Stuck in Van Horn, TX
12-06-2006, 01:14
Julie- do you guys have Coach-net ERS? From what I understand they know
about our big rigs. Ernie Ekberg 83PT40 Weatherford, tx [Non-text portions of this message have been removed] |
12-06-2006, 05:28
We have been having problems with our Bluebird since Iowa. The turbo
boost won't. The problem has been intermittent if we waited awhile then she would drive fine. We stopped in Oklahoma City and had them change the oil and filters and they said that was the problem. We stopped in Duncan to have Ralph to some work on our coach and then were going to Irving, TX to have a shop there check the axle seals and install new front shocks. We lost the turbo boost just as we were getting on the interstate at Gainesville so I pulled off immediately as the check transmission light came on. I pushed the check transmission button and got code 21. After some time we started up again and it ran fine. It acted up again just before we got off the freeway for the shop and it limped into the parking lot. They checked it out and said it was faulty ground and cleaned all the corrosion off the chassis batteries and all of the ground connections and the other connections all the way to the front of the coach where the translator device is located. Test drove it and said the problem is fixed. We left Saturday morning and made it to Pecos on Sunday. We stayed there until Tuesday and 30 miles south of Pecos we again lost power. Dick phoned the shop in Irvine and he walked us through clearing the code and we started up again and just past Van Horn we had the same problem. We wound up on the roadside half on an exit ramp from the scenic overlook. We phoned our ERS and the person they contacted kept stalling about coming out to assess the problem. Finally as we were yet again on the phone to the ERS a tow driver stopped because the sheriff asked him to see if he could help. We started up the engine and it ran again so we went down hill into Van Horn and are parked in the lot of the tow truck driver. He says our problem is the transmission filters. Dick checked with the Allison shop in Irving and they said that didn't sound right to them. So we are going to find a campground and phone the Detroit Diesel/ Allison people in El Paso who have mobile service to find out if they can come check our rig out. I hope we can get someone to figure out what the problem is instead of paying everyone down the highway money to figure it out. Julie Bonser 1992 WLWB PT 40' |
12-06-2006, 06:12
Hi Julie,
When you say; "The turbo boost won't." I assume that you are loosing power. Detroit Diesel Electronic Controls (DDEC) will automatically cut engine power for many reasons including overheating, etc. If you are getting a repeating engine or transmission warning light, the cause of that may also be causing the DDEC to cut engine power. A Detroit/ Allison shop should be able to read the code and determine the cause. Perhaps those more knowledgeable will jump in here to add to this. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, Julia Bonser wrote: > > > We have been having problems with our Bluebird since Iowa. The turbo > boost won't. The problem has been intermittent if we waited awhile > then she would drive fine. We stopped in Oklahoma City and had them > change the oil and filters and they said that was the problem. We > stopped in Duncan to have Ralph to some work on our coach and then > were going to Irving, TX to have a shop there check the axle seals > and install new front shocks. > > We lost the turbo boost just as we were getting on the interstate at > Gainesville so I pulled off immediately as the check transmission > light came on. I pushed the check transmission button and got code > 21. After some time we started up again and it ran fine. It acted up > again just before we got off the freeway for the shop and it limped > into the parking lot. They checked it out and said it was faulty > ground and cleaned all the corrosion off the chassis batteries and > all of the ground connections and the other connections all the way > to the front of the coach where the translator device is located. > Test drove it and said the problem is fixed. > > We left Saturday morning and made it to Pecos on Sunday. We stayed > there until Tuesday and 30 miles south of Pecos we again lost power. > Dick phoned the shop in Irvine and he walked us through clearing the > code and we started up again and just past Van Horn we had the same > problem. We wound up on the roadside half on an exit ramp from the > scenic overlook. We phoned our ERS and the person they contacted kept > stalling about coming out to assess the problem. Finally as we were > yet again on the phone to the ERS a tow driver stopped because the > sheriff asked him to see if he could help. We started up the engine > and it ran again so we went down hill into Van Horn and are parked > in the lot of the tow truck driver. He says our problem is the > transmission filters. Dick checked with the Allison shop in Irving > and they said that didn't sound right to them. > > So we are going to find a campground and phone the Detroit Diesel/ > Allison people in El Paso who have mobile service to find out if they > can come check our rig out. > > I hope we can get someone to figure out what the problem is instead > of paying everyone down the highway money to figure it out. > > > > Julie Bonser > 1992 WLWB PT 40' > |
12-06-2006, 08:34
Julie- am glad that you have some competent folks coming to your assistance.
