Wire Tracers
12-03-2006, 04:08
Wire Tracers
Tom, I see that the OTC 20 ton stands have a height range of from
15.25 to 24 inches. On the LXi, if I use the HWH jacks to pick the
back of the bus off the ground, the bottom of the frame rails at the tag
axle are approximately 28 inches from the ground. Have you seen
any stands that support 20 ton but have a height range suitable for
me. I don't feel comfortable putting blocking between the stand and
my reinforced, level, concrete floor, unless there's a suitable blocking
material that this list has experience with.
Thanks,
David Brady
'02 LXi, Smokey
Va, soon to be NC
Tom Warner wrote:
> GULP!!!!!!! What I meant to say is I have a 20 1/2 ton OTC axel
> hydraulic/air jack. Easy to use and very handy. I also have four 20
> ton heavy duty OTC jack stands. I work on the coach every day and am
> extremely safety conscious. One rule When I go under the bus I must
> come out
> Tom warner
> vernon center,ny
> 1985 PT 40
12-03-2006, 05:13
Wire Tracers
Hmm, I haven't been hit in the head using any imported hydraulic lifting
devices. My 60 year old art deco styled floor jack still gets the bus in the
air. (Shop air over oil powered) I don't get too close to it while it is doing
it's job. I know a guy who is missing vision in an eye due to a hydraulic press
accident. I don't do business with catalog sellers anymore. Too many
disappointments.
MH
Sent: Sunday, December 03, 2006 9:48 AM
Subject: [WanderlodgeForum] Re: Wire Tracers
Silly, what part of your M Benz was American Made? You can call me
Cheep but if $35.00 gets you 18% closer its worth it. I wonder if
that tool truck sells any Dale Carnegie titles.
GregoryO'Connor
94ptRomolandCa
<MHOHNSTEIN@...> wrote:
> That is very interesting, I used to work at American Can in
Milwaukee, the founder of Gardner Bender, Mr. Gardner worked there
too, before he moved on to bigger things.
> I'm not as wise as you POB, I buy my tools from the tool truck that
supplies PROFESSIONAL MECHANICS, you know, Snapon, Mac or Matco.
They laid me away a couple hundred dollars for such a device, and
call me silly but I like to use product made in this COUNTRY. As
bird owner I am used to tracing circuits, and if I get over my head I
call Jeff Miller. Others stressing over the loss of "Benny" might
check out Jeff at Dupree products. He knows.
> MH
> From: Tom Warner
> Sent: Saturday, December 02, 2006 12:21 PM
> Subject: [WanderlodgeForum] Wire Tracers
> One of the best wire tracers that I have used is the gardner
bender
> wire tracer that you can buy at both lowes, home depot and lots
of
> other places. They have two models a wire tracker and a LAN
tracker.
> I have the LAN tracker since I can troubleshoot computer and
phone
> lines with it also. Gardner Bender is one of the premier
producers of
> tools and test equipment for electricians, telephone repairmen
> communications personnel. Sure you can buy ones that cost
hundreds of
> dollars but for automotive, homes and telephone wire tracing this
> tool works fine, is portable, is easy to use and is reasonably
> priced. What kind of tool do you use Mike that costs hundreds of
> dollars and is better to trace wires?
> http://www.gardnerbender.com/
> http://www.discount-home-
improvement.com/Electrical/Gardner_Bender_LAN_Tracker.html
> Print out this sheet and you will find it for a little less at
either
> Lowes or Home depot
> tom warner
> vernon center,ny
> 1985 PT 40
> At 09:18 AM 12/2/2006, you wrote:
> >Only if you need one that works.
> >MH
> > From: erniecarpet@...
> > Sent: Saturday, December 02, 2006 7:44 AM
> > Subject: Re: [WanderlodgeForum] Re: Posing a question to gauge
> > interest....lurkers hel...
> > I thought those wire toners were in the couple hundred dollar
range?
> > Ernie Ekberg
> > 83PT40
> > Livingston, Montana
> > --ready to roll
> > [Non-text portions of this message have been removed]
> >Yahoo! Groups Links
12-03-2006, 06:27
Wire Tracers
In a message dated 12/3/2006 8:45:43 A.M. Mountain Standard Time,
warbucks@... writes:
20 1/2 ton OTC
It's amazing how sometimes my fingers don't type what my brain is thinking.
83PT40
Limon, Co
12-03-2006, 08:03
Wire Tracers
For that matter what part of any electronics device is made in the
USA, which hydraulic devices? As for tools some of the best are now
made in Japan and Taiwan and some are as expensive as Snapon which in
my opinion is way over priced for the occaional user.
Some of the tools I have had for over 45 years and they are still in
perfect shape and they are not snapon. I have two sets of 12X torque
multipliers which are made in Taiwan and believe me they are not
cheap and are very well made. The OTC heavy duty 22 1/2 ton
air/hydraulic floor jack is made in Taiwan and it is of excellent quality.
tom warner
vernon center,ny
1985 PT 40
>lifting devices. My 60 year old art deco styled floor jack still
>gets the bus in the air. (Shop air over oil powered) I don't get too
>close to it while it is doing it's job. I know a guy who is missing
>vision in an eye due to a hydraulic press accident. I don't do
>business with catalog sellers anymore. Too many disappointments.
>MH
> From: Gregory OConnor
> GregoryO'Connor
> 94ptRomolandCa
> > MH
> > From: Tom Warner
> bender
> of
> tracker.
> phone
> producers of
> and
> hundreds of
> either
> > Lowes or Home depot
> > tom warner
> > vernon center,ny
> > 1985 PT 40
> > >MH
> range?
> > > Ernie Ekberg
> > > 83PT40
> > > Livingston, Montana
> > > --ready to roll
> > >Yahoo! Groups Links
>Yahoo! Groups Links
