Installing new stereo?
01-11-2007, 07:08
Before I cut the hole for the stereo which is larger than the existing
opening. How should the cover for the panel be cut as to not hurt the filament for the lighting? There is no lighting near but I don't want it to spreed. Should it be cut with a blade and then what? Seal the edges? |
01-11-2007, 09:58
What year is your coach? Are you cutting wood or the EL panel. If you plan to
cut the EL panel contact Stephen Birtles at http://www.capeinnovation.com before cutting. Leroy Eckert 1990 WB-40 "Smoke N Mirrors' Niceville, FL ----- Original Message ----- From: John Mann To: WanderlodgeForum@yahoogroups.com Sent: Thursday, January 11, 2007 1:08 PM Subject: [WanderlodgeForum] Installing new stereo? Before I cut the hole for the stereo which is larger than the existing opening. How should the cover for the panel be cut as to not hurt the filament for the lighting? There is no lighting near but I don't want it to spreed. Should it be cut with a blade and then what? Seal the edges? [Non-text portions of this message have been removed] |
01-11-2007, 10:10
Unless you are absolutly sure that there is no functioning EL panel
behind the Graphics DO NOT CUT if there is a functioning panel behind the graphic and you cut open the pouch or panel you will destroy it Either give me a call or send me your phone numbwer and I will call you Stephen 77fc35 905 328 0162 --- In WanderlodgeForum@yahoogroups.com, "John Mann" > > Before I cut the hole for the stereo which is larger than the existing > opening. How should the cover for the panel be cut as to not hurt the > filament for the lighting? There is no lighting near but I don't want > it to spreed. Should it be cut with a blade and then what? Seal the > edges? > |
01-11-2007, 11:06
Sorry About that I was in a hurry when I posted; It is in a 1985
pt40. The new stereo back is wider to accommodate a CD insted of just cassette. Only a little wider on each side, need to cut the EL panel and a little wood to accomadate. John Mann 1985 pt 40 Granbury Texas In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" wrote: > > Unless you are absolutly sure that there is no functioning EL panel > behind the Graphics DO NOT CUT > if there is a functioning panel behind the graphic and you cut open > the pouch or panel you will destroy it > Either give me a call or send me your phone numbwer and I will call you > Stephen 77fc35 > 905 328 0162 > > --- In WanderlodgeForum@yahoogroups.com, "John Mann" wrote: > > > > Before I cut the hole for the stereo which is larger than the existing > > opening. How should the cover for the panel be cut as to not hurt the > > filament for the lighting? There is no lighting near but I don't want > > it to spreed. Should it be cut with a blade and then what? Seal the > > edges? > > > |
01-11-2007, 12:12
OK, Stephen posted, please call him. He can help you .
Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: John Mann To: WanderlodgeForum@yahoogroups.com Sent: Thursday, January 11, 2007 5:06 PM Subject: [WanderlodgeForum] Re: Installing new stereo? Sorry About that I was in a hurry when I posted; It is in a 1985 pt40. The new stereo back is wider to accommodate a CD insted of just cassette. Only a little wider on each side, need to cut the EL panel and a little wood to accomadate. John Mann 1985 pt 40 Granbury Texas In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" wrote: > > Unless you are absolutly sure that there is no functioning EL panel > behind the Graphics DO NOT CUT > if there is a functioning panel behind the graphic and you cut open > the pouch or panel you will destroy it > Either give me a call or send me your phone numbwer and I will call you > Stephen 77fc35 > 905 328 0162 > > --- In WanderlodgeForum@yahoogroups.com, "John Mann" wrote: > > > > Before I cut the hole for the stereo which is larger than the existing > > opening. How should the cover for the panel be cut as to not hurt the > > filament for the lighting? There is no lighting near but I don't want > > it to spreed. Should it be cut with a blade and then what? Seal the > > edges? > > > [Non-text portions of this message have been removed] |
