jacking up rear of fc35
01-01-2007, 05:42
in the next few days iam going to be checking the brakes on our bus and
i want to jack up the front and rear to remove wheels and do an
inspection. do not plan on jacking both at the same time. can anyone
tell me the proper placement of the jacks. i will be using 2-20 ton
jacks and some hefty blocking material. also at the same time iam going
to remove the rear leveling jacks and rebuild them. the right rear has
a bad leak.also going to look at the shocks and panhard rod.
happy new year and will be in kinder in february.
ed and peggy
"lonesome dove"
fc35rb
01-01-2007, 06:13
It's best to place the jacks under the axles, however when I replaced the rear
bags and panhard bar assembly I used 4 jack stands on the suspension frame as
the truck frame is way up there, a 15 ton floor jack is used to raise the bus.
I used a 5 ton floor jack to control the height of the differential after the
coach was elevated. The frame and related components were painted at that time.
The panhard bar replacement was purchased at a local semi trailer parts and
service facility, cost was $35.
The parking brakes do not lock the front axle.
6" concrete is a minumum surface for such work.
Mike Hohnstein
Germantown, WI
83FC35
Sent: Monday, January 01, 2007 11:42 AM
Subject: [WanderlodgeForum] jacking up rear of fc35
ed and peggy
"lonesome dove"
fc35rb
01-01-2007, 09:59
ok, exactly where did you put the jacks to support the motorhome?
dan
88pt38
kiwi
jackson, ms
Sent: Monday, January 01, 2007 12:13 PM
Subject: Re: [WanderlodgeForum] jacking up rear of fc35
the truck frame is way up there, a 15 ton floor jack is used to raise the bus. I
Mike Hohnstein
Germantown, WI
83FC35
ed and peggy
"lonesome dove"
fc35rb
Checked by AVG Free Edition.
Version: 7.1.409 / Virus Database: 268.16.1/611 - Release Date: 12/31/2006
01-01-2007, 12:36
The air ride suspension has a significant frame work that bolts to the chassis
frame rails. Raising the rear of the coach high enough to allow access to the
suspension components would require much taller jack stands than I have to reach
the frame rails.
Mike Hohnstein
Germantown, WI
83FC35
Sent: Monday, January 01, 2007 3:59 PM
dan
88pt38
kiwi
jackson, ms
Mike Hohnstein
Germantown, WI
83FC35
ed and peggy
"lonesome dove"
fc35rb
01-01-2007, 13:54
Mike -thanks for the return to my questions. you gave me the info that
i was looking for. had and idea but needed someone who has been their
and done that. it is hard to believe the size and weight of these
things,safety is always on my mind anytime i get close to getting under
my bus. just today i found someone with a ramp rated at 50 tons. will
drive the bus on the ramp and look things over good and then jack up
the bus and go to work. Mike again thanks for your help and hope you
have a good new year.
ed&peggy
"lonesome dove"
1983fcrb 35'
01-01-2007, 14:48
Ed, don't forget chocks
GregoryO'Connor
94ptRomolandCa
that
under
> ed&peggy
> "lonesome dove"
> 1983fcrb 35'
