update power problem observations
02-09-2007, 17:25
okay, first off, I am confused about electricity. There are four big
wires a big red one that goes to one of the 50 amp breakers, a black one that goes to the other, a white that goes to the bar with all the other little white ones and a green that goes to the other side with all the bare copper ones. I checked with my test light that lights for 110 and another light for 220, and when i touched the place where the red wire connects to the breaker and either the green or white bar it reads 110. when i do the same with the black wire on the other 50 amp breaker the same happens. I took the little plastic thing that holds the two 50 amp breakers together off and when i flip the top one the plugs that have lamps plugged into them go out, when I flip the other one the heater in the bathroom goes off. So both are doing something. Also, the gauges in the upper dash labeled ac voltage are reading:leg 1 120, leg 2 120. the gauges labeled ac amperage leg 1 reads zero and leg 2 reads 10. I looked for gfi plugs and found none. should I take the switch apart that I use to select genarator 30 or 50 amp? I tried to work it with the genarator and the same problem was there. Im so confused. Robert Rahn 88 pt 40 Kalispell, Mt. |
02-09-2007, 17:52
NO do not pull that switch apart. The guages you just talked about would not
have volts on them if the rotor switch is bad. Now I also have very low or no amps unless I am using a 110v item. remember your water heater is on one leg and the insta hot or eng block heater or 110v lighting will be on the other. BEFORE disassembly of any item turn on all of the 110v items to verify if the side has no draw. ALSO start your GEN and put it online. Again check all the 110v to see if there is a change. Paul Williams 88XXV 8V92 In South Lake Tahoe -----Original Message----- From: chaunceyboyblu@... To: WanderlodgeForum@yahoogroups.com Sent: Fri, 9 Feb 2007 9:25 PM Subject: [WanderlodgeForum] update power problem observations okay, first off, I am confused about electricity. There are four big wires a big red one that goes to one of the 50 amp breakers, a black one that goes to the other, a white that goes to the bar with all the other little white ones and a green that goes to the other side with all the bare copper ones. I checked with my test light that lights for 110 and another light for 220, and when i touched the place where the red wire connects to the breaker and either the green or white bar it reads 110. when i do the same with the black wire on the other 50 amp breaker the same happens. I took the little plastic thing that holds the two 50 amp breakers together off and when i flip the top one the plugs that have lamps plugged into them go out, when I flip the other one the heater in the bathroom goes off. So both are doing something. Also, the gauges in the upper dash labeled ac voltage are reading:leg 1 120, leg 2 120. the gauges labeled ac amperage leg 1 reads zero and leg 2 reads 10. I looked for gfi plugs and found none. should I take the switch apart that I use to select genarator 30 or 50 amp? I tried to work it with the genarator and the same problem was there. Im so confused. Robert Rahn 88 pt 40 Kalispell, Mt. ________________________________________________________________________ Check out the new AOL. Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more. [Non-text portions of this message have been removed] |
02-09-2007, 18:03
Robert,
If I follow what you described and what you tested, you are good to go in the circuit breaker panel. Removing the little plastic thing and flipping the breakers independently...tuning off the breakers should turn off those items connected to it...all seems good. Amperage registered on one leg and not the other...depends on the coach load demand and how the coach is wired. Very possible one leg would be zero while the other has a power demand on it. The reading of 110 & 120 volts in each leg tells me the legs are receiving power. Our '87 coach does not have GFIs and perhaps yours does not as well. Do not take the gen/shore switch apart until we hear more from others perhaps more familiar with doing so and testing same. My only other suggestion at this time is to unplug the shore cord, start the gen., be sure the switch is set to gen., reset all the breakers in the 110V control panel, and see what happens. Good luck. Curt Sprenger 198 PT38 8V92 "MacAttach Racing Anaheim Hills, CA Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Robert & Teri Rahn wrote: > okay, first off, I am confused about electricity. There are four big > wires a big red one that goes to one of the 50 amp breakers, a black > one