Installing new guage.
05-13-2007, 03:08
Extension 222
Jim Riordan
88 WBWL XXV
Stuartr, Fl.
Rob Robinson wrote:
Thanks Bob. Much appreciated
On 12/05/07, bloomas wrote:
> From: Rob Robinson
> Sent: Saturday, May 12, 2007 2:43 PM
> Subject: Re: [WanderlodgeForum] Re: Installing new
> guage.
> # for Teleflex
> 941 907 1000
> Bob Loomas 1985 PT 36
> Jim could you post that phone number for Teleflex
> On 12/05/07, jim riordan > wrote:
> > Thanks,
> > The new guage is not a 54438 Earl said the did not maske it anymore. He
> > sent me a "superseded" one the index numbers were different. He sent me
> a
> > new sensor it was for the old type guage it was reading 40% high. I
> called
> > Teleflex spoke to Joe Federsal (great help) he sent me the correct
> sensor
> > for the guage that I got from earl, everything seems to work now. This
> new
> > guage 9153278 is improved in that it first register point is at 140
> rather
> > than 100, top is 320 like the old one. the end result is that the gauge
> will
> > provide more accurate readings in the operational range than the old
> one. I
> > hope!
> > Jim RIordan
> > 88 WBWL XXV
> > Stuart, Fl.
> > pattypape > l.com>> wrote:
> > Jim,
> > I replaced both oil temp gages on our 88 FC ( 3208 oil and rear axle
> > temps) BB gage part number 54438, It is a Teleflex gage.
> > If this is your gage the temp sensor is a Stewart-Warner, part
> > number 280EEF . It is available at truck parts stores. It has
> > several threaded bushings for all thread sizes, One will match the
> > original threads. BB did not have the correct sensor.
> > Bill 88 FC Michigan
> > --- In
WanderlodgeForum@yahoogroups.com Forum%40yahoogroups.com>,
> > jim riordan
> > wrote:
> > > I have just replace my oil temp guage. I got it from BB and it is
> > indexed differently from the original one. I needed to get a new temp
> > sending switch also...
> > > Jim Riordan
> > > 88 WBWL XXV
> > > Stuart, Fl.
> > > "Ralph L. Fullenwider" wrote:
> > > Hi Art:
> > > **CAUTION** **CAUTION**
> > > Remove the 4 bottom out side covers of the lower dash. If the lower
> > dash
> > > has been out before then it should lift up from the front edge and
> > slip
> > > forward a little. If it has not been out before then on the left
> > side of
> > > the lower dash, under one of the blank covers, will be a screw that
> > has to
> > > come out.
> > > Now, with the lower dash panel slid forward, remove the cb mic from
> > the
> > > holder and take the long screw out that holds the cb mic holder.
> > Now the
> > > upper lower dash should be free on that side and if it has been
> > removed it
> > > will probably be free to tilt forward. If it has not been out
> > before then
> > > you need a looooong phillips screwdriver, hold the right side of
> > the upper
> > > lower dash out and reach in with the long phillips and un screw the
> > far
> > > left L bracket. In the bottom center of the upper lower dash, after
> > the
> > > lower panel is moved forward you should see a screw that needs to
> > come out
> > > as well. Now your upper lower dash panel should be free to tilt
> > forward.
> > > **CAUTION** Do NOT force it, if it won't come out enough to replace
> > the
> > > gauge, find what is holding it. I cannot stress **CAUTION** enough
> > on this.
> > > While your in there, remove the light sockets with the lamps from
> > the other
> > > gauges and clean or replace them.
> > > Your going to find a "rats nest" of wiring under and behind both
> > panels.
> > > Remember if you drill, spindle or pierce any of those panels, they
> > are shot
> > > and cannot be brought back. Use only holes provided for screws and
> > such.
> > > Good luck
> > > Safe travels,
> > > Ralph and Charolette Fullenwider
> > > 84FC35
> > > Ralph's RV Solutions, Duncan, Oklahoma
> > > At 06:44 PM 5/10/2007 +0000, you wrote:
> > > >I have recieved a new engine oil temp guage from the fellow I
> > bought
> > > >my coach from. Now to install it. The guage is on the verticle
> > part of
> > > >the dash panel.Has anyone been into that panel? Any advise will be
> > > >better than me going in there blind!
