromet is holding the fixture. I've pulled on it some and > it is not coming away from the coach body. Appreciate suggestions? > |
10-16-2006, 07:42
Proch Light
10-16-2006, 07:50
Proch Light
Thanks Ed. Sorry about the lack of name, etc. My email is down so I
posted on the group site. Auto signature is nice. Curt Sprenger 1987 PT38 8V92 Anaheim, CA --- In WanderlodgeForum@yahoogroups.com, "Ed Gardels" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "Curtis Sprenger" > curtsprenger@ wrote: > >Curt-- My porch lite didnt work when I bought my coach, the switch on > the bottom of the light assy it self was broken off. I bought a new > one almost identical to the orig. at home depot. It had a water proff > rubber boot on it. Thats what fixed mine. I think it would come out a > few inches away from the side of the caach. > hope this helps.. what year rig do you have? > Ed Gardels 89sp > Arlington Texas > > > > The porch light at the entry door stopped working. There is 12+ volts > > at one of the 4 bulb pin sockets. Do I need bulbs (they look like > > new), inverter, ballast? > > > > After removing the 2 screws holding the fixture to the body, that > > black center gromet is holding the fixture. I've pulled on it some > and > > it is not coming away from the coach body. Appreciate suggestions? > > > |
10-16-2006, 08:30
Proch Light
Ed,
I went out and played with the proch light bottom switch, blue it out, and played some more. Turns out that switch is defective, turns on the light about one in 20 tries. I'll get a new one. Thanks again. Curt Sprenger 1987 PT38 8V92 Anaheim, CA --- In WanderlodgeForum@yahoogroups.com, "Curtis Sprenger" > > Thanks Ed. Sorry about the lack of name, etc. My email is down so I > posted on the group site. Auto signature is nice. > Curt Sprenger 1987 PT38 8V92 Anaheim, CA > > --- In WanderlodgeForum@yahoogroups.com, "Ed Gardels" > wrote: > > > > --- In WanderlodgeForum@yahoogroups.com, "Curtis Sprenger" > > curtsprenger@ wrote: > > >Curt-- My porch lite didnt work when I bought my coach, the switch on > > the bottom of the light assy it self was broken off. I bought a new > > one almost identical to the orig. at home depot. It had a water proff > > rubber boot on it. Thats what fixed mine. I think it would come out a > > few inches away from the side of the caach. > > hope this helps.. what year rig do you have? > > Ed Gardels 89sp > > Arlington Texas > > > > > > > The porch light at the entry door stopped working. There is 12+ > volts > > > at one of the 4 bulb pin sockets. Do I need bulbs (they look like > > > new), inverter, ballast? > > > > > > After removing the 2 screws holding the fixture to the body, that > > > black center gromet is holding the fixture. I've pulled on it some > > and > > > it is not coming away from the coach body. Appreciate suggestions? > > > > > > |
