Freeze protection heaters
02-02-2007, 06:01
Post: #21
Alex- if these is only 1 wire, I don't know why that can't be just wire nutted
together. Ernie-83PT40 in Wyoming ----- Original Message ----- From: Alex Smith To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 02, 2007 10:52 AM Subject: Re: [WanderlodgeForum] Freeze protection heaters There are 2 of those pipe wire heaters which plug into 110v outlet under the bath vanity in my Bird. I had to cut one wire to repair a copper tubing leak. Can the wire be spliced back? Any help appreciate. Alex Smith Tallahassee 82FC35RB ernieekberg@... wrote: terry- is that the light blue color plugs and wires that run who knows where? Both my birds had those and I was afraid to plug those in because, 1- didn't know if they worked, 2- did previous owners cut those somewhere, and 3- after 24 years- deterioration of those wires could possibly start a fire. So- I have removed most of those wires when I was adding my pex tubing last summer. Ernie-83PT40 in -4 Wyoming ----- Original Message ----- From: Terry Neal To: WanderlodgeForum@yahoogroups.com Sent: Thursday, February 01, 2007 6:36 PM Subject: Re: [WanderlodgeForum] Freeze protection heaters Ernie & Group, My 82 PT doesn't have any of the heaters that you describe. Wish that it did. All I have are some old Frostex heat tapes. Plugged one in a while back & it immediately burned the plug off the end of the tape. No heat tapes plugged in anymore. Terry Neal Bozeman, MT 82PT40 74FC34 ernieekberg@... wrote: > These are the freeze protection heaters that are located in the hot > water tank area, under the kitchen sink, and in the fresh water > compartment. Since my coach is old, i was asking if anyone repleced > these with newer more efficient models. These are electric. > Ernie-83PT40 in Wyoming > ----- Original Message ----- > From: Pete Masterson > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, February 01, 2007 4:05 PM > Subject: Re: [WanderlodgeForum] Freeze protection heaters > > I'm not sure what heaters you're wanting... the newer coaches use > "Perfectoe" electric heaters in the bathroom and under the kitchen > cabinets. See <http://www.electricsuppliesonline.com/pelhe.html > <http://www.electricsuppliesonline.com/pelhe.html>> for > a description. These are available in 120 or 208/240V models. The > 120V model is used in my coach. > > For the hot-water radiator-type heat, (hydronic heating system) the > fans used are simple "pancake" fans available in 120V and 12V ratings > at places like Radio Shack. (Check to see what voltage is used on the > one you're replacing.) If the radiators aren't getting hot, then you > may have a valve set wrong, a blocked water line, or another problem. > Perhaps someone with a closer aged coach can make some suggestions. > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > On Feb 1, 2007, at 12:45 PM, Ernest Ekberg wrote: > > > While I was stopped due to the bad weather, I was doing a check on my > > heaters. The kitchen heater was running but putting out no heat. I > > took one of Brenda's hair dryers and put it in that compartment. Works > > like a charm. > > My rear heater by the hot water heater, the fan was barely moving. > > Don't know why- these things are just 24 years old. Took the partition > > out of that compartment and added a ceramic heater to that area. > > Perhaps this was the problem I was having last year. Time to look for > > new heaters. Anyone know where we can find small, compact heaters like > > came in our coaches? Ernie-83PT40 in Buffalo, Wy, for a short time, I > > hope > > > > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] --------------------------------- Expecting? Get great news right away with email Auto-Check. Try the Yahoo! Mail Beta. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
02-02-2007, 07:22
Post: #22
Troy would like to talk to you about your newell,
could you send your email or phone #? madson95atyahoodotcom 8035fcsb calmar ia [hot here -9 should be up to zero by noon] --- ernieekberg@... wrote: > Try- are those heaters very efficient? They look > like the size that I could use. Ernie-83PT40 in > Wyoming > ----- Original Message ----- > From: Troy Tikalsky > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, February 01, 2007 10:05 PM > Subject: Re: [WanderlodgeForum] Freeze protection > heaters > > > Surplus Center has units similar to the ones used > in my coach. > > > http://www.surpluscenter.com/item.asp?UI...name=\ electric > > Troy Tikalsky > 1986 Newell > Waconia, MN > > ----- Original Message ----- > From: Ernest Ekberg > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, February 01, 2007 2:45 PM > Subject: [WanderlodgeForum] Freeze protection > heaters > > While I was stopped due to the bad weather, I was > doing a check on my > heaters. The kitchen heater was running but > putting out no heat. I > took one of Brenda's hair dryers and put it in > that compartment. Works > like a charm. > My rear heater by the hot water heater, the fan > was barely moving. > Don't know why- these things are just 24 years > old. Took the partition > out of that compartment and added a ceramic heater > to that area. > Perhaps this was the problem I was having last > year. Time to look for > new heaters. Anyone know where we can find small, > compact heaters like > came in our coaches? Ernie-83PT40 in Buffalo, Wy, > for a short time, I > hope > > [Non-text portions of this message have been > removed] > > > > > > [Non-text portions of this message have been > removed] > > ________________________________________________________________________________\ ____ Don't get soaked. Take a quick peak at the forecast with the Yahoo! Search weather shortcut. http://tools.search.yahoo.com/shortcuts/#loc_weather |
02-02-2007, 10:17
Post: #23
They work surprisingly well and draw about 12 amps. There are 2 inside the
coach and 1 in the bay where the water tanks and lines are located. The fan is wide and slow so they are very quiet. A single heater in the storage bay area 2'x4'x8.5' kept the water lines and tanks from freezing when it got below zero a few weeks ago. Troy ----- Original Message ----- From: ernieekberg@... To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 02, 2007 10:38 AM Subject: Re: [WanderlodgeForum] Freeze protection heaters Try- are those heaters very efficient? They look like the size that I could use. Ernie-83PT40 in Wyoming ----- Original Message ----- From: Troy Tikalsky To: WanderlodgeForum@yahoogroups.com Sent: Thursday, February 01, 2007 10:05 PM Subject: Re: [WanderlodgeForum] Freeze protection heaters Surplus Center has units similar to the ones used in my coach. http://www.surpluscenter.com/item.asp?UI...name=\ electric Troy Tikalsky 1986 Newell Waconia, MN ----- Original Message ----- From: Ernest Ekberg To: WanderlodgeForum@yahoogroups.com Sent: Thursday, February 01, 2007 2:45 PM Subject: [WanderlodgeForum] Freeze protection heaters While I was stopped due to the bad weather, I was doing a check on my heaters. The kitchen heater was running but putting out no heat. I took one of Brenda's hair dryers and put it in that compartment. Works like a charm. My rear heater by the hot water heater, the fan was barely moving. Don't know why- these things are just 24 years old. Took the partition out of that compartment and added a ceramic heater to that area. Perhaps this was the problem I was having last year. Time to look for new heaters. Anyone know where we can find small, compact heaters like came in our coaches? Ernie-83PT40 in Buffalo, Wy, for a short time, I hope [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
02-02-2007, 10:18
Post: #24
Alex:
If you are talking about the element themselves, no, they cannot be wired back together. If you cut the wire to the element that is ok to splice back together. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: "ernieekberg@..." To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 2, 2007 10:01:15 AM Subject: Re: [WanderlodgeForum] Freeze protection heaters Alex- if these is only 1 wire, I don't know why that can't be just wire nutted together. Ernie-83PT40 in Wyoming ----- Original Message ----- From: Alex Smith To: WanderlodgeForum@ yahoogroups. com Sent: Friday, February 02, 2007 10:52 AM Subject: Re: [WanderlodgeForum] Freeze protection heaters There are 2 of those pipe wire heaters which plug into 110v outlet under the bath vanity in my Bird. I had to cut one wire to repair a copper tubing leak. Can the wire be spliced back? Any help appreciate. Alex Smith Tallahassee 82FC35RB ernieekberg@ peoplepc. com wrote: terry- is that the light blue color plugs and wires that run who knows where? Both my birds had those and I was afraid to plug those in because, 1- didn't know if they worked, 2- did previous owners cut those somewhere, and 3- after 24 years- deterioration of those wires could possibly start a fire. So- I have removed most of those wires when I was adding my pex tubing last summer. Ernie-83PT40 in -4 Wyoming ----- Original Message ----- From: Terry Neal To: WanderlodgeForum@ yahoogroups. com Sent: Thursday, February 01, 2007 6:36 PM Subject: Re: [WanderlodgeForum] Freeze protection heaters Ernie & Group, My 82 PT doesn't have any of the heaters that you describe. Wish that it did. All I have are some old Frostex heat tapes. Plugged one in a while back & it immediately burned the plug off the end of the tape. No heat tapes plugged in anymore. Terry Neal Bozeman, MT 82PT40 74FC34 ernieekberg@ peoplepc. com wrote: > These are the freeze protection heaters that are located in the hot > water tank area, under the kitchen sink, and in the fresh water > compartment. Since my coach is old, i was asking if anyone repleced > these with newer more efficient models. These are electric. > Ernie-83PT40 in Wyoming > ----- Original Message ----- > From: Pete Masterson > To: WanderlodgeForum@ yahoogroups. com > > Sent: Thursday, February 01, 2007 4:05 PM > Subject: Re: [WanderlodgeForum] Freeze protection heaters > > I'm not sure what heaters you're wanting... the newer coaches use > "Perfectoe" electric heaters in the bathroom and under the kitchen > cabinets. See <http://www.electric suppliesonline. com/pelhe. html > <http://www.electric suppliesonline. com/pelhe. html>> for > a description. These are available in 120 or 208/240V models. The > 120V model is used in my coach. > > For the hot-water radiator-type heat, (hydronic heating system) the > fans used are simple "pancake" fans available in 120V and 12V ratings > at places like Radio Shack. (Check to see what voltage is used on the > one you're replacing.) If the radiators aren't getting hot, then you > may have a valve set wrong, a blocked water line, or another problem. > Perhaps someone with a closer aged coach can make some suggestions. > > Pete Masterson > aeonix1@mac. com > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > On Feb 1, 2007, at 12:45 PM, Ernest Ekberg wrote: > > > While I was stopped due to the bad weather, I was doing a check on my > > heaters. The kitchen heater was running but putting out no heat. I > > took one of Brenda's hair dryers and put it in that compartment. Works > > like a charm. > > My rear heater by the hot water heater, the fan was barely moving. > > Don't know why- these things are just 24 years old. Took the partition > > out of that compartment and added a ceramic heater to that area. > > Perhaps this was the problem I was having last year. Time to look for > > new heaters. Anyone know where we can find small, compact heaters like > > came in our coaches? Ernie-83PT40 in Buffalo, Wy, for a short time, I > > hope > > > > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] ------------ --------- --------- --- Expecting? Get great news right away with email Auto-Check. Try the Yahoo! Mail Beta. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
02-02-2007, 10:26
Post: #25
Thanks, Troy- I'll order 3 of them. Ernie-83PT40 in Wyoming with 24 year old
heaters ----- Original Message ----- From: Troy Tikalsky To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 02, 2007 3:17 PM Subject: Re: [WanderlodgeForum] Freeze protection heaters They work surprisingly well and draw about 12 amps. There are 2 inside the coach and 1 in the bay where the water tanks and lines are located. The fan is wide and slow so they are very quiet. A single heater in the storage bay area 2'x4'x8.5' kept the water lines and tanks from freezing when it got below zero a few weeks ago. Troy ----- Original Message ----- From: ernieekberg@... To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 02, 2007 10:38 AM Subject: Re: [WanderlodgeForum] Freeze protection heaters Try- are those heaters very efficient? They look like the size that I could use. Ernie-83PT40 in Wyoming ----- Original Message ----- From: Troy Tikalsky To: WanderlodgeForum@yahoogroups.com Sent: Thursday, February 01, 2007 10:05 PM Subject: Re: [WanderlodgeForum] Freeze protection heaters Surplus Center has units similar to the ones used in my coach. http://www.surpluscenter.com/item.asp?UI...name=\ electric Troy Tikalsky 1986 Newell Waconia, MN ----- Original Message ----- From: Ernest Ekberg To: WanderlodgeForum@yahoogroups.com Sent: Thursday, February 01, 2007 2:45 PM Subject: [WanderlodgeForum] Freeze protection heaters While I was stopped due to the bad weather, I was doing a check on my heaters. The kitchen heater was running but putting out no heat. I took one of Brenda's hair dryers and put it in that compartment. Works like a charm. My rear heater by the hot water heater, the fan was barely moving. Don't know why- these things are just 24 years old. Took the partition out of that compartment and added a ceramic heater to that area. Perhaps this was the problem I was having last year. Time to look for new heaters. Anyone know where we can find small, compact heaters like came in our coaches? Ernie-83PT40 in Buffalo, Wy, for a short time, I hope [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
02-02-2007, 12:34
Post: #26
I am also looking to replace my old freeze heaters but I'm not sure
