A question for the "yankees"...surface rust
05-20-2007, 09:11
I'm a southerner, and around here we are not used to seeing much rust
on the underside of our vehicles. My newly acquired PT, however, was a northern coach, and the underpinnings have surface rust on them. Since this is all foreign to me, I ask...is this really something to worry much about? Is there anything I should do about it? Nothing looks weak or rusted through with holes or anything like that, there's just a coating on everything under there. The good news is that the body is fine, the coach was stripped to the bare metal and re-painted 3 years ago, and I have pictures of it stripped showing no body rust. Opinions/advice? Scott Forman 82 FC35RB sold but still here 86 PT38 |
05-20-2007, 10:06
Scott,
The body of your Bird is all galvanized steel so rust there should never be much of a problem. The frame may have some light rust that can be lightly sanded and touched up with a good quality (spray cans) rust resistant spray paint. --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > I'm a southerner, and around here we are not used to seeing much rust > on the underside of our vehicles. My newly acquired PT, however, was a > northern coach, and the underpinnings have surface rust on them. Since > this is all foreign to me, I ask...is this really something to worry > much about? Is there anything I should do about it? Nothing looks > weak or rusted through with holes or anything like that, there's just a > coating on everything under there. > > The good news is that the body is fine, the coach was stripped to the > bare metal and re-painted 3 years ago, and I have pictures of it > stripped showing no body rust. > > Opinions/advice? > > Scott Forman > 82 FC35RB sold but still here > 86 PT38 > |
05-20-2007, 12:44
Greg...which hammer do you apply that with?
Max SOB contemplating ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
05-20-2007, 16:05
The only thing of concern would then be grounds. If you notice BB
coated over the grounds with a heavy bodied paint. thick paint will not flow between the strap and frame/body. Paint with elasticity hold up better when painted thick compared to paint designed to be applied in thin coats. I wonder what they use, it looks like red primer solids.?????? You can clean the rust with acid gel and flush with water then reseal the metal with Continental frame paint but bare metal (rusted metal reveals bare) wont hold color without prepcoat and primer. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > I'm a southerner, and around here we are not used to seeing much rust > on the underside of our vehicles. My newly acquired PT, however, was a > northern coach, and the underpinnings have surface rust on them. Since > this is all foreign to me, I ask...is this really something to worry > much about? Is there anything I should do about it? Nothing looks > weak or rusted through with holes or anything like that, there's just a > coating on everything under there. > > The good news is that the body is fine, the coach was stripped to the > bare metal and re-painted 3 years ago, and I have pictures of it > stripped showing no body rust. > > Opinions/advice? > > Scott Forman > 82 FC35RB sold but still here > 86 PT38 > |
