Hitch Extender Adapter
12-03-2006, 07:09
Hey guys, when Steve Gureasko arrives home tonite from the Galveston rally,
he can chime in on your question. We installed one for his neighbor this past spring. I don't remember what it was but it was a heavy duty extension. Ernie-83PT40 in Co going to Texas [Non-text portions of this message have been removed] |
12-03-2006, 11:51
Hello everyone. We're looking for a mount for a bike rack. We know
what bike rack we want (Thule T2) and we want to mount it on the back of the coach. But we can't mount the bike rack and tow the car at the same time without an adapter. We have seen such an adapter. Its called a 2" Dual Tow Hitch Extension Receiver Adapter. It is an extension for our tow bar and has another tow bar receiver welded on the side. With it we can tow the car AND have a hitch mount bike rack on the back of the coach. We found the adapter at toolprice.com SKU: 9164P. But that one is rated for 4000 lbs and we tow a Honda Pilot â 4500 lbs. Does anyone know of one off the shelf? Has anyone had one fabricated? All thoughts welcome. Pen Sand & Jim O'Connor '83 PT 35 Yuma AZ this week (70's and sunny) |
12-03-2006, 12:12
Jim, Having worked at the local welding shop and seen many "extensions", I can
say I have never seen one that I thought looked like a good idea. How about putting the rack of your choice on the back of the Pilot? Doug jimocon a mount for a bike rack. We know what bike rack we want (Thule T2) and we want to mount it on the back of the coach. But we can't mount the bike rack and tow the car at the same time without an adapter. We have seen such an adapter. Its called a 2" Dual Tow Hitch Extension Receiver Adapter. It is an extension for our tow bar and has another tow bar receiver welded on the side. With it we can tow the car AND have a hitch mount bike rack on the back of the coach. We found the adapter at toolprice.com SKU: 9164P. But that one is rated for 4000 lbs and we tow a Honda Pilot â 4500 lbs. Does anyone know of one off the shelf? Has anyone had one fabricated? All thoughts welcome. Pen Sand & Jim O'Connor '83 PT 35 Yuma AZ this week (70's and sunny) Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Cheap Talk? Check out Yahoo! Messenger's low PC-to-Phone call rates. [Non-text portions of this message have been removed] |
12-03-2006, 12:51
TrailerHitches.com has several "towing racks" listed -- with class 3
and 4 hitches. It notes that the "hitch's towing capacity is reduced by half when using towing racks." A class 4, nominally a 10,000 lb. hitch would then be rated at 5000 lbs. See <http://www.trailerhitches.com/carriers/b...ducts.cfm? action=view&key=CE716> for details. Might a rack that attaches to the ladder be better for you? See < http://www.jcwhitney.com/autoparts/Produ...-10101/Pr- p_Product.CATENTRY_ID:2007103/p-2007103/N-111+600005760/c-10107> for one example. Or, <http://www.toplinemfg.com/html/rv- ladderbikerk.html> for another. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Dec 3, 2006, at 4:12 PM, Doug Engel wrote: > Jim, Having worked at the local welding shop and seen many > "extensions", I can say I have never seen one that I thought looked > like a good idea. How about putting the rack of your choice on the > back of the Pilot? Doug > > jimocon > looking for a mount for a bike rack. We know > what bike rack we want (Thule T2) and we want to mount it on the back > of the coach. But we can't mount the bike rack and tow the car at the > same time without an adapter. > > We have seen such an adapter. Its called a 2" Dual Tow Hitch > Extension Receiver Adapter. It is an extension for our tow bar and > has another tow bar receiver welded on the side. With it we can tow > the car AND have a hitch mount bike rack on the back of the coach. We > found the adapter at toolprice.com SKU: 9164P. But that one is rated > for 4000 lbs and we tow a Honda Pilot â 4500 lbs. Does anyone know of > one off the shelf? Has anyone had one fabricated? All thoughts > welcome. > > Pen Sand & Jim O'Connor > '83 PT 35 > Yuma AZ this week (70's and sunny) [Non-text portions of this message have been removed] |
12-03-2006, 12:58
Cabelas.com has a very nice one for $60. Perfect for a bike rack.