these units are right for those with coaches without a true 220V circuit in the coach. It appears from the information on the link below that the fan in the unit is 115VAC BUT the heating elements are 220VAC. That would mean that they could not be plugged into or wired into the standard wiring in my coach and a special 220V circuit would need to be added to my circuit breaker box and then they would only work when the coach was plugged into a true 220V 50amp circuit. The price is excellent but I believe 115V units would be a better choice - unless your coach already has 220V heater circuits wired and you always plug into 220V 50amp circuits when you plan on needing the heaters. Harry Saddock 83FC35 South Windsor, CT --- In WanderlodgeForum@yahoogroups.com, > > Thanks, Troy- I'll order 3 of them. Ernie-83PT40 in Wyoming with 24 year old heaters > ----- Original Message ----- > From: Troy Tikalsky > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 02, 2007 3:17 PM > Subject: Re: [WanderlodgeForum] Freeze protection heaters > > > They work surprisingly well and draw about 12 amps. There are 2 inside the coach and 1 in the bay where the water tanks and lines are located. The fan is wide and slow so they are very quiet. A single heater in the storage bay area 2'x4'x8.5' kept the water lines and tanks from freezing when it got below zero a few weeks ago. > > Troy > > ----- Original Message ----- > From: ernieekberg@... > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 02, 2007 10:38 AM > Subject: Re: [WanderlodgeForum] Freeze protection heaters > > Try- are those heaters very efficient? They look like the size that I could use. Ernie-83PT40 in Wyoming > ----- Original Message ----- > From: Troy Tikalsky > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, February 01, 2007 10:05 PM > Subject: Re: [WanderlodgeForum] Freeze protection heaters > > Surplus Center has units similar to the ones used in my coach. > > http://www.surpluscenter.com/item.asp? UID=2007020123015286&item=16-1329&catname=electric > > Troy Tikalsky > 1986 Newell > Waconia, MN > > ----- Original Message ----- > From: Ernest Ekberg > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, February 01, 2007 2:45 PM > Subject: [WanderlodgeForum] Freeze protection heaters > > While I was stopped due to the bad weather, I was doing a check on my > heaters. The kitchen heater was running but putting out no heat. I > took one of Brenda's hair dryers and put it in that compartment. Works > like a charm. > My rear heater by the hot water heater, the fan was barely moving. > Don't know why- these things are just 24 years old. Took the partition > out of that compartment and added a ceramic heater to that area. > Perhaps this was the problem I was having last year. Time to look for > new heaters. Anyone know where we can find small, compact heaters like > came in our coaches? Ernie-83PT40 in Buffalo, Wy, for a short time, I > hope > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
02-02-2007, 12:49
Post: #27
Harry- hope I didn't make a mistake when i ordered these. I don't know if troy
has a dedicated 220v circuit on his Newell. It says on the website that you can put 2 wires together. Don't know what that means, but they will be delivered next week. i'll report what happens with these units. The price cannot be beat, however. Ernie-83PT40 in Wyoming ----- Original Message ----- From: hsaddock To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 02, 2007 5:34 PM Subject: [WanderlodgeForum] Re: Freeze protection heaters I am also looking to replace my old freeze heaters but I'm not sure these units are right for those with coaches without a true 220V circuit in the coach. It appears from the information on the link below that the fan in the unit is 115VAC BUT the heating elements are 220VAC. That would mean that they could not be plugged into or wired into the standard wiring in my coach and a special 220V circuit would need to be added to my circuit breaker box and then they would only work when the coach was plugged into a true 220V 50amp circuit. The price is excellent but I believe 115V units would be a better choice - unless your coach already has 220V heater circuits wired and you always plug into 220V 50amp circuits when you plan on needing the heaters. Harry Saddock 83FC35 South Windsor, CT --- In WanderlodgeForum@yahoogroups.com, > > Thanks, Troy- I'll order 3 of them. Ernie-83PT40 in Wyoming with 24 year old heaters > ----- Original Message ----- > From: Troy Tikalsky > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 02, 2007 3:17 PM > Subject: Re: [WanderlodgeForum] Freeze protection heaters > > > They work surprisingly well and draw about 12 amps. There are 2 inside the coach and 1 in the bay where the water tanks and lines are located. The fan is wide and slow so they are very quiet. A single heater in the storage bay area 2'x4'x8.5' kept the water lines and tanks from freezing when it got below zero a few weeks ago. > > Troy > > ----- Original Message ----- > From: ernieekberg@... > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 02, 2007 10:38 AM > Subject: Re: [WanderlodgeForum] Freeze protection heaters > > Try- are those heaters very efficient? They look like the size that I could use. Ernie-83PT40 in Wyoming > ----- Original Message ----- > From: Troy Tikalsky > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, February 01, 2007 10:05 PM > Subject: Re: [WanderlodgeForum] Freeze protection heaters > > Surplus Center has units similar to the ones used in my coach. > > http://www.surpluscenter.com/item.asp? UID=2007020123015286&item=16-1329&catname=electric > > Troy Tikalsky > 1986 