Propane refrig.
05-28-2007, 04:57
Propane refrig.
Will the refrige, on propane, keep running during travel. If not, is
my main engine alternator w/inverter enough to power it on AC. I have a Heart 2500 W inverter. Don't know how big the alternator is. Art Weatherly Riverside Ca '85 PT36 |
05-28-2007, 05:06
Propane refrig.
Hi Art:
Yes, the refer should go to LP when the gen set is off and your not on shore power. To run it off the inverter on ac you would have to re wire some circuits, but there should be no need to do so. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 04:57 PM 5/28/2007 +0000, you wrote: >Will the refrige, on propane, keep running during travel. If not, is >my main engine alternator w/inverter enough to power it on AC. I have >a Heart 2500 W inverter. Don't know how big the alternator is. > >Art Weatherly >Riverside Ca >'85 PT36 > > |
05-28-2007, 12:48
Propane refrig.
Art, The one I have has a delay hooked up to bus ignition to keep the
pilot from striking a spark while fueling. The circuit board with the defaults runs on 12v as does the interior light. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "amweath" wrote: > > Will the refrige, on propane, keep running during travel. If not, is > my main engine alternator w/inverter enough to power it on AC. I have > a Heart 2500 W inverter. Don't know how big the alternator is. > > Art Weatherly > Riverside Ca > '85 PT36 > |
05-29-2007, 00:02
Propane refrig.
Yes.
SteveAnderson 79 FC 35 Poulsbo Wa In a message dated 5/29/2007 8:52:50 AM Pacific Daylight Time, amweatherly@... writes: I wasn't clear enough with my question. Will the fridge keep working on propane while driving down the road? Art Weatherly Riverside Ca. '85 PT36 ----- Original Message ----- From: Ralph L. Fullenwider To: _WanderlodgeForum@WanderlodgeFWan_ (mailto:WanderlodgeForum@yahoogroups.com) Sent: Monday, May 28, 2007 10:06 AM Subject: [SPAM] Re: [WanderlodgeForum] Propane refrig. Hi Art: Yes, the refer should go to LP when the gen set is off and your not on shore power. To run it off the inverter on ac you would have to re wire some circuits, but there should be no need to do so. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 04:57 PM 5/28/2007 +0000, you wrote: >Will the refrige, on propane, keep running during travel. If not, is >my main engine alternator w/inverter enough to power it on AC. I have >a Heart 2500 W inverter. Don't know how big the alternator is. > >Art Weatherly >Riverside Ca >'85 PT36 > > [Non-text portions of this message have been removed] ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
05-29-2007, 03:45
Propane refrig.
while driving down the road? Art Weatherly Riverside Ca. '85 PT36 ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Monday, May 28, 2007 10:06 AM Subject: [SPAM] Re: [WanderlodgeForum] Propane refrig. Hi Art: Yes, the refer should go to LP when the gen set is off and your not on shore power. To run it off the inverter on ac you would have to re wire some circuits, but there should be no need to do so. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 04:57 PM 5/28/2007 +0000, you wrote: >Will the refrige, on propane, keep running during travel. If not, is >my main engine alternator w/inverter enough to power it on AC. I have >a Heart 2500 W inverter. Don't know how big the alternator is. > >Art Weatherly >Riverside Ca >'85 PT36 > > [Non-text portions of this message have been removed] |
05-29-2007, 03:59
Propane refrig.
Yes it will. I do it all the time.
Keith 84FC35 --- In WanderlodgeForum@yahoogroups.com, "Art Weatherly" > > I wasn't clear enough with my question. Will the fridge keep working on propane while driving down the road? > > Art Weatherly > Riverside Ca. > '85 PT36 > ----- Original Message ----- > From: Ralph L. Fullenwider > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, May 28, 2007 10:06 AM > Subject: [SPAM] Re: [WanderlodgeForum] Propane refrig. > > > Hi Art: > > Yes, the refer should go to LP when the gen set is off and your not on > shore power. To run it off the inverter on ac you would have to re wire > some circuits, but there should be no need to do so. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Duncan, Oklahoma > > At 04:57 PM 5/28/2007 +0000, you wrote: > >Will the refrige, on propane, keep running during travel. If not, is > >my main engine alternator w/inverter enough to power it on AC. I have > >a Heart 2500 W inverter. Don't know how big the alternator is. > > > >Art Weatherly > >Riverside Ca > >'85 PT36 > > > > > > > > > > [Non-text portions of this message have been removed] > |
05-29-2007, 04:10
Propane refrig.
Yes it will. You have to be sure that you have the setting on the eye brow
set to automatic. If it set to auto, it will seek 110 vac first then go to lp. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 08:45 AM 5/29/2007 -0700, you wrote: >I wasn't clear enough with my question. Will the fridge keep working on >propane while driving down the road? > >Art Weatherly >Riverside Ca. >'85 PT36 > ----- Original Message ----- > From: Ralph L. Fullenwider > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, May 28, 2007 10:06 AM > Subject: [SPAM] Re: [WanderlodgeForum] Propane refrig. > > > Hi Art: > > Yes, the refer should go to LP when the gen set is off and your not on > shore power. To run it off the inverter on ac you would have to re wire > some circuits, but there should be no need to do so. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Duncan, Oklahoma > > At 04:57 PM 5/28/2007 +0000, you wrote: > >Will the refrige, on propane, keep running during travel. If not, is > >my main engine alternator w/inverter enough to power it on AC. I have > >a Heart 2500 W inverter. Don't know how big the alternator is. > > > >Art Weatherly > >Riverside Ca > >'85 PT36 > > > > > > |
05-29-2007, 05:07
Propane refrig.
I guess you didn't get a straight answer, because that's what they're
designed to do. However, many years ago, I rented an RV where the pilot light would blow out when on the road. I'd hope that newer refrigerators would have electric spark for starting the burner instead of a pilot light so that shouldn't be a problem. My coach has a regular home-type refrigerator that runs off the inverter. Makes boondocking a problem as it pulls down the batteries rather quickly. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On May 29, 2007, at 10:45 AM, Art Weatherly wrote: > I wasn't clear enough with my question. Will the fridge keep > working on propane while driving down the road? <snip> |
