Low sulfur fuel
12-05-2006, 10:16
Low sulfur fuel
I have a 95 BMC with the 300 Cummins diesel engine. I am full time now
on the West Coast and of course all you can get now is the new fuel. Should I be adding something when I fill up or is it OK for the older engines? If I should be using an additive, what is recommended and where do you get it? Lee Davis |
12-05-2006, 10:40
Low sulfur fuel
Lee: Around October 27 there was a discussion regarding Ultra Low Sulphur
Diesel Fuel. If you cannot find them in previous posts I have them in my deleted files and will forward them to you off forum if you shoot me you e-mail. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Lee Davis To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, December 05, 2006 4:16 PM Subject: [WanderlodgeForum] Low sulfur fuel I have a 95 BMC with the 300 Cummins diesel engine. I am full time now on the West Coast and of course all you can get now is the new fuel. Should I be adding something when I fill up or is it OK for the older engines? If I should be using an additive, what is recommended and where do you get it? Lee Davis [Non-text portions of this message have been removed] |
12-05-2006, 10:43
Low sulfur fuel
If you check this page from Chevron about fuel leaks with ULSD:
http://www.chevron.com/products/prodserv...hevro\ n_tb_2005Aug.pdf (if it wraps, use http://tinyurl.com/y6hszq ) You will see that they say the problem is aromatics, and not lubricity. They say: "Fuel additives do not appear to be a solution, since they do not change the aromatics content of the fuel." They consider only replacement of affected seals as the solution. On 12/5/2006 at 10:16 PM Lee Davis wrote: >I have a 95 BMC with the 300 Cummins diesel engine. I am full time now >on the West Coast and of course all you can get now is the new fuel. >Should I be adding something when I fill up or is it OK for the older >engines? If I should be using an additive, what is recommended and >where do you get it? Don Bradner http://www.arcatapet.net |
12-05-2006, 11:44
Low sulfur fuel
Nothing available that will solve the problem on this date.
R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Lee Davis" > > I have a 95 BMC with the 300 Cummins diesel engine. I am full time now > on the West Coast and of course all you can get now is the new fuel. > Should I be adding something when I fill up or is it OK for the older > engines? If I should be using an additive, what is recommended and > where do you get it? > > Lee Davis > |
12-05-2006, 12:06
Low sulfur fuel
Lee,
This has been discussed on many forums recently. Basically as I understand it, it summarizes as this: the new ULSD fuel has less lubricity, less aromatics and less fuel efficiency. Less lubricity for the older engines (defined in this case as pre-2007) means you *will* need to find a good additive package. One inexpensive way to add lubricity is to add plain old ATF (automatic transmission fluid) at each fill up. I have seen many different estimates of how much, everywhere from 1qt to 1gal per 100 gallons of fuel. Mike H., one of the forum's resident diesel gurus, even mentioned up to 5% ATF, which seems pretty high to me. Check with truck stops to see if any commercial additive packages for the ULSD have hit their shelves yet. While there are claims that fuel manufacturers have added additional lubricity additive packages to the ULSD, one of our Lone Star Birds members who owns a heavy diesel repair shop has said fuel pump manufacturers were recommending adding lubricity additives even with the previous LSD fuel or they would not warrant the pumps. In any event, it seems clear that you will need a lubricity agent to be safe. Less aromatics means less seal swelling which may translate into fuel leaks on some engines. A high pressure fuel leak on a hot engine is something I plan to keep a good eye out for when I have to start buying the ULSD (still have LSD available around here so far in spite of deadlines). I have heard rumors that some Mercedes and Cummins forums have already reported fuel leaks as a problem, but that could be more good old internet urban legends than fact. Find a discussion group specific to your engine, but watch your individual engine to be sure. Less fuel efficiency in the neighborhood of 1.2% has been reported (see http://www.nrc.gov/reading-rm/doc-collec...20062\ 2.pdf) At my fuel inefficiency of about 5-5.5mpg, a 1.2% decrease appears to be rounding error from my standpoint and something I can't much fret over. Points one and two are much more significant to me in terms of potentially disasterous results and long term engine wear. Something that has not been reported or discussed on the forums is how the new EPA laws have also affected lubricating oils. The new "CJ"-rated diesel engine oil spec was specifically designed for the 2007 ULSD engines. It also has reduced sulfur as well as phosphorous and sulfated ash which helps stabilize the oil's TBN (total base number), acts as a lubricity agent and provides alkalinity to counteract acid formation during combustion. My understanding is that oil manufacturers can not maintain the TBN with current additive packages. All of this taken together may result in reduced ability to neutralize blow-by which creates more sulpheric acid which in turn creates corrosion, more deposits which could clog piston rings and cause cylinder wall scuffing, less total wear protection for the engine, etc, etc...... While oil ratings are generally rated as backwards compatible (CI vs. CD, etc.), I noted some engine oil manufacturers recommending to use the CJ oils only in the new (2007+) heavy duty engines and stick with the older rated oils for older heavy duty diesel engines. In my opinion, you really need to be sure you are sticking with a CI rated oil for older (pre-2007) engines. As time goes on, and the over the road fleets mature into a predominance of 2007+ engines, the older oil formulations will probably be harder to come by. Just my understanding. Not a fuel or oil manufacturer, but grew up in the fuel distribution business and have maintained an interest in what is really going in my engines. FWIW, etc, etc.... Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Lee Davis" > > I have a 95 BMC with the 300 Cummins diesel engine. I am full time now > on the West Coast and of course all you can get now is the new fuel. > Should I be adding something when I fill up or is it OK for the older > engines? If I should be using an additive, what is recommended and > where do you get it? > > Lee Davis > |
