Rear main seal for a Cat 3208 (thanks)
04-28-2005, 15:19
Tom, thanks for the reply. Every tranny I've changed I've lifted back into
place by hand. I think I'll still file this one under big job:-) It is nice to know that it isn't super major though, I'd like to get it fixed. Aside from my wish to have a "perfect" Bird, I'm leaving an awful mess everywhere. Thank you also, Dave and Jon. I think I'll be calling thurs. to see how soon they can get me in. Al S. _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner Sent: Thursday, April 28, 2005 7:55 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Rear main seal for a Cat 3208 Al this is not what you asked for but it might help. Its really not a big job, if you have either a lift or a pair of OTC 20 ton tire jacks to lift the front end off the ground about 2'. The drive shaft needs to be dropped, tranny dip stick removed, levelling valve disconnected, tranny lines disconnected, shift parts etc. They will have to lift the front end of the coach up and then place some jack stands under the front frame and then let the tires down until the tranny will clear the front axel as the tranny is being pulled straight back. Worse part is the side bolts in the tranny. You need a nice long drive to get to them because of the clearance. We did it in about 13 manhours. Tom 1982 FC35 Vernon Center,NY In the beautiful Mohawk Valley At 07:34 PM 4/28/2005 -0700, you wrote: >really need to get this rear main seal fixed. Does anyone know of a good >place in Wash (preferably close to Seattle) they would entrust with a bigger >job like that? > > > >Thanks > >Al S. > >'81 31' FC > >Coos bay _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. [Non-text portions of this message have been removed] |