that goes to the other, a white that goes to the bar with all the > other little white ones and a green that goes to the other side with > all the bare copper ones. I checked with my test light that lights > for 110 and another light for 220, and when i touched the place where > the red wire connects to the breaker and either the green or white > bar it reads 110. when i do the same with the black wire on the other > 50 amp breaker the same happens. I took the little plastic thing that > holds the two 50 amp breakers together off and when i flip the top > one the plugs that have lamps plugged into them go out, when I flip > the other one the heater in the bathroom goes off. So both are doing > something. Also, the gauges in the upper dash labeled ac voltage are > reading:leg 1 120, leg 2 120. the gauges labeled ac amperage leg 1 > reads zero and leg 2 reads 10. I looked for gfi plugs and found none. > should I take the switch apart that I use to select genarator 30 or > 50 amp? I tried to work it with the genarator and the same problem > was there. Im so confused. > Robert Rahn > 88 pt 40 > Kalispell, Mt. > > |
02-09-2007, 18:38
Robert:
Curt has a very good point here. I would not take a part anything else just yet. If you have power at the 50 amp breaker box, then everything up to there should be okay. Take a look at the circuit breaker box and plug in a known load like a 1500 watt heater and then check the ammeter. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 9, 2007 10:03:04 PM Subject: Re: [WanderlodgeForum] update power problem observations Robert, If I follow what you described and what you tested, you are good to go in the circuit breaker panel. Removing the little plastic thing and flipping the breakers independently. ..tuning off the breakers should turn off those items connected to it...all seems good. Amperage registered on one leg and not the other...depends on the coach load demand and how the coach is wired. Very possible one leg would be zero while the other has a power demand on it. The reading of 110 & 120 volts in each leg tells me the legs are receiving power. Our '87 coach does not have GFIs and perhaps yours does not as well. Do not take the gen/shore switch apart until we hear more from others perhaps more familiar with doing so and testing same. My only other suggestion at this time is to unplug the shore cord, start the gen., be sure the switch is set to gen., reset all the breakers in the 110V control panel, and see what happens. Good luck. Curt Sprenger 198 PT38 8V92 "MacAttach Racing Anaheim Hills, CA Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Robert & Teri Rahn wrote: > okay, first off, I am confused about electricity. There are four big > wires a big red one that goes to one of the 50 amp breakers, a black > one that goes to the other, a white that goes to the bar with all the > other little white ones and a green that goes to the other side with > all the bare copper ones. I checked with my test light that lights > for 110 and another light for 220, and when i touched the place where > the red wire connects to the breaker and either the green or white > bar it reads 110. when i do the same with the black wire on the other > 50 amp breaker the same happens. I took the little plastic thing that > holds the two 50 amp breakers together off and when i flip the top > one the plugs that have lamps plugged into them go out, when I flip > the other one the heater in the bathroom goes off. So both are doing > something. Also, the gauges in the upper dash labeled ac voltage are > reading:leg 1 120, leg 2 120. the gauges labeled ac amperage leg 1 > reads zero and leg 2 reads 10. I looked for gfi plugs and found none. > should I take the switch apart that I use to select genarator 30 or > 50 amp? I tried to work it with the genarator and the same problem > was there. Im so confused. > Robert Rahn > 88 pt 40 > Kalispell, Mt. > > <!-- #ygrp-mlmsg {font-size:13px;font-family:arial,helvetica,clean,sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial,helvetica,clean,sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0; } #ygrp-tpmsgs{ font-family:Arial; clear:both; } #ygrp-vitnav{ padding-top:10px; font-family:Verdana; font-size:77%; margin:0; } #ygrp-vitnav a{ padding:0 1px; } #ygrp-actbar{ clear:both; margin:25px 0; white-space:nowrap; color:#666; text-align:right; } #ygrp-actbar .left{ float:left; white-space:nowrap; } .