Brent 77fc31 Ventura,CA --- In WanderlodgeForum@yahoogroups.com, "jimocon" wrote: > > Hello everyone. We're looking for a mount for a bike rack. We know > what bike rack we want (Thule T2) and we want to mount it on the back > of the coach. But we can't mount the bike rack and tow the car at the > same time without an adapter. > > We have seen such an adapter. Its called a 2" Dual Tow Hitch > Extension Receiver Adapter. It is an extension for our tow bar and > has another tow bar receiver welded on the side. With it we can tow > the car AND have a hitch mount bike rack on the back of the coach. We > found the adapter at toolprice.com SKU: 9164P. But that one is rated > for 4000 lbs and we tow a Honda Pilot â 4500 lbs. Does anyone know of > one off the shelf? Has anyone had one fabricated? All thoughts > welcome. > > Pen Sand & Jim O'Connor > '83 PT 35 > Yuma AZ this week (70's and sunny) > |
12-03-2006, 13:03
I had the same problem. Solved it by taking bike rack which had square to
accomidate extender and then welded a piece of 1&1/2 x6" steel on the bottom of the rack and drilling two holes to take bolts with lock nuts which fit over the extender and then was clamped to the extender by running the bolts through another identical piece of steel on the underside of the extender. I know that this sounds like a "rube goldberg" solution, but it actually worked and the load was not an issue since it was not affected. If this does not make any sense you can call me at 817 221-2404. jimocon Hello everyone. We're looking for a mount for a bike rack. We know what bike rack we want (Thule T2) and we want to mount it on the back of the coach. But we can't mount the bike rack and tow the car at the same time without an adapter. We have seen such an adapter. Its called a 2" Dual Tow Hitch Extension Receiver Adapter. It is an extension for our tow bar and has another tow bar receiver welded on the side. With it we can tow the car AND have a hitch mount bike rack on the back of the coach. We found the adapter at toolprice.com SKU: 9164P. But that one is rated for 4000 lbs and we tow a Honda Pilot â 4500 lbs. Does anyone know of one off the shelf? Has anyone had one fabricated? All thoughts welcome. Pen Sand & Jim O'Connor '83 PT 35 Yuma AZ this week (70's and sunny) Yahoo! Groups Links Wallace Craig 95 WLWB 42 Azle, Texas [Non-text portions of this message have been removed] |
12-03-2006, 13:27
I've got one that I use when I pull our 4 dr Sidekick. The hitch extension part
is very heavy duty. It's as strong as any hitch material I've seen. The top section that holds the bike rack is much less heavy duty. I suspect the downrating of the hitch is because the hitch is extended further away from the vehicle limiting the amount of the tongue weight on the extension. I wouldn't think it would make much of a difference when towing since there is very little tongue weight. It would roughly be equivalent to extending your tow bar by an additional 18 inches, which, as far as I can see, would make virtually no difference at all in the amount you could tow. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, "jimocon" > > Hello everyone. We're looking for a mount for a bike rack. We know > what bike rack we want (Thule T2) and we want to mount it on the back > of the coach. But we can't mount the bike rack and tow the car at the > same time without an adapter. > > We have seen such an adapter. Its called a 2" Dual Tow Hitch > Extension Receiver Adapter. It is an extension for our tow bar and > has another tow bar receiver welded on the side. With it we can tow > the car AND have a hitch mount bike rack on the back of the coach. We > found the adapter at toolprice.com SKU: 9164P. But that one is rated > for 4000 lbs and we tow a Honda Pilot â 4500 lbs. Does anyone know of > one off the shelf? Has anyone had one fabricated? All thoughts > welcome. > > Pen Sand & Jim O'Connor > '83 PT 35 > Yuma AZ this week (70's and sunny) > |
12-03-2006, 13:30
Blue Ox are rated at 10,000 lbs. I use one of the drop recievers,