> > > >Art Weatherly
> > > >Riverside Ca.
> > > >'85 PT36
> > > Moody friends. Drama queens. Your life? Nope! - their life, your
> > story.
> > > Play Sims Stories at Yahoo! Games.
> > > [Non-text portions of this message have been removed]
> > Be a PS3 game guru.
> > Get your game face on with the latest PS3 news and previews at Yahoo!
> > Games.
> Rob, Sue & Merlin Robinson
> 94 WLWB
94 WLWB
Sick sense of humor? Visit Yahoo! TV's Comedy with an Edge to see what's on,
when.
05-13-2007, 03:19
Thanks for the site Bill
On 12/05/07, pattypape wrote:
> Rob , This is the web site
> http://www.teleflexmarine.com/cgi-bin/frameset2.cgi?
> site=gauges&type=us&link2=1047
> Teleflex Gage troubleshooting guide and the tech support phone number
> at the bottom of the page. Ask for Joe , he is very helpful.
> Bill 88 FC Michigan
> --- In WanderlodgeForum@yahoogroups.com,
> "Rob Robinson"
> > On 12/05/07, jim riordan wrote:
> > > Thanks,
> anymore. He
> sent me a
> I called
> correct sensor
> This new
> 140 rather
> gauge will
> old one. I
> > > hope!
> > > Jim RIordan
> > > 88 WBWL XXV
> > > Stuart, Fl.
> > > pattypape > wrote:
> > > Jim,
> axle
> > > Bill 88 FC Michigan
> > > --- In
> > 40yahoogroups.com>,
> > > jim riordan
> is
> temp
> > > > Jim Riordan
> > > > 88 WBWL XXV
> > > > Stuart, Fl.
> > > > Hi Art:
> lower
> > > dash
> and
> > > slip
> > > side of
> that
> > > has to
> > > > come out.
> from
> > > the
> > > Now the
> > > removed it
> > > before then
> > > the upper
> the
> > > far
> after
> > > the
> to
> > > come out
> > > forward.
> replace
> > > the
> enough
> > > on this.
> from
> > > the other
> > > panels.
> they
> > > are shot
> and
> > > such.
> > > > Good luck
> > > > Safe travels,
> > > > 84FC35
> > > bought
> > > part of
> will be
> > > > >Art Weatherly
> > > > >Riverside Ca.
> > > > >'85 PT36
> > > story.
> > > Be a PS3 game guru.
> Yahoo!
> > > Games.
> > 94 WLWB
94 WLWB
05-13-2007, 10:29
I got my new oil temp guage in today. I did indeed need a l-o-n-g phillips
screwdriver (acually a 14" extention for a 1/4 drive
ratchet set). Getting that inside screw out was the most time consuming part (
two trips tp K Mart for longer stuff).
So, it's done. Thanks for the guidance Ralph. Worked just like you said.
Art Weatherly
Riverside Ca
'85 PT36---- Original Message -----
Sent: Thursday, May 10, 2007 12:07 PM
Subject: [SPAM] Re: [WanderlodgeForum] Installing new guage.
Hi Art:
Remove the 4 bottom out side covers of the lower dash. If the lower dash
has been out before then it should lift up from the front edge and slip
forward a little. If it has not been out before then on the left side of
the lower dash, under one of the blank covers, will be a screw that has to
come out.
Now, with the lower dash panel slid forward, remove the cb mic from the
holder and take the long screw out that holds the cb mic holder. Now the
upper lower dash should be free on that side and if it has been removed it
will probably be free to tilt forward. If it has not been out before then
you need a looooong phillips screwdriver, hold the right side of the upper
lower dash out and reach in with the long phillips and un screw the far
left L bracket. In the bottom center of the upper lower dash, after the
lower panel is moved forward you should see a screw that needs to come out
as well. Now your upper lower dash panel should be free to tilt forward.
**CAUTION** Do NOT force it, if it won't come out enough to replace the
gauge, find what is holding it. I cannot stress **CAUTION** enough on this.
While your in there, remove the light sockets with the lamps from the other
Your going to find a "rats nest" of wiring under and behind both panels.