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana; font-size:77%; padding:15px 0; } #ygrp-ft{ font-family:verdana; font-size:77%; border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px; } #ygrp-vital{ background-color:#e0ecee; margin-bottom:20px; padding:2px 0 8px 8px; } #ygrp-vital #vithd{ font-size:77%; font-family:Verdana; font-weight:bold; color:#333; text-transform:uppercase; } #ygrp-vital ul{ padding:0; margin:2px 0; } #ygrp-vital ul li{ list-style-type:none; clear:both; border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold; color:#ff7900; float:right; width:2em; text-align:right; padding-right:.5em; } #ygrp-vital ul li .cat{ font-weight:bold; } #ygrp-vital a { text-decoration:none; } #ygrp-vital a:hover{ text-decoration:underline; } #ygrp-sponsor #hd{ color:#999; font-size:77%; } #ygrp-sponsor #ov{ padding:6px 13px; background-color:#e0ecee; margin-bottom:20px; } #ygrp-sponsor #ov ul{ padding:0 0 0 8px; margin:0; } #ygrp-sponsor #ov li{ list-style-type:square; padding:6px 0; font-size:77%; } #ygrp-sponsor #ov li a{ text-decoration:none; font-size:130%; } #ygrp-sponsor #nc { background-color:#eee; margin-bottom:20px; padding:0 8px; } #ygrp-sponsor .ad{ padding:8px 0; } #ygrp-sponsor .ad #hd1{ font-family:Arial; font-weight:bold; color:#628c2a; font-size:100%; line-height:122%; } #ygrp-sponsor .ad a{ text-decoration:none; } #ygrp-sponsor .ad a:hover{ text-decoration:underline; } #ygrp-sponsor .ad p{ margin:0; } o {font-size:0;} .MsoNormal { margin:0 0 0 0; } #ygrp-text tt{ font-size:120%; } blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
02-09-2007, 19:02
I'm coming in late here. But what exactly is not working? Is the top switch
overhead switched on? (or maybe an 88 doesn't do it that way). Just some thoughts I haven't seen mentioned. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 09, 2007 10:03 PM Subject: Re: [WanderlodgeForum] update power problem observations Robert, If I follow what you described and what you tested, you are good to go in the circuit breaker panel. Removing the little plastic thing and flipping the breakers independently...tuning off the breakers should turn off those items connected to it...all seems good. Amperage registered on one leg and not the other...depends on the coach load demand and how the coach is wired. Very possible one leg would be zero while the other has a power demand on it. The reading of 110 & 120 volts in each leg tells me the legs are receiving power. Our '87 coach does not have GFIs and perhaps yours does not as well. Do not take the gen/shore switch apart until we hear more from others perhaps more familiar with doing so and testing same. My only other suggestion at this time is to unplug the shore cord, start the gen., be sure the switch is set to gen., reset all the breakers in the 110V control panel, and see what happens. Good luck. Curt Sprenger 198 PT38 8V92 "MacAttach Racing Anaheim Hills, CA Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Robert & Teri Rahn wrote: > okay, first off, I am confused about electricity. There are four big > wires a big red one that goes to one of the 50 amp breakers, a black > one that goes to the other, a white that goes to the bar with all the > other little white ones and a green that goes to the other side with > all the bare copper ones. I checked with my test light that lights > for 110 and another light for 220, and when i touched the place where > the red wire connects to the breaker and either the green or white > bar it reads 110. when i do the same with the black wire on the other > 50 amp breaker the same happens. I took the little plastic thing that > holds the two 50 amp breakers together off and when i flip the top > one the plugs that have lamps plugged into them go out, when I flip > the other one the heater in the bathroom goes off. So both are doing > something. Also, the gauges in the upper dash labeled ac voltage are > reading:leg 1 120, leg 2 120. the gauges labeled ac amperage leg 1 > reads zero and leg 2 reads 10. I looked for gfi plugs and found none. > should I take the switch apart that I use to select genarator 30 or > 50 amp? I tried to work it with the genarator and the same problem > was there. Im so confused. > Robert Rahn > 88 pt 40 > Kalispell, Mt. > > [Non-text portions of this message have been removed] |
02-09-2007, 19:13
I guess that wasn't very clear - I do mean the 3 air/heat switches above the
