Potable water filtration system
12-03-2006, 13:16
Post: #41
I finally have the right phrase to justify a water filtration
system, "Safe Sex". Let face it, you never know who the last person was that connected to the tap, so you should be concencious about protecting yourself and your family. I plan to install a top notch system, but I am still making decisions, so it's bottled water for now. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "iwander_85pt40" > > Gardner, > > I use a TastePURE CX90 water filter. It is a combination > ceramic/charcoal filter. I also have an inline filter under the sink. > > The CX90 has a blue see through housing, so you can monitor it. > Maintenance involves scrubbing the ceramic filter with an included > scrubbing pad, as needed. > > A few months ago I was hooked up to a well water source. The ceramic > filter prevented dirt and other contaminants from entering my system. > I had to clean the ceramic filter about once a week to maintain water > flow. > > Currently, we are hooked up to another well water system. > > Last week, I checked the filter and noticed it had turned a very dark > color, much darker than normal. Turns out algae had started to grow > on the ceramic filter. > > I pulled the filter and checked the outflow side of the inner charcoal > filter and connector to the coach. Clean as can be. The outer > ceramic filter surface was covered with algae. Most likely because > the filter is exposed to sunlight most of the day. > > I installed a new replacement filter and covered the housing to > prevent sunlight hitting it. > > During my research about water filters, I saw discussions about using > see-through versus opaque filter housings, due to the algae issue. > The see through housings were more likely to promote growth of algae. > I'm going to leave my filter covered to see what happens. > > In my opinion, a water filter is absolutely necessary because as > RVers, we have no idea how safe a particular water supply is. We > don't know if the previous RVer used an anti-siphon valve when he back > flushed his holding tanks, among other not so safe possibilities. > > Phil Corpus > 'iWander' 85PT40 > Left Coast > > > > > --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" > wrote: > > > > Does anyone have a reccomendation for a water filter system for > > drinking water? A simple particulate filter for dirt,etc is fine for > > the shower and toilet, but the kitchen sink cold water and ice maker > > are what I want to provide really well filtered water to. We currently > > bring along bottled water for drinking, coffee, etc. and don't use the > > icemaker, but that is a pain in the neck. Some of the filtration > > systems come in at 10 cents plus per gallon, but bottled water is a > > heck of a lot more than that. My '78 has a small filter under the sink > > for which I have no idea how to order a replacement cartridge. I would > > rather start fresh and do it right. > > > > Any suggestions, experiences, wise cracks? > > > > Gardner > > 78FC33 (when the Bird is not at my house, I just spend my time > > thinking up questions) > > > |
