Teleflex Gauges
03-21-2007, 05:43
Teleflex Gauges
I have had problems with some of my guages also. I called Teleflex
and was routed to a supplier in NJ Sealand Power Ind. Inc. Rich 1 800
225 0004
Jim Riordan
88 WBWL XXV
Stuart, Fl.
> Thanks Mike.
> Curt Sprenger
> 1987 PT38 8V92 "MacAttack Racing"
> Anaheim Hills, Calif.
> mbulriss wrote:
> > Teleflex gauge information is in the "Parts" Database on the
> > WanderlodgeForum home page.
> > Mike Bulriss
> > 1991 WB40 "Texas Minivan"
> > San Antonio, TX
> > , "pattypape"
> > wrote:
> > > Curt,
> > > Earl at BB has a reasonable price on gages, He also has the
Teleflex
> > > gage part numbers, the original gage with the silver trim is no
> > > longer available, But with care and a screw driver the bezel
can be
> > > removed and installed on the new gage to match the others in
the dash.
> > > A Silver felt permanent marker and a steady hand will touch up
> > > Silver trim on all gages very nicely.
> > > The sensors are most important and Joe at Teleflex tech support
is
> > > very helpful. He has the part numbers to match the sensors and
gages.
> > > There is a universal Stuart Warner sensor that is easily
available
> > > at parts stores that will match these gages.It has several
sizes of
> > > bushings to match all the standard thread sizes. Joe can help
with
> > > these part numbers.
> > > Teleflex also has a gage trouble shooting guide online.
> > > Sorry, but all my part numbers and website address are back in
> > > Michigan.
> > > I have not changed the angle of the gages , But new bulbs may
help
> > > Bill 88 FC
> > , Curt Sprenger
> > > wrote:
> > > > I need to replace the generator oil gauge and the coolant
gauge. The
> > > oil
> > > > gauge is shot, the coolant gauge needs a new sender. They are
> > > > Teleflex gauges. I've done research and have not found the
same
> > > > gauges/sending units. Also, would like to angle the gauges in
their
> > > > mounting so they are readable from the drivers seat. What
have others
> > > > done to remedy this?
> > > > Curt Sprenger
06-04-2007, 01:10
Teleflex Gauges
Minutes ago I ordered from Bluebird the following Teleflex
International Line gauges. Yellow C readings and White F readings over
black face.
Engine Oil Temperature and related sender
Generator Oil Pressure
Generator Water Temperature
All in stock, will ship today. Get them while they are hot.
Leroy Eckert
1990WB-40"Smoke N Mirrors"
Niceville, FL