12-06-2006, 11:43
We have Camping World ERS which does know about big rigs except they
claimed there were qualified people in Van Horn to evaluate the problem. So Camping World did not want to pay the tow to El Paso. We phoned our insurer Foremost because we have emergency coverage with them. They did not quibble and a big tow rig is on its way to us now. Stuart and Stevenson in El Paso said they would want to test drive it with their laptop hooked up to the DDEC. They are both a Detroit Diesel and an Allison shop so I hope they will be able to find the problem. Julie Bonser 1992 WLWB PT 40' On Dec 6, 2006, at 12:14 PM, erniecarpet@... wrote: > Julie- do you guys have Coach-net ERS? From what I understand they > know > about our big rigs. > > Ernie Ekberg > 83PT40 > Weatherford, tx |
12-06-2006, 13:34
If you can find the DD booklet in your blue box, it gives
instructions on how to read the engine codes and has a table with the code meanings. Likewise, the Allison book should have instructions on retrieving the transmission codes along with their meanings. It's a start on understanding what's going on. Hint: Have a notepad handy so you can note down the codes as they're signaled (you count light flashes). You will need to be able to give full attention to the flashing lights, so set yourself up to write without needing to look at the paper. Don't write all over the dash board (as I did when the note pad slipped). Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Dec 6, 2006, at 10:12 AM, g_man1146 wrote: > Hi Julie, > > When you say; "The turbo boost won't." I assume that you are loosing > power. Detroit Diesel Electronic Controls (DDEC) will automatically > cut engine power for many reasons including overheating, etc. If you > are getting a repeating engine or transmission warning light, the > cause of that may also be causing the DDEC to cut engine power. A > Detroit/ Allison shop should be able to read the code and determine > the cause. Perhaps those more knowledgeable will jump in here to add > to this. > > Rich D. '99LXi43' CT [Non-text portions of this message have been removed] |
12-06-2006, 15:19
I hope they know to remove the drive shaft before towing.
Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, December 06, 2006 7:34 PM Subject: Re: [WanderlodgeForum] Stuck in Van Horn, TX Julie- am glad that you have some competent folks coming to your assistance. Ernie Ekberg 83PT40 Weatherford, tx [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
12-06-2006, 18:56
Thanks for the hint. My navigator wrote down the code from the test
transmission. We were not getting any codes from the engine. All systems looked normal. What is frustrating is we had an Allison dealer troubleshoot this issue and we still wind up on the side of the road. Julie Bonser 1992 WLWB PT 40' parking lot of Stewart & Stevenson El Paso, TX On Dec 6, 2006, at 7:34 PM, Pete Masterson wrote: > If you can find the DD booklet in your blue box, it gives > instructions on how to read the engine codes and has a table with the > code meanings. Likewise, the Allison book should have instructions on > retrieving the transmission codes along with their meanings. It's a > start on understanding what's going on. > > Hint: Have a notepad handy so you can note down the codes as they're > signaled (you count light flashes). You will need to be able to give > full attention to the flashing lights, so set yourself up to write > without needing to look at the paper. Don't write all over the dash > board (as I did when the note pad slipped). |
12-06-2006, 19:02
Yes he knew and we knew also. He did a fine job. Two hour tow from
Van Horn to El Paso. Now it is the wait for service. At least we are not in the back of the beyond any more. Julie Bonser 1992 WLWB PT 40' On Dec 6, 2006, at 9:19 PM, Leroy Eckert wrote: > I hope they know to remove the drive shaft before towing. > > Leroy Eckert > 1990 WB-40 "Smoke N Mirrors" > Niceville, FL > > > > > > ----- Original Message ----- > From: erniecarpet@... > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, December 06, 2006 7:34 PM > Subject: Re: [WanderlodgeForum] Stuck in Van Horn, TX > > > Julie- am glad that you have some competent folks coming to your > assistance. > > > Ernie Ekberg > 83PT40 > Weatherford, tx > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > |
