Fuse locations??
11-08-2006, 12:27
Fuse locations??
I have the wiring diagrams for my 88FC. One of them is marked "lower
front load center". Where is this located? It has most of the main fuses for the parking, marker lites and much more. Lower to me means the dash area. The only place I did not look was behind the panel in front of the co pilot seat. Seems like that would be a bad place for fuses. Am I blind?? Help please. Bruce |
11-08-2006, 12:55
Fuse locations??
There is a pull-out box on the outside wall about the
area of your left calve sp? Mine has a CB on it, look there. Bob Janes, 87FC35, Greenville, SC --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > I have the wiring diagrams for my 88FC. One of them is marked "lower > front load center". Where is this located? It has most of the main > fuses for the parking, marker lites and much more. Lower to me means > the dash area. The only place I did not look was behind the panel in > front of the co pilot seat. Seems like that would be a bad place for > fuses. Am I blind?? Help please. > > Bruce > |
11-08-2006, 17:16
Fuse locations??
> > I have the wiring diagrams for my 88FC. One of them is marked "lower > front load center". Where is this located? It has most of the main > fuses for the parking, marker lites and much more. Lower to me means > the dash area. The only place I did not look was behind the panel in > front of the co pilot seat. Seems like that would be a bad place for > fuses. Am I blind?? Help please. > > Bruce > Bruce, I just got an 87FC35 a few months ago... and the one thing i've learned about where this stuff is... is that it's not necessarily in the same spot on any two coaches. That being said, here's where things are on mine. I've got a ZF trans, and my breakers are behind a panel underneath those buttons. (By the left leg when you are in the drivers seat.) The intercom phone might be attached to the side of the panel too. Then there are bosch relays. These are still giving me heck. I found 7 WAY in the back underneath my lower instrument panel (the one with the speedo). I also have some in the access panel behind the front grill on the driver's side. I also recently discovered that some "missing" relays are (in my coach) wired on a circuit board (also behind same grill access panel). There are two silver boxes with lots of wires going into them. If you open one up and peer inside, you can see the relays on the circuit board. These are giving me trouble as we speak, and BB says PMMI must have made them, but that's about all they can tell me. (And that's a problem, because some are failing and need to be replaced.) I haven't talked to anyone else that has these relays on a circuit board, but if you're missing some and can't find them, you might be "lucky" also and have them on a circuit board. (excuse the sarcasm.) Feel free to email me if you have any questions I might be able to answer (I don't always see all the posts on here.) Alan |
11-09-2006, 04:26
Fuse locations??
The FC have 3 banks of circuit breakers. The one you are looking for is
horizontal and covered with "stuff". It's behind the two vertical assemblies to the right of the steering column facing the front of the coach, swing panel open of course. MH ----- Original Message ----- From: birdshill123 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 09, 2006 8:55 AM Subject: [WanderlodgeForum] Re: Fuse locations?? Still searching for the elusive fuse panel. Undid the carpeted panel under the ZF shifter. The only items in that area are the ZF box and assocaited wiring. Checked above the bed. Nothing. Not behind the grill on the driver's side. I am wondering if they might have hidden it behind the upholstered panel under the dash in front of the co pilot?? I cannot understand how something so important would be hidden?? Or I just need a new set of eyes. Bruce [Non-text portions of this message have been removed] |
11-09-2006, 05:13
Fuse locations??
Mike:
Thanks for the reply. I found the breakers (not fuses). The 87 to 89's are different. They were behind the carpeted panel under the shifter. Still looking for my ground problem. Bruce |
11-09-2006, 12:11
Fuse locations??
Bruce, I'm not sure which Bird you have, but I have a fuse panel in the battery
compartment on the back wall. Not sure how many fuses, but if memory serves me they are the fuses that go to the rear lights. Bruce Morris (919)872-7635 Raleigh, NC Webmaster - WOO (http://www.wanderlodge.us) 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv ----- Original Message ----- From: birdshill123 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, November 09, 2006 9:55 AM Subject: [WanderlodgeForum] Re: Fuse locations?? Still searching for the elusive fuse panel. Undid the carpeted panel under the ZF shifter. The only items in that area are the ZF box and assocaited wiring. Checked above the bed. Nothing. Not behind the grill on the driver's side. I am wondering if they might have hidden it behind the upholstered panel under the dash in front of the co pilot?? I cannot understand how something so important would be hidden?? Or I just need a new set of eyes. Bruce [Non-text portions of this message have been removed] |
11-09-2006, 13:26
Fuse locations??
Bruce Morris: Thx. I found them.
Bruce 1988 FC35 |
