Carpet replacement question
02-24-2007, 01:58
Todd-the laminate floors work well. That stuff doesn't scratch like my real wood
floor in my coach. I am parked on dirt and the little sand pebbles get in my shoes- going to put a rug over my wood till I leave here. Ernie Ekberg 83PT40 Livingston,Montana ----- Original Message ----- From: Todd Jones To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 23, 2007 10:05 PM Subject: Re: [WanderlodgeForum] Re: Carpet replacement question Ernie... What would you recommend for hard floors on a 78FC33? I plan on switching from carpet to hard floors once the carpet gets bad. The floor will need to stand up to the abuse our dogs put to it while camping & boating ;-) Todd Jones Lincoln, NE. "The Bus" 78FC33SB We ended up with the name "The Bus" because it was an easy command for the dogs......."get in the bus" . On 2/23/07, ernieekberg@... > > Under the carpet and pad is 3/4 plywood over steel floor. The 6 inch > carpet on the side walls are covering steel. There is a plastic trim strip > over the side boards and carpet. > The whole project takes a lot of time. There are millions of staples the > factory and maybe subsequent flooring installers used to adhere the carpet > and pad. If you have had any water damage around your icemaker, you might > have to install some new wood. > Ernie Ekberg > 83PT40 > Livingston,Montana > ----- Original Message ----- > From: Keith Strehle > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 23, 2007 1:54 PM > Subject: [WanderlodgeForum] Re: Carpet replacement question > > So if I rip up the carpet will I find a standard issue wood floor? > And what about the kick boards in the wood floor area? > > --- In WanderlodgeForum@yahoogroups.com > > > > > Keith, that has been done on numerous coaches. The only thing we > don't mess with is ceramic tile. > > Ernie Ekberg > > 83PT40 > > Livingston,Montana > > ----- Original Message ----- > > From: Keith Strehle > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, February 23, 2007 8:46 AM > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > As long as we're on the topic of flooring. I want to eventually > put > > in some tile or pergo type flooring in the entry/kitchen/fridge > > areas. Any thoughts on the subject? > > > > Keith > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > Hi Alan, will be back in the late fall. Brenda and I would like > to > > make the RIV this year. Can't afford Texas right now. > > > Ernie Ekberg > > > 83PT40 > > > Livingston,Montana > > > ----- Original Message ----- > > > From: Alan > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Thursday, February 22, 2007 8:53 PM > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > Ernie, > > > > > > Thanks for the tips on the carpet. When are you coming back to > > Texas? > > > You're missing out on some great weather. > > > > > > Thanks, > > > Alan > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
02-24-2007, 05:27
Todd,
You might check this product out also, it's called Amtico. (http://www.amtico.com) You can find a local retailer at this web site. It's some newer stuff that looks very much like the real thing. They produce both wood and tile/marble imitation materials. I'm getting ready to redo my floors and i'm going to put one of the marble products in mine. Good luck, Alan 87FC35 |
02-24-2007, 06:29
Todd, when Ernie replaced all of our flooring last year, we used a
Mannington product. 25 year warranty. Really tough against dirt & small pebbles as Ernie says. Doesn't show scratches. Lots of color & pattern choices. Would use it again. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T ernieekberg@... wrote: > Todd-the laminate floors work well. That stuff doesn't scratch like my > real wood floor in my coach. I am parked on dirt and the little sand > pebbles get in my shoes- going to put a rug over my wood till I leave > here. > Ernie Ekberg > 83PT40 > Livingston,Montana > ----- Original Message ----- > From: Todd Jones > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, February 23, 2007 10:05 PM > Subject: Re: [WanderlodgeForum] Re: Carpet replacement question > > Ernie... > What would you recommend for hard floors on a 78FC33? > I plan on switching from carpet to hard floors once the carpet gets bad. > The floor will need to stand up to the abuse our dogs put to it while > camping & boating ;-) > > Todd Jones > Lincoln, NE. > "The Bus" > 78FC33SB > > We ended up with the name "The Bus" because it was an easy command for the > dogs......."get in the bus" > > . > > On 2/23/07, ernieekberg@... > > > > > Under the carpet and pad is 3/4 plywood over steel floor. The 6 inch > > carpet on the side walls are covering steel. There is a plastic trim > strip > > over the side boards and carpet. > > The whole project takes a lot of time. There are millions of staples the > > factory and maybe subsequent flooring installers used to adhere the > carpet > > and pad. If you have had any water damage around your icemaker, you > might > > have to install some new wood. > > Ernie Ekberg > > 83PT40 > > Livingston,Montana > > ----- Original Message ----- > > From: Keith Strehle > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Friday, February 23, 2007 1:54 PM > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > So if I rip up the carpet will I find a standard issue wood floor? > > And what about the kick boards in the wood floor area? > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > Keith, that has been done on numerous coaches. The only thing we > > don't mess with is ceramic tile. > > > Ernie Ekberg > > > 83PT40 > > > Livingston,Montana > > > ----- Original Message ----- > > > From: Keith Strehle > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Friday, February 23, 2007 8:46 AM > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > As long as we're on the topic of flooring. I want to eventually > > put > > > in some tile or pergo type flooring in the entry/kitchen/fridge > > > areas. Any thoughts on the subject? > > > > > > Keith > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > Hi Alan, will be back in the late fall. Brenda and I would like > > to > > > make the RIV this year. Can't afford Texas right now. > > > > Ernie Ekberg > > > > 83PT40 > > > > Livingston,Montana > > > > ----- Original Message ----- > > > > From: Alan > > > > To: WanderlodgeForum@yahoogroups.com > > > > > Sent: Thursday, February 22, 2007 8:53 PM > > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > > > > Ernie, > > > > > > > > Thanks for the tips on the carpet. When are you coming back to > > > Texas? > > > > You're missing out on some great weather. > > > > > > > > Thanks, > > > > Alan > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
02-24-2007, 07:44
IMHO - I don't think that the carpet ever gets bad in these coaches. People
just get tired of the color and want something different. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Todd Jones To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 23, 2007 9:05 PM Subject: Re: [WanderlodgeForum] Re: Carpet replacement question Ernie... What would you recommend for hard floors on a 78FC33? I plan on switching from carpet to hard floors once the carpet gets bad. The floor will need to stand up to the abuse our dogs put to it while camping & boating ;-) Todd Jones Lincoln, NE. "The Bus" 78FC33SB We ended up with the name "The Bus" because it was an easy command for the dogs......."get in the bus" . On 2/23/07, ernieekberg@... > > Under the carpet and pad is 3/4 plywood over steel floor. The 6 inch > carpet on the side walls are covering steel. There is a plastic trim strip > over the side boards and carpet. > The whole project takes a lot of time. There are millions of staples the > factory and maybe subsequent flooring installers used to adhere the carpet > and pad. If you have had any water damage around your icemaker, you might > have to install some new wood. > Ernie Ekberg > 83PT40 > Livingston,Montana > ----- Original Message ----- > From: Keith Strehle > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 23, 2007 1:54 PM > Subject: [WanderlodgeForum] Re: Carpet replacement question > > So if I rip up the carpet will I find a standard issue wood floor? > And what about the kick boards in the wood floor area? > > --- In WanderlodgeForum@yahoogroups.com > > > > > Keith, that has been done on numerous coaches. The only thing we > don't mess with is ceramic tile. > > Ernie Ekberg > > 83PT40 > > Livingston,Montana > > ----- Original Message ----- > > From: Keith Strehle > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, February 23, 2007 8:46 AM > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > As long as we're on the topic of flooring. I want to eventually > put > > in some tile or pergo type flooring in the entry/kitchen/fridge > > areas. Any thoughts on the subject? > > > > Keith > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > Hi Alan, will be back in the late fall. Brenda and I would like > to > > make the RIV this year. Can't afford Texas right now. > > > Ernie Ekberg > > > 83PT40 > > > Livingston,Montana > > > ----- Original Message ----- > > > From: Alan > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Thursday, February 22, 2007 8:53 PM > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > Ernie, > > > > > > Thanks for the tips on the carpet. When are you coming back to > > Texas? > > > You're missing out on some great weather. > > > > > > Thanks, > > > Alan > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
02-24-2007, 08:49
Not always true Richard. There are particular spots that are prone to