drivers head. The top one should be for the front of the coach. Sorry about that. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 09, 2007 11:02 PM Subject: Re: [WanderlodgeForum] update power problem observations I'm coming in late here. But what exactly is not working? Is the top switch overhead switched on? (or maybe an 88 doesn't do it that way). Just some thoughts I haven't seen mentioned. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 09, 2007 10:03 PM Subject: Re: [WanderlodgeForum] update power problem observations Robert, If I follow what you described and what you tested, you are good to go in the circuit breaker panel. Removing the little plastic thing and flipping the breakers independently...tuning off the breakers should turn off those items connected to it...all seems good. Amperage registered on one leg and not the other...depends on the coach load demand and how the coach is wired. Very possible one leg would be zero while the other has a power demand on it. The reading of 110 & 120 volts in each leg tells me the legs are receiving power. Our '87 coach does not have GFIs and perhaps yours does not as well. Do not take the gen/shore switch apart until we hear more from others perhaps more familiar with doing so and testing same. My only other suggestion at this time is to unplug the shore cord, start the gen., be sure the switch is set to gen., reset all the breakers in the 110V control panel, and see what happens. Good luck. Curt Sprenger 198 PT38 8V92 "MacAttach Racing Anaheim Hills, CA Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Robert & Teri Rahn wrote: > okay, first off, I am confused about electricity. There are four big > wires a big red one that goes to one of the 50 amp breakers, a black > one that goes to the other, a white that goes to the bar with all the > other little white ones and a green that goes to the other side with > all the bare copper ones. I checked with my test light that lights > for 110 and another light for 220, and when i touched the place where > the red wire connects to the breaker and either the green or white > bar it reads 110. when i do the same with the black wire on the other > 50 amp breaker the same happens. I took the little plastic thing that > holds the two 50 amp breakers together off and when i flip the top > one the plugs that have lamps plugged into them go out, when I flip > the other one the heater in the bathroom goes off. So both are doing > something. Also, the gauges in the upper dash labeled ac voltage are > reading:leg 1 120, leg 2 120. the gauges labeled ac amperage leg 1 > reads zero and leg 2 reads 10. I looked for gfi plugs and found none. > should I take the switch apart that I use to select genarator 30 or > 50 amp? I tried to work it with the genarator and the same problem > was there. Im so confused. > Robert Rahn > 88 pt 40 > Kalispell, Mt. > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
02-10-2007, 00:03
Robert,
I don't know if this could be it, but on our coach the bottom left breaker in the panel is a GFI breaker. If it is tripped (which is not always apparent, without cycling it) one of my legs will show nothing on the front gages. Tom Sorrentino 1987PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > I guess that wasn't very clear - I do mean the 3 air/heat switches above the drivers head. The top one should be for the front of the coach. Sorry about that. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: Richard Hayden > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 09, 2007 11:02 PM > Subject: Re: [WanderlodgeForum] update power problem observations > > > I'm coming in late here. But what exactly is not working? Is the top switch overhead switched on? (or maybe an 88 doesn't do it that way). Just some thoughts I haven't seen mentioned. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 09, 2007 10:03 PM > Subject: Re: [WanderlodgeForum] update power problem observations > > Robert, > > If I follow what you described and what you tested, you are good to go > in the circuit breaker panel. > > Removing the little plastic thing and flipping the breakers > independently...tuning off the breakers should turn off those items > connected to it...all seems good. > > Amperage registered on one leg and not the other...depends on the coach > load demand and how the coach is wired. Very possible one leg would be > zero while the other has a power demand on it. > > The reading of 110 & 120 volts in each leg tells me the legs are > receiving power. > > Our '87 coach does not have GFIs and perhaps yours does not as well. > > Do not take the gen/shore switch apart until we hear more from others > perhaps more familiar with doing so and testing same. > > My only other suggestion at this time is to unplug the shore cord, start > the gen., be sure the switch is set to gen., reset all the breakers in > the 110V control panel, and see what happens. > > Good luck. > > Curt Sprenger > 198 PT38 8V92 "MacAttach Racing > Anaheim Hills, CA > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > Robert & Teri Rahn wrote: > > > okay, first off, I am confused about electricity. There are four big > > wires a big red one that goes to one of the 