Radiator site glass
04-12-2007, 03:54
Radiator site glass
The site glass on my 87FC35 is leaking slightly. I assume that thing
screws out and has a rubber gasket behind it..?? I tried putting a rag around it and turning it with a wrench, but I was afraid of breaking it. How do these things work and what would I need to do to stop it from dripping? Thanks all, Alan Johnson 87FC35 |
04-12-2007, 04:19
Radiator site glass
Hey Alan, sorry I can't help answer your question. Where is the sight
glass is located? I have an 84FC and I'm trying to find out where the radiator overflow tube goes to? Keith 84FC --- In WanderlodgeForum@yahoogroups.com, "Alan" wrote: > > The site glass on my 87FC35 is leaking slightly. I assume that thing > screws out and has a rubber gasket behind it..?? I tried putting a > rag around it and turning it with a wrench, but I was afraid of > breaking it. > > How do these things work and what would I need to do to stop it from > dripping? > > Thanks all, > Alan Johnson > 87FC35 > |
04-12-2007, 04:53
Radiator site glass
Keith,
The overflow hose goes through a couple of brackets on the driver's side of the radiator and then points at the ground. David Hollis 84FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > I have an 84FC and I'm trying to find out where the > radiator overflow tube goes to? > > Keith > 84FC > > |
04-12-2007, 05:07
Radiator site glass
Thanks David. That's what I suspected. I just want to make sure I
don't overlook anything and have to deal with it later.... Keith 84FC --- In WanderlodgeForum@yahoogroups.com, "dthollis1961" > > Keith, > > The overflow hose goes through a couple of brackets on the driver's > side of the radiator and then points at the ground. > > David Hollis 84FC35 Springfield,IL > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > I have an 84FC and I'm trying to find out where the > > radiator overflow tube goes to? > > > > Keith > > 84FC > > > > > |
04-12-2007, 08:08
Radiator site glass
Yes, there is a gasket between the site glass on the radiator, and it
dose squire out. If you brake the glass, any large truck dealer will have this part, 25 dollars? D Thompson 89 fc 35 Cameron Wi |