excessive wear, making the replacement necessary. I have that condition now, where the carpet terminates at the tile floor in the galley. The carpet has frayed badly there. R.E. (Ron) Marabito, Dalllas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > IMHO - I don't think that the carpet ever gets bad in these coaches. People just get tired of the color and want something different. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: Todd Jones > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 23, 2007 9:05 PM > Subject: Re: [WanderlodgeForum] Re: Carpet replacement question > > > Ernie... > What would you recommend for hard floors on a 78FC33? > I plan on switching from carpet to hard floors once the carpet gets bad. > The floor will need to stand up to the abuse our dogs put to it while > camping & boating ;-) > > Todd Jones > Lincoln, NE. > "The Bus" > 78FC33SB > > We ended up with the name "The Bus" because it was an easy command for the > dogs......."get in the bus" > > . > > On 2/23/07, ernieekberg@... > > > > Under the carpet and pad is 3/4 plywood over steel floor. The 6 inch > > carpet on the side walls are covering steel. There is a plastic trim strip > > over the side boards and carpet. > > The whole project takes a lot of time. There are millions of staples the > > factory and maybe subsequent flooring installers used to adhere the carpet > > and pad. If you have had any water damage around your icemaker, you might > > have to install some new wood. > > Ernie Ekberg > > 83PT40 > > Livingston,Montana > > ----- Original Message ----- > > From: Keith Strehle > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, February 23, 2007 1:54 PM > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > So if I rip up the carpet will I find a standard issue wood floor? > > And what about the kick boards in the wood floor area? > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > Keith, that has been done on numerous coaches. The only thing we > > don't mess with is ceramic tile. > > > Ernie Ekberg > > > 83PT40 > > > Livingston,Montana > > > ----- Original Message ----- > > > From: Keith Strehle > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Friday, February 23, 2007 8:46 AM > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > As long as we're on the topic of flooring. I want to eventually > > put > > > in some tile or pergo type flooring in the entry/kitchen/fridge > > > areas. Any thoughts on the subject? > > > > > > Keith > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > Hi Alan, will be back in the late fall. Brenda and I would like > > to > > > make the RIV this year. Can't afford Texas right now. > > > > Ernie Ekberg > > > > 83PT40 > > > > Livingston,Montana > > > > ----- Original Message ----- > > > > From: Alan > > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Thursday, February 22, 2007 8:53 PM > > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > > > > Ernie, > > > > > > > > Thanks for the tips on the carpet. When are you coming back to > > > Texas? > > > > You're missing out on some great weather. > > > > > > > > Thanks, > > > > Alan > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
02-24-2007, 09:53
Wow Ron. I've seen that in the house but not in a BB WL. But, my point was
that BB put an excellent grade of carpet in these coaches. On our last coach, '81FC31'SB it was kind of a orangeish redish and we always wanted to change it but didn't. Someone before me had painted it with the standard BB blue-silver-dark gray and the carpet didn't match. Oh well. The new owner wasn't bothered and must be happy since I've never heard from him. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Saturday, February 24, 2007 12:49 PM Subject: [WanderlodgeForum] Re: Carpet replacement question Not always true Richard. There are particular spots that are prone to excessive wear, making the replacement necessary. I have that condition now, where the carpet terminates at the tile floor in the galley. The carpet has frayed badly there. R.E. (Ron) Marabito, Dalllas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com "Richard Hayden" > > IMHO - I don't think that the carpet ever gets bad in these coaches. People just get tired of the color and want something different. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > ----- Original Message ----- > From: Todd Jones > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, February 23, 2007 9:05 PM > Subject: Re: [WanderlodgeForum] Re: Carpet replacement question > > > Ernie... > What would you recommend for hard floors on a 78FC33? > I plan on switching from carpet to hard floors once the carpet gets bad. > The floor will need to stand up to the abuse our dogs put to it while > camping & boating ;-) > > Todd Jones > Lincoln, NE. > "The Bus" > 78FC33SB > > We ended up with the name "The Bus" because it was an easy command for the > dogs......."get in the bus" > > . > > On 2/23/07, ernieekberg@... > > > > Under the carpet and pad is 3/4 plywood over steel floor. The 6 inch > > carpet on the side walls are covering steel. There is a plastic trim strip > > over the side boards and carpet. > > The whole project takes a lot of time. There are millions of staples the > > factory and maybe subsequent flooring installers used to adhere the carpet > > and pad. If you have had any water damage around your icemaker, you might > > have