Remember if you drill, spindle or pierce any of those panels, they are shot
and cannot be brought back. Use only holes provided for screws and such.
Good luck
Safe travels,
84FC35
>I have recieved a new engine oil temp guage from the fellow I bought
>my coach from. Now to install it. The guage is on the verticle part of
>Art Weatherly
>Riverside Ca.
>'85 PT36
06-04-2007, 01:59
I want to pass along information I am receiving from Teleflex, Bluebird and
other suppliers I e-mailed over the weekend. Oil Temperature gauge 54438
Bluebird part number 3865334 shows to be in stock at Bluebird today. I will see
if the indexing is the same when I receive it. According to Teleflex this and
other Teleflex gauges Bluebird used are no longer in production and are no
longer available if Bluebird does not have inventory. I am replacing 3 flakey
gauges now while they are available.
Steve Birtles and I are searching for an instrument shop to rebuild the original
gauges. I would like to keep my bird dash looking original. In the long term
that may be difficult to do.
Leroy Eckert
1990WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Saturday, May 12, 2007 9:36 AM
Subject: [WanderlodgeForum] Re: Installing new guage.
Jim,
Yep, that is the correct gage, Teleflex # 9153278.
The BB# 54438 was still a good number, But
they shipped the updated 9153278 gage , Then the temp would read
really high, That is why there is a lot of confusion , when
replacing gages, the sensor must be replaced also.
I like the new scale for the oil temp,200 to 230
Not so good for the rear axle because, it only heats up to about
140 to 170. lowest part of the gage.
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, jim riordan
> Thanks,
anymore. He sent me a "superseded" one the index numbers were
different. He sent me a new sensor it was for the old type guage it
was reading 40% high. I called Teleflex spoke to Joe Federsal (great
help) he sent me the correct sensor for the guage that I got from
earl, everything seems to work now. This new guage 9153278 is
improved in that it first register point is at 140 rather than 100,
top is 320 like the old one. the end result is that the gauge will
one. I hope!
> Jim RIordan
> 88 WBWL XXV
> Stuart, Fl.
> pattypape wrote:
> Jim,
axle
> Bill 88 FC Michigan
temp
> > Jim Riordan
> > 88 WBWL XXV
> > Stuart, Fl.
> > Hi Art:
lower
> dash
> slip
> side of
that
> has to
> > come out.
from
> the
> Now the
> removed it
> before then
> the upper
> far
after
> the
> come out
> forward.
replace
> the
enough
> on this.
> the other
> panels.
they
> are shot
> such.
> > Good luck
> > Safe travels,
> > 84FC35
> bought
> part of
be
> > >Art Weatherly
> > >Riverside Ca.
> > >'85 PT36
> story.
> Be a PS3 game guru.
Yahoo! Games.
06-04-2007, 02:25
Leroy,
Contact Chuck at APT Instruments in Bloomington, Mn. about servicing Teleflex
gauges 952-881-7095.
Howard Truitt
Camilla, Ga.
86 PT40
> From: "Leroy Eckert"
> Date: 2007/06/04 Mon AM 09:59:05 EDT
> To:
> Subject: Re: [WanderlodgeForum] Re: Installing new guage.
original gauges. I would like to keep my bird dash looking original. In the
long term that may be difficult to do.
> Leroy Eckert
> Niceville, FL
> From: pattypape
> Jim,
> Bill 88 FC Michigan
> > Thanks,
> one. I hope!
> > Jim RIordan
> > 88 WBWL XXV
> > Stuart, Fl.
> > pattypape wrote:
> > Jim,
> axle
> > Bill 88 FC Michigan
> temp
> > > Jim Riordan
> > > 88 WBWL XXV
> > > Stuart, Fl.
> > > Hi Art:
> lower
> > dash
> and
> > slip
> > side of
> that
> > has to
> > > come out.
> from
> > the
> > Now the
> > removed it
> > before then
> > the upper
> the
> > far
> after
> > the
> > come out
> > forward.
> replace
> > the
> enough
> > on this.
> > the other
> > panels.
> they
> > are shot
> and
> > such.
> > > Good luck
> > > Safe travels,
> > > 84FC35
> > bought
> > part of
> be
> > > >Art Weatherly
> > > >Riverside Ca.
> > > >'85 PT36
> > story.
