Vinyl eraser
05-14-2007, 10:42
Vinyl eraser
I want to remove the old, faded, cracked vinyl from my bird.
There are rubberized wheels to be used in an electric drill which are suppopsed to help considerably. I also saw a larger wheel for use in a power buffer that claims to work 10 times faster. The little wheel is about $23, the 'Big Eraser' is $149. The idea is that it will lift the vinyl but not damage the paint as long as you keep the speed down and don't press too hard. They also provide plastic razor blades to get the stubborn pieces loose. Has anyone used this kind of wheel to remove vinyl? Did it really help? Did it last more than 5 minutes? Gardner 78FC33 |