to install some new wood. > > Ernie Ekberg > > 83PT40 > > Livingston,Montana > > ----- Original Message ----- > > From: Keith Strehle > > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, February 23, 2007 1:54 PM > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > So if I rip up the carpet will I find a standard issue wood floor? > > And what about the kick boards in the wood floor area? > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > Keith, that has been done on numerous coaches. The only thing we > > don't mess with is ceramic tile. > > > Ernie Ekberg > > > 83PT40 > > > Livingston,Montana > > > ----- Original Message ----- > > > From: Keith Strehle > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Friday, February 23, 2007 8:46 AM > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > As long as we're on the topic of flooring. I want to eventually > > put > > > in some tile or pergo type flooring in the entry/kitchen/fridge > > > areas. Any thoughts on the subject? > > > > > > Keith > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > Hi Alan, will be back in the late fall. Brenda and I would like > > to > > > make the RIV this year. Can't afford Texas right now. > > > > Ernie Ekberg > > > > 83PT40 > > > > Livingston,Montana > > > > ----- Original Message ----- > > > > From: Alan > > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Thursday, February 22, 2007 8:53 PM > > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > > > > Ernie, > > > > > > > > Thanks for the tips on the carpet. When are you coming back to > > > Texas? > > > > You're missing out on some great weather. > > > > > > > > Thanks, > > > > Alan > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
02-24-2007, 11:25
Ernie, Alan, Terry ...........Thanks
Todd Jones Lincoln,NE. "The Bus" 78FC33 . On 2/24/07, Richard Hayden > > Wow Ron. I've seen that in the house but not in a BB WL. But, my point > was that BB put an excellent grade of carpet in these coaches. On our last > coach, '81FC31'SB it was kind of a orangeish redish and we always wanted to > change it but didn't. Someone before me had painted it with the standard BB > blue-silver-dark gray and the carpet didn't match. Oh well. The new owner > wasn't bothered and must be happy since I've never heard from him. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > > > Sent: Saturday, February 24, 2007 12:49 PM > Subject: [WanderlodgeForum] Re: Carpet replacement question > > Not always true Richard. There are particular spots that are prone to > excessive wear, making the replacement necessary. I have that > condition now, where the carpet terminates at the tile floor in the > galley. The carpet has frayed badly there. > > R.E. (Ron) Marabito, Dalllas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com > > "Richard Hayden" > > > > > IMHO - I don't think that the carpet ever gets bad in these coaches. > People just get tired of the color and want something different. > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > > From: Todd Jones > > To: > WanderlodgeForum@yahoogroups.com > > > > Sent: Friday, February 23, 2007 9:05 PM > > Subject: Re: [WanderlodgeForum] Re: Carpet replacement question > > > > > > Ernie... > > What would you recommend for hard floors on a 78FC33? > > I plan on switching from carpet to hard floors once the carpet > gets bad. > > The floor will need to stand up to the abuse our dogs put to it while > > camping & boating ;-) > > > > Todd Jones > > Lincoln, NE. > > "The Bus" > > 78FC33SB > > > > We ended up with the name "The Bus" because it was an easy command > for the > > dogs......."get in the bus" > > > > . > > > > On 2/23/07, ernieekberg@... > > > > > > > Under the carpet and pad is 3/4 plywood over steel floor. The 6 inch > > > carpet on the side walls are covering steel. There is a plastic > trim strip > > > over the side boards and carpet. > > > The whole project takes a lot of time. There are millions of > staples the > > > factory and maybe subsequent flooring installers used to adhere > the carpet > > > and pad. If you have had any water damage around your icemaker, > you might > > > have to install some new wood. > > > Ernie Ekberg > > > 83PT40 > > > Livingston,Montana > > > ----- Original Message ----- > > > From: Keith Strehle > > > To: > WanderlodgeForum@yahoogroups.com > > > > > Sent: Friday, February 23, 2007 1:54 PM > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > So if I rip up the carpet will I find a standard issue wood floor? > > > And what about the kick boards in the wood floor area? > > > > > > --- In > WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > Keith, that has been done on numerous coaches. The only thing we > > > don't mess with is ceramic tile. > > > > Ernie Ekberg > > > > 83PT40 > > > > Livingston,Montana > > > > ----- Original Message ----- > > > > From: Keith Strehle > > > > To: > WanderlodgeForum@yahoogroups.com > > > > > Sent: Friday, February 23, 2007 8:46 AM > > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > > > > As long as we're on the topic of flooring. I want to eventually > > > put > > > > in some tile or pergo type flooring in the entry/kitchen/fridge > > > > areas. Any thoughts on the subject? > > > > > > > > Keith > > > > > > > > --- In > WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > Hi Alan, will be back in the late fall. Brenda and I would like > > > to > > > > make the RIV this year. Can't afford Texas right now. > > > > > Ernie Ekberg > > > > > 83PT40 > > > > > Livingston,Montana > > > > > ----- Original Message ----- > > > > > From: Alan > > > > > To: > WanderlodgeForum@yahoogroups.com > > > > > > Sent: Thursday, February 22, 2007 8:53 PM > > > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > > > > > > > Ernie, > > > > > > > > > > Thanks for the tips on the carpet. When are you coming back to > > > > Texas? > > > > > You're missing out on some great weather. > > > > > > > > > > Thanks, > > > > > Alan > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed] |
02-24-2007, 17:27
Oh, It's good carpet, but I think the carpet work into the metal
edging was the problem. The balance of the carpet is fine. R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > Wow Ron. I've seen that in the house but not in a BB WL. But, my point was that BB put an excellent grade of carpet in these coaches. On our last coach, '81FC31'SB it was kind of a orangeish redish and we always wanted to change it but didn't. Someone before me had painted it with the standard BB blue-silver-dark gray and the carpet didn't match. Oh well. The new owner wasn't bothered and must be happy since I've never heard from him. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, February 24, 2007 12:49 PM > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > Not always true Richard. There are particular spots that are prone to > excessive wear, making the replacement necessary. I have that > condition now, where the carpet terminates at the tile floor in the > galley. The carpet has frayed badly there. > > R.E. (Ron) Marabito, Dalllas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com "Richard Hayden" > > > > > IMHO - I don't think that the carpet ever gets bad in these coaches. > People just get tired of the color and want something different. > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > > From: Todd Jones > > To: > WanderlodgeForum@yahoogroups.com > > Sent: Friday, February 23, 2007 9:05 PM > > Subject: Re: [WanderlodgeForum] Re: Carpet replacement question > > > > > > Ernie... > > What would you recommend for hard floors on a 78FC33? > > I plan on switching from carpet to hard floors once the carpet > gets bad. > > The floor will need to stand up to the abuse our dogs put to it while > > camping & boating ;-) > > > > Todd Jones > > Lincoln, NE. > > "The Bus" > > 78FC33SB > > > > We ended up with the name "The Bus" because it was an easy command > for the > > dogs......."get in the bus" > > > > . > > > > On 2/23/07, ernieekberg@ > > > > > > > Under the carpet and pad is 3/4 plywood over steel floor. The 6 inch > > > carpet on the side walls are covering steel. There is a plastic > trim strip > > > over the side boards and carpet. > > > The whole project takes a lot of time. There are millions of > staples the > > > factory and maybe subsequent flooring installers used to adhere > the carpet > > > and pad. If you have had any water damage around your icemaker, > you might > > > have to install some new wood. > > > Ernie Ekberg > > > 83PT40 > > > Livingston,Montana > > > ----- Original Message ----- > > > From: Keith Strehle > > > To: > WanderlodgeForum@yahoogroups.com > > > > Sent: Friday, February 23, 2007 1:54 PM > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > So if I rip up the carpet will I find a standard issue wood floor? > > > And what about the kick boards in the wood floor area? > > > > > > --- In > WanderlodgeForum@yahoogroups.com > > > > > > > > > > > Keith, that has been done on numerous coaches. The only thing we > > > don't mess with is ceramic tile. > > > > Ernie Ekberg > > > > 83PT40 > > > > Livingston,Montana > > > > ----- Original Message ----- > > > > From: Keith Strehle > > > > To: > WanderlodgeForum@yahoogroups.com > > > > Sent: Friday, February 23, 2007 8:46 AM > > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > > > > As long as we're on the topic of flooring. I want to eventually > > > put > > > > in some tile or pergo type flooring in the entry/kitchen/fridge > > > > areas. Any thoughts on the subject? > > > > > > > > Keith > > > > > > > > --- In > WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > Hi Alan, will be back in the late fall. Brenda and I would like > > > to > > > > make the RIV this year. Can't afford Texas right now. > > > > > Ernie Ekberg > > > > > 83PT40 > > > > > Livingston,Montana > > > > > ----- Original Message ----- > > > > > From: Alan > > > > > To: > WanderlodgeForum@yahoogroups.com > > > > > Sent: Thursday, February 22, 2007 8:53 PM > > > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > > > > > > > Ernie, > > > > > > > > > > Thanks for the tips on the carpet. When are you coming back to > > > > Texas? > > > > > You're missing out on some great weather. > > > > > > > > > > Thanks, > > > > > Alan > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > |
02-25-2007, 03:08
Having had a recent leak to my toilet (fresh water side thankfully),
this weekend I pulled the toilet out for repairs and in doing so removed the carpet to find the floor covered with linoleum. A few months ago I pulled the carpet off the face of my entry steps to find stainless steel. I'll not replace the carpet in these areas. I'm one that doesn't like the color of our carpet but it is of such good quality and in such great shape I can't bring myself to remove the rest of it yet, but then it's only 22 years old! Ron, No. California 85PT36 --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > IMHO - I don't think that the carpet ever gets bad in these coaches. People just get tired of the color and want something different. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA |
02-25-2007, 04:19
I'll go with not only excessive wear, but it gets to the point where
the dirt than can't be extracted during cleaning (but sure can get wet) added to the slow decomposition of the carpet and pad materials, you just can't get a fresh clean smelling coach anymore. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > Not always true Richard. There are particular spots that are prone to > excessive wear, making the replacement necessary. I have that > condition now, where the carpet terminates at the tile floor in the > galley. The carpet has frayed badly there. > > R.E. (Ron) Marabito, Dalllas, TX 92WB40 > > > --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > > > > IMHO - I don't think that the carpet ever gets bad in these coaches. > People just get tired of the color and want something different. > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > > From: Todd Jones > > To: > WanderlodgeForum@yahoogroups.com > > Sent: Friday, February 23, 2007 9:05 PM > > Subject: Re: [WanderlodgeForum] Re: Carpet replacement question > > > > > > Ernie... > > What would you recommend for hard floors on a 78FC33? > > I plan on switching from carpet to hard floors once the carpet > gets bad. > > The floor will need to stand up to the abuse our dogs put to it while > > camping & boating ;-) > > > > Todd Jones > > Lincoln, NE. > > "The Bus" > > 78FC33SB > > > > We ended up with the name "The Bus" because it was an easy command > for the > > dogs......."get in the bus" > > > > . > > > > On 2/23/07, ernieekberg@ > > > > > > > Under the carpet and pad is 3/4 plywood over steel floor. The 6 inch > > > carpet on the side walls are covering steel. There is a plastic > trim strip > > > over the side boards and carpet. > > > The whole project takes a lot of time. There are millions of > staples the > > > factory and maybe subsequent flooring installers used to adhere > the carpet > > > and pad. If you have had any water damage around your icemaker, > you might > > > have to install some new wood. > > > Ernie Ekberg > > > 83PT40 > > > Livingston,Montana > > > ----- Original Message ----- > > > From: Keith Strehle > > > To: > WanderlodgeForum@yahoogroups.com > > > > Sent: Friday, February 23, 2007 1:54 PM > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > So if I rip up the carpet will I find a standard issue wood floor? > > > And what about the kick boards in the wood floor area? > > > > > > --- In > WanderlodgeForum@yahoogroups.com > > > > > > > > > > > Keith, that has been done on numerous coaches. The only thing we > > > don't mess with is ceramic tile. > > > > Ernie Ekberg > > > > 83PT40 > > > > Livingston,Montana > > > > ----- Original Message ----- > > > > From: Keith Strehle > > > > To: > WanderlodgeForum@yahoogroups.com > > > > Sent: Friday, February 23, 2007 8:46 AM > > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > > > > As long as we're on the topic of flooring. I want to eventually > > > put > > > > in some tile or pergo type flooring in the entry/kitchen/fridge > > > > areas. Any thoughts on the subject? > > > > > > > > Keith > > > > > > > > --- In > WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > Hi Alan, will be back in the late fall. Brenda and I would like > > > to > > > > make the RIV this year. Can't afford Texas right now. > > > > > Ernie Ekberg > > > > > 83PT40 > > > > > Livingston,Montana > > > > > ----- Original Message ----- > > > > > From: Alan > > > > > To: > WanderlodgeForum@yahoogroups.com > > > > > Sent: Thursday, February 22, 2007 8:53 PM > > > > > Subject: [WanderlodgeForum] Re: Carpet replacement question > > > > > > > > > > > > > > > Ernie, > > > > > > > > > > Thanks for the tips on the carpet. When are you coming back to > > > > Texas? > > > > > You're missing out on some great weather. > > > > > > > > > > Thanks, > > > > > Alan > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