> > Be a PS3 game guru.
> Yahoo! Games.
06-04-2007, 02:27
Thanks Howard:
I'll give them a call.
Leroy Eckert
Niceville, FL
Sent: Monday, June 04, 2007 9:25 AM
Subject: [WanderlodgeForum] Installing new guage.
Leroy,
Howard Truitt
Camilla, Ga.
86 PT40
> To:
original gauges. I would like to keep my bird dash looking original. In the long
> Leroy Eckert
> Niceville, FL
> From: pattypape
> Jim,
> Bill 88 FC Michigan
> > Thanks,
> one. I hope!
> > Jim RIordan
> > 88 WBWL XXV
> > Stuart, Fl.
> > pattypape wrote:
> > Jim,
> axle
> > Bill 88 FC Michigan
> temp
> > > Jim Riordan
> > > 88 WBWL XXV
> > > Stuart, Fl.
> > > Hi Art:
> lower
> > dash
> and
> > slip
> > side of
> that
> > has to
> > > come out.
> from
> > the
> > Now the
> > removed it
> > before then
> > the upper
> the
> > far
> after
> > the
> > come out
> > forward.
> replace
> > the
> enough
> > on this.
> > the other
> > panels.
> they
> > are shot
> and
> > such.
> > > Good luck
> > > Safe travels,
> > > 84FC35
> > bought
> > part of
> be
> > > >Art Weatherly
> > > >Riverside Ca.
> > > >'85 PT36
> > story.
> > Be a PS3 game guru.
> Yahoo! Games.
06-04-2007, 02:36
Leroy,
I would be interested in your gage replacement project. The indexing
was different on the last gage, that I received and the sensor needed
to be changed to get a proper reading , Also the bezel is different
it is a flat solid black bezel, without the Silver trim, I have
changed the bezels , but that breaks the gage seal, no trouble with
fogging of the gage so far.......
Keep us informed.
Bill 88 FC Michigan
Bluebird and other suppliers I e-mailed over the weekend. Oil
Temperature gauge 54438 Bluebird part number 3865334 shows to be in
stock at Bluebird today. I will see if the indexing is the same when
I receive it. According to Teleflex this and other Teleflex gauges
Bluebird used are no longer in production and are no longer available
if Bluebird does not have inventory. I am replacing 3 flakey gauges
the original gauges. I would like to keep my bird dash looking
original. In the long term that may be difficult to do.
> Leroy Eckert
> Niceville, FL
> From: pattypape
> Jim,
> Bill 88 FC Michigan
> > Thanks,
it
(great
100,
will
old
> one. I hope!
> > Jim RIordan
> > 88 WBWL XXV
> > Stuart, Fl.
> > pattypape wrote:
> > Jim,
> axle
> > Bill 88 FC Michigan
it is
new
> temp
> > > Jim Riordan
> > > 88 WBWL XXV
> > > Stuart, Fl.
> > > Hi Art:
> lower
> > dash
edge
> and
> > slip
left
> > side of
screw
> that
> > has to
> > > come out.
mic
> from
> > the
holder.
> > Now the
been
> > removed it
> > before then
of
> > the upper
screw
> the
> > far
> after
> > the
needs to
> > come out
tilt
> > forward.
> replace
> > the
> enough
> > on this.
from
> > the other
both
> > panels.
> they
> > are shot
screws
> and
> > such.
> > > Good luck
> > > Safe travels,
> > > 84FC35
I
> > bought
verticle
> > part of
will
> be
> > > >Art Weatherly
> > > >Riverside Ca.
> > > >'85 PT36
your
> > story.
> > Be a PS3 game guru.
> Yahoo! Games.
06-04-2007, 02:53
I will let you know when I get the gauges. I think I'll go and buy one of those
lighted magnifying lamps and see if I can take the old ones apart and try to
determine why they are reading improperly. Grounds are good and the sendors are
new.
Leroy Eckert
Niceville, FL
Sent: Monday, June 04, 2007 9:36 AM
Leroy,
Keep us informed.
Bill 88 FC Michigan
> Leroy Eckert
> Niceville, FL
> From: pattypape
> Jim,
> Bill 88 FC Michigan
> > Thanks,
it
(great
100,
will
old
> one. I hope!