Newell > Waconia, MN > > ----- Original Message ----- > From: Ernest Ekberg > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, February 01, 2007 2:45 PM > Subject: [WanderlodgeForum] Freeze protection heaters > > While I was stopped due to the bad weather, I was doing a check on my > heaters. The kitchen heater was running but putting out no heat. I > took one of Brenda's hair dryers and put it in that compartment. Works > like a charm. > My rear heater by the hot water heater, the fan was barely moving. > Don't know why- these things are just 24 years old. Took the partition > out of that compartment and added a ceramic heater to that area. > Perhaps this was the problem I was having last year. Time to look for > new heaters. Anyone know where we can find small, compact heaters like > came in our coaches? Ernie-83PT40 in Buffalo, Wy, for a short time, I > hope > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
02-02-2007, 13:11
Post: #28
Ernie, that heater has 2 - 1000 w elements which is a lot for a 9"
long unit. Try wiring the elements for 120 volts. You should get very warm air. Still cheap even using more units. I'm going to try them on a Q-bus I'm building. Paul C Virginia 90 SP-36 95 Q-bus ( future "Baby Bird") --- In WanderlodgeForum@yahoogroups.com, > > Harry- hope I didn't make a mistake when i ordered these. I don't know if troy has a dedicated 220v circuit on his Newell. It says on the website that you can put 2 wires together. Don't know what that means, but they will be delivered next week. i'll report what happens with these units. The price cannot be beat, however. Ernie-83PT40 in Wyoming > |
02-02-2007, 13:18
Post: #29
Paul, I like the fact that these units are close to the dimensions of my old
relics. Hope they do the trick. Ernie-83PT40 in Wyoming ----- Original Message ----- From: bluebirdsp36 To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 02, 2007 6:11 PM Subject: [WanderlodgeForum] Re: Freeze protection heaters Ernie, that heater has 2 - 1000 w elements which is a lot for a 9" long unit. Try wiring the elements for 120 volts. You should get very warm air. Still cheap even using more units. I'm going to try them on a Q-bus I'm building. Paul C Virginia 90 SP-36 95 Q-bus ( future "Baby Bird") --- In WanderlodgeForum@yahoogroups.com, > > Harry- hope I didn't make a mistake when i ordered these. I don't know if troy has a dedicated 220v circuit on his Newell. It says on the website that you can put 2 wires together. Don't know what that means, but they will be delivered next week. i'll report what happens with these units. The price cannot be beat, however. Ernie-83PT40 in Wyoming > [Non-text portions of this message have been removed] |
02-02-2007, 14:09
Post: #30
Ernie - using Paul's suggestion, you should get approximately half
the heat out of the unit compared to if it was run on its design voltage of 220V. From a heat output perspective, probably somewhere around a little less than 2/3rds the heat output of a heater designed for 115v 15 amp circuit. This is a somewhat educated WAG - if we knew the amperage they would draw, we could calculate this more closely. Other issue - if you study the pictures on the web site ("more photos"), you will notice that the heaters are not mounted in any type of enclosure and as such they are not suitable (not safe due to exposed electrical connections, lack of thermal protection from the heating elements to adjacent materials, motor hanging out in space, etc) for directly mounting behind a cabinet, under a bed, etc - they MUST be mounted in some kind of metal enclosure and then the enclosure with the heaters mounted inside mounted where you want them. Also, there is no thermostat on these units, you will need to wire in some kind of thermostat either in/on the enclosure you build for them or a separate thermostat some where in the area you are using them to to heat, otherwise they will just keep heating until you disconnect them. Lastly, you may want to put an on/off switch some where near where they are located. Still a great price for what they are - but they are not a "drop in" ![]() Harry Saddock 83FC35 South Windsor, CT --- In WanderlodgeForum@yahoogroups.com, "bluebirdsp36" > > Ernie, that heater has 2 - 1000 w elements which is a lot for a 9" > long unit. Try wiring the elements for 120 volts. You should get very > warm air. Still cheap even using more units. I'm going to try them on > a Q-bus I'm building. > > Paul C > Virginia > 90 SP-36 > 95 Q-bus ( future "Baby Bird") > > > > --- In WanderlodgeForum@yahoogroups.com, > > > > Harry- hope I didn't make a mistake when i ordered these. I don't > know if troy has a dedicated 220v circuit on his Newell. It says on > the website that you can put 2 wires together. Don't know what that > means, but they will be delivered next week. i'll report what happens > with these units. The price cannot be beat, however. Ernie-83PT40 in > Wyoming > > > > |
