Carpet replacement question
02-22-2007, 09:59
With the weather getting nice it's making me feel like getting out and
working on my Bird. My next project is some interior updating. I
just dropped my couch off to be recovered. I have a couple of carpet
questions for anyone that might have some experience here.
1. Has anyone used something besides a "plush" carpet (like oem)?
I've seen some nice fancy sculpted carpets that are a very low and
tight pile. ...Probably not a problem for the floors, but I haven't
done much carpet work and i'm concerned that that might be a nightmare
trying to get all the doghouse corners to look good. The plush fibers
cover up a lot of stuff.
2. Any other considerations for carpets? Like weight, firmness of
backing (for bending around corners).
3. What works well for making the carpet adhere? (Like the doghouse
and various vertical kick panels?
Thanks and let's keep our fingers crossed for spring soon!
Alan
87FC35
02-22-2007, 10:27
Alan, Ernie Eckberg is our carpet guru. Am sure he can help you. He
used a low cut sculptured carpet in my PT. No dog house to contend with
but a few wall surfaces etc that were covered with the carpet.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
> Alan
> 87FC35
02-22-2007, 11:30
Alan, I would stay away from berber on your dog house, as when you bend that
carpet around all the edges, the secondary back will grin at you. Contact cement
is the only thing that works well on the doghouse. It is best to remove the
doghouse and carpet it on a table- unless you like to be a contortionist. While
you have that baby out, you can reinsulate it- if the old is bad. There are 2
set screws on the lid hinges that need to be removed in order for the lid to
come off. A good 3/8 8 pound density pad is a must for the floor.Good luck
83PT40
Livingston,Montana- carpet business for 35 years
Sent: Thursday, February 22, 2007 2:59 PM
Subject: [WanderlodgeForum] Carpet replacement question
Alan
87FC35
02-22-2007, 15:53
Ernie,
Thanks for the tips on the carpet. When are you coming back to Texas?
You're missing out on some great weather. Smile
Thanks,
Alan
02-23-2007, 01:08
Hi Alan, will be back in the late fall. Brenda and I would like to make the RIV
this year. Can't afford Texas right now.
83PT40
Livingston,Montana
Sent: Thursday, February 22, 2007 8:53 PM
Subject: [WanderlodgeForum] Re: Carpet replacement question
Ernie,
Thanks,
Alan
02-23-2007, 03:46
As long as we're on the topic of flooring. I want to eventually put
in some tile or pergo type flooring in the entry/kitchen/fridge
areas. Any thoughts on the subject?
Keith
make the RIV this year. Can't afford Texas right now.
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Alan
> Ernie,
Texas?
> Thanks,
> Alan
02-23-2007, 08:24
Keith, that has been done on numerous coaches. The only thing we don't mess with
is ceramic tile.
83PT40
Livingston,Montana
Sent: Friday, February 23, 2007 8:46 AM
Keith
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Alan
> Ernie,
Texas?
> Thanks,
> Alan
02-23-2007, 08:54
So if I rip up the carpet will I find a standard issue wood floor?
And what about the kick boards in the wood floor area?
don't mess with is ceramic tile.
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Keith Strehle
put
> Keith
to
> > Ernie Ekberg
> > 83PT40
> > Livingston,Montana
> > From: Alan
> > Ernie,
> Texas?
> > Thanks,
> > Alan
02-23-2007, 09:04
Under the carpet and pad is 3/4 plywood over steel floor. The 6 inch carpet on
the side walls are covering steel. There is a plastic trim strip over the side
boards and carpet.
The whole project takes a lot of time. There are millions of staples the factory
and maybe subsequent flooring installers used to adhere the carpet and pad. If
you have had any water damage around your icemaker, you might have to install
some new wood.
83PT40
Livingston,Montana
Sent: Friday, February 23, 2007 1:54 PM
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Keith Strehle
put
> Keith
to
> > Ernie Ekberg
> > 83PT40
> > Livingston,Montana
> > From: Alan
> > Ernie,
> Texas?
> > Thanks,
> > Alan
02-23-2007, 17:05
Ernie...
What would you recommend for hard floors on a 78FC33?
I plan on switching from carpet to hard floors once the carpet gets bad.
The floor will need to stand up to the abuse our dogs put to it while
camping & boating ;-)
Todd Jones
Lincoln, NE.
"The Bus"
78FC33SB
We ended up with the name "The Bus" because it was an easy command for the
dogs......."get in the bus"
> carpet on the side walls are covering steel. There is a plastic trim strip
> over the side boards and carpet.
> factory and maybe subsequent flooring installers used to adhere the carpet
> and pad. If you have had any water damage around your icemaker, you might
> have to install some new wood.
> Ernie Ekberg
> 83PT40
> Livingston,Montana
> From: Keith Strehle
> > Ernie Ekberg
> > 83PT40
> > Livingston,Montana
> > From: Keith Strehle
> put
> > Keith
> to
> > > Ernie Ekberg
> > > 83PT40
> > > Livingston,Montana
> > > From: Alan
> > > Ernie,
> > Texas?
> > > Thanks,
> > > Alan
User(s) browsing this thread: 10 Guest(s)