they also have straight extensions. I ordered from towing world. http://www.blueox.us/Accessories/droprcvrs.htm http://www.blueox.us/Accessories/bikeracks.htm http://www.towingworld.com/Accessories/d...eivers.htm Dan 94 BMC 37' --- In WanderlodgeForum@yahoogroups.com, "jimocon" > > Hello everyone. We're looking for a mount for a bike rack. We know > what bike rack we want (Thule T2) and we want to mount it on the back > of the coach. But we can't mount the bike rack and tow the car at the > same time without an adapter. > > We have seen such an adapter. Its called a 2" Dual Tow Hitch > Extension Receiver Adapter. It is an extension for our tow bar and > has another tow bar receiver welded on the side. With it we can tow > the car AND have a hitch mount bike rack on the back of the coach. We > found the adapter at toolprice.com SKU: 9164P. But that one is rated > for 4000 lbs and we tow a Honda Pilot â 4500 lbs. Does anyone know of > one off the shelf? Has anyone had one fabricated? All thoughts > welcome. > > Pen Sand & Jim O'Connor > '83 PT 35 > Yuma AZ this week (70's and sunny) > |
12-03-2006, 13:30
Another solution I've seen is to weld another receiver to the top of
the one on your coach, use the top one for your bike rack and the original receiver for your dinghy. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Wallace Craig > > I had the same problem. Solved it by taking bike rack which had square to accomidate extender and then welded a piece of 1&1/2 x6" steel on the bottom of the rack and drilling two holes to take bolts with lock nuts which fit over the extender and then was clamped to the extender by running the bolts through another identical piece of steel on the underside of the extender. > I know that this sounds like a "rube goldberg" solution, but it actually worked and the load was not an issue since it was not affected. If this does not make any sense you can call me at 817 221- 2404. > > jimocon > Hello everyone. We're looking for a mount for a bike rack. We know > what bike rack we want (Thule T2) and we want to mount it on the back > of the coach. But we can't mount the bike rack and tow the car at the > same time without an adapter. > > We have seen such an adapter. Its called a 2" Dual Tow Hitch > Extension Receiver Adapter. It is an extension for our tow bar and > has another tow bar receiver welded on the side. With it we can tow > the car AND have a hitch mount bike rack on the back of the coach. We > found the adapter at toolprice.com SKU: 9164P. But that one is rated > for 4000 lbs and we tow a Honda Pilot â 4500 lbs. Does anyone know of > one off the shelf? Has anyone had one fabricated? All thoughts > welcome. > > Pen Sand & Jim O'Connor > '83 PT 35 > Yuma AZ this week (70's and sunny) > > > > > > Yahoo! Groups Links > > > > > > > Wallace Craig > 95 WLWB 42 > Azle, Texas > > > [Non-text portions of this message have been removed] > |
12-03-2006, 13:38
This is the one I use:
http://www.northerntool.com/webapp/wcs/s...929_492929 Kerry --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" wrote: > > I've got one that I use when I pull our 4 dr Sidekick. The hitch extension part is very heavy > duty. It's as strong as any hitch material I've seen. The top section that holds the bike > rack is much less heavy duty. I suspect the downrating of the hitch is because the hitch is > extended further away from the vehicle limiting the amount of the tongue weight on the > extension. I wouldn't think it would make much of a difference when towing since there is > very little tongue weight. It would roughly be equivalent to extending your tow bar by an > additional 18 inches, which, as far as I can see, would make virtually no difference at all in > the amount you could tow. > > Kerry > 82 Fc 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, "jimocon" > > > > Hello everyone. We're looking for a mount for a bike rack. We know > > what bike rack we want (Thule T2) and we want to mount it on the back > > of the coach. But we can't mount the bike rack and tow the car at the > > same time without an adapter. > > > > We have seen such an adapter. Its called a 2" Dual Tow Hitch > > Extension Receiver Adapter. It is an extension for our tow bar and > > has another tow bar receiver welded on the side. With it we can tow > > the car AND have a hitch mount bike rack on the back of the coach. We > > found the adapter at toolprice.com SKU: 9164P. But that one is rated > > for 4000 lbs and we tow a Honda Pilot â 4500 lbs. Does anyone know of > > one off the shelf? Has anyone had one fabricated? All thoughts > > welcome. > > > > Pen Sand & Jim O'Connor > > '83 PT 35 > > Yuma AZ this week (70's and sunny) > > > |