50 amp breakers, a black > > one that goes to the other, a white that goes to the bar with all the > > other little white ones and a green that goes to the other side with > > all the bare copper ones. I checked with my test light that lights > > for 110 and another light for 220, and when i touched the place where > > the red wire connects to the breaker and either the green or white > > bar it reads 110. when i do the same with the black wire on the other > > 50 amp breaker the same happens. I took the little plastic thing that > > holds the two 50 amp breakers together off and when i flip the top > > one the plugs that have lamps plugged into them go out, when I flip > > the other one the heater in the bathroom goes off. So both are doing > > something. Also, the gauges in the upper dash labeled ac voltage are > > reading:leg 1 120, leg 2 120. the gauges labeled ac amperage leg 1 > > reads zero and leg 2 reads 10. I looked for gfi plugs and found none. > > should I take the switch apart that I use to select genarator 30 or > > 50 amp? I tried to work it with the genarator and the same problem > > was there. Im so confused. > > Robert Rahn > > 88 pt 40 > > Kalispell, Mt. > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
02-10-2007, 01:31
Robert, did you sell the coach yet? Curt may have stumbled on the
problem or a problem. 1- terms necessary to explain technical parts like " little plastic thingy" reveal that we may be giving advice that put you in danger. 2.- if you find a GFI receptical, someone may have changed some electrical wiring in the coach. 50HzBill often warns us that the coach is or is not grounded in a particular way.?????? and the factory wire grounding must be maintained. I would advise only flipping switches on and off and remember not to touch anything conductive. The inverter and generator produce the same type of deadly power that comes from Edison. Un plugging the bus from land power and using the other power sources does not protect or limit the risk of shock. This is the situation where the hire of a good RV tech and not a household electric tech would be a wise choice. GregoryO'Connor 94ptRomolandCa--- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Robert, > > If I follow what you described and what you tested, you are good to go > in the circuit breaker panel. > > Removing the little plastic thing and flipping the breakers > independently...tuning off the breakers should turn off those items > connected to it...all seems good. > > Amperage registered on one leg and not the other...depends on the coach > load demand and how the coach is wired. Very possible one leg would be > zero while the other has a power demand on it. > > The reading of 110 & 120 volts in each leg tells me the legs are > receiving power. > > Our '87 coach does not have GFIs and perhaps yours does not as well. > > Do not take the gen/shore switch apart until we hear more from others > perhaps more familiar with doing so and testing same. > > My only other suggestion at this time is to unplug the shore cord, start > the gen., be sure the switch is set to gen., reset all the breakers in > the 110V control panel, and see what happens. > > Good luck. > > Curt Sprenger > 198 PT38 8V92 "MacAttach Racing > Anaheim Hills, CA > > > > > > > > > > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Robert & Teri Rahn wrote: > > > okay, first off, I am confused about electricity. There are four big > > wires a big red one that goes to one of the 50 amp breakers, a black > > one that goes to the other, a white that goes to the bar with all the > > other little white ones and a green that goes to the other side with > > all the bare copper ones. I checked with my test light that lights > > for 110 and another light for 220, and when i touched the place where > > the red wire connects to the breaker and either the green or white > > bar it reads 110. when i do the same with the black wire on the other > > 50 amp breaker the same happens. I took the little plastic thing that > > holds the two 50 amp breakers together off and when i flip the top > > one the plugs that have lamps plugged into them go out, when I flip > > the other one the heater in the bathroom goes off. So both are doing > > something. Also, the gauges in the upper dash labeled ac voltage are > > reading:leg 1 120, leg 2 120. the gauges labeled ac amperage leg 1 > > reads zero and leg 2 reads 10. I looked for gfi plugs and found none. > > should I take the switch apart that I use to select genarator 30 or > > 50 amp? I tried to work it with the genarator and the same problem > > was there. Im so confused. > > Robert Rahn > > 88 pt 40 > > Kalispell, Mt. > > > > > |
