Generator Diode
03-14-2007, 08:31
Generator Diode
Ralph,
Can you tell me where to find the generator diode on my 86 PT40. Also what it looks like. Howard Truitt Camilla, Ga. 86 PT40 [Non-text portions of this message have been removed] |
03-14-2007, 10:14
Generator Diode
Howard:
The two most used places were in the compartment under the drivers seat or behind the front bumper usually attached to the front side of the wheel well. Some were also placed behind the curb side grill to the engine compartment and were in the lower rear corner but the strut that goes up. The '86 had construction prints that placed it in different places. You should find it in one of those three places though. It is about the size of a dime in diameter and about as thick as 4 or 5 dimes with a threaded stud on one side that is mounted to the mounting plate and is insulated, the other end has a solder lug and should be connected to a large silver solenoid mounted in the same proximity. Safe travels, Ralph and Charolette Fullenwider '84 FC35 Duncan, Oklahoma Ralph's RV Solutions At 03:31 PM 3/14/2007 -0400, you wrote: >Ralph, >Can you tell me where to find the generator diode on my 86 PT40. >Also what it looks like. >Howard Truitt >Camilla, Ga. >86 PT40 > |