> > Jim RIordan
> > 88 WBWL XXV
> > Stuart, Fl.
> > pattypape wrote:
> > Jim,
> axle
> > Bill 88 FC Michigan
it is
new
> temp
> > > Jim Riordan
> > > 88 WBWL XXV
> > > Stuart, Fl.
> > > Hi Art:
> lower
> > dash
edge
> and
> > slip
left
> > side of
screw
> that
> > has to
> > > come out.
mic
> from
> > the
holder.
> > Now the
been
> > removed it
> > before then
of
> > the upper
screw
> the
> > far
> after
> > the
needs to
> > come out
tilt
> > forward.
> replace
> > the
> enough
> > on this.
from
> > the other
both
> > panels.
> they
> > are shot
screws
> and
> > such.
> > > Good luck
> > > Safe travels,
> > > 84FC35
I
> > bought
verticle
> > part of
will
> be
> > > >Art Weatherly
> > > >Riverside Ca.
> > > >'85 PT36
your
> > story.
> > Be a PS3 game guru.
> Yahoo! Games.
06-04-2007, 03:35
Might try these guys http://www.gaugeguys.com/
A couple of guys running the business from a converted garage, not fancy but
they were friendly and knowledgeable.
Troy
Sent: Monday, June 04, 2007 8:59 AM
Leroy Eckert
Niceville, FL
Jim,
Bill 88 FC Michigan
> Thanks,
one. I hope!
> Jim RIordan
> 88 WBWL XXV
> Stuart, Fl.
> pattypape wrote:
> Jim,
axle
> Bill 88 FC Michigan
temp
> > Jim Riordan
> > 88 WBWL XXV
> > Stuart, Fl.
> > Hi Art:
lower
> dash
> slip
> side of
that
> has to
> > come out.
from
> the
> Now the
> removed it
> before then
> the upper
> far
after
> the
> come out
> forward.
replace
> the
enough
> on this.
> the other
> panels.
they
> are shot
> such.
> > Good luck
> > Safe travels,
> > 84FC35
> bought
> part of
be
> > >Art Weatherly
> > >Riverside Ca.
> > >'85 PT36
> story.
> Be a PS3 game guru.
Yahoo! Games.
06-04-2007, 03:42
Leroy is the engine oil temp guage you ordered for you 90 the same for the
94?
> of those lighted magnifying lamps and see if I can take the old ones apart
> and try to determine why they are reading improperly. Grounds are good and
> the sendors are new.
> Leroy Eckert
> Niceville, FL
> From: pattypape
> Leroy,
> Keep us informed.
> Bill 88 FC Michigan
> "Leroy Eckert"
> > Leroy Eckert
> > Niceville, FL
> > From: pattypape
> > Jim,
> > Bill 88 FC Michigan
> jim riordan
> > wrote:
> > > Thanks,
> it
> (great
> 100,
> will
> old
> > one. I hope!
> > > Jim RIordan
> > > 88 WBWL XXV
> > > Stuart, Fl.
> > > pattypape wrote:
> > > Jim,
> > axle
> the
> > > Bill 88 FC Michigan
> > > --- In
> jim riordan
> it is
> new
> > temp
> > > > Jim Riordan
> > > > 88 WBWL XXV
> > > > Stuart, Fl.
> > > > Hi Art:
> > lower
> > > dash
> edge
> > and
> > > slip
> left
> > > side of
> screw
> > that
> > > has to
> > > > come out.
> mic
> > from
> > > the
> holder.
> > > Now the
> been
> > > removed it
> > > before then
> of
> > > the upper
> screw
> > the
> > > far
> > after
> > > the
> needs to
> > > come out
> tilt
> > > forward.
> > replace
> > > the
> > enough
> > > on this.
> from
> > > the other
> both
> > > panels.
> > they
> > > are shot
> screws
> > and
> > > such.
> > > > Good luck
> > > > Safe travels,
> > > > 84FC35
> I
> > > bought
> verticle
> > > part of
> will
> > be
> > > > >Art Weatherly
> > > > >Riverside Ca.
> > > > >'85 PT36
> your
> > > story.
> > > Be a PS3 game guru.
> > Yahoo! Games.
94 WLWB
