cool a matic fan
06-03-2007, 02:36
cool a matic fan
I said they are no longer in production not out of business last time
I called they still had a limited number of parts available send them an email Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Leroy- called that number and answering machine says they no longer maintain > regular business hours. So, looks like, as Stephen said, they are outta > business. Will check out fantastic fans. > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
06-03-2007, 03:04
cool a matic fan
Ernie,
You might also check http://www.maxxair.com/products/MaxxFan.aspx . It has the effect of a rain shield without an additional cover. If I need to replace a fan in the future, I may try it out. Dan --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Hi Stephen- the fantastic vent has a 920 cfm capability. wonder what > kool-o-matic cfm is? > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
06-03-2007, 03:09
cool a matic fan
I should have added the info on the wireless remote:
http://www.maxxair.com/brochures/remote_..._guide.pdf You can set air temps for start stop, open and close the lid, etc. Dan 97 BB BMC 37 NM --- In WanderlodgeForum@yahoogroups.com, "ac7880" wrote: > > Ernie, > > You might also check > http://www.maxxair.com/products/MaxxFan.aspx . It has the effect of a > rain shield without an additional cover. If I need to replace a fan in > the future, I may try it out. > > Dan > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > Hi Stephen- the fantastic vent has a 920 cfm capability. wonder what > > kool-o-matic cfm is? > > > > Ernie Ekberg > > 83PT40 > > Livingston, Mt > > > > > > > > > > ************************************** See what's free at > http://www.aol.com. > > > > > > [Non-text portions of this message have been removed] > > > |
06-03-2007, 03:12
cool a matic fan
Ernie,
Grainger may have a replacement motor http://www.grainger.com Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Leroy- called that number and answering machine says they no longer maintain > regular business hours. So, looks like, as Stephen said, they are outta > business. Will check out fantastic fans. > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
06-03-2007, 03:49
cool a matic fan
Stephen- will the max air fit in the 14x 14 opening? If i have to cutthe
roof, I'll just go with fantastic. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
06-03-2007, 06:58
cool a matic fan
Thats a pretty touchy subject them CFMs
I would imagine the fantastic and the maxx air are much better at moving air than the koala-matic (Hows that for spell checking) I would think about upgrading any way I would look at the maxxair with hand held remote apperently the wall switch models are diffenet and only available to manufactureres besides the work of installing in an already built coach I will see if there is any cost saving in purchasing a bunch Just be aware that the maxxair has a 23 inch footprint on the roof you may have to trim the deck plates Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Hi Stephen- the fantastic vent has a 920 cfm capability. wonder what > kool-o-matic cfm is? > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
06-03-2007, 23:24
cool a matic fan
yes ihave never seen aroof vent that is not based on14x14 although
there may be some somewhere stephen77fc35 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Stephen- will the max air fit in the 14x 14 opening? If i have to cutthe > roof, I'll just go with fantastic. > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
06-04-2007, 02:47
cool a matic fan
Hi Ernie,
I just had the same experience with my Kool-O-Matic fan. I found an almost perfect replacement motor at surpluscenter.com. I say almost perfect because the body of the new motor is about 1/8th" smaller in diameter than the original so I had to shim it on 3 sides (to keep it centered). I think I paid $ 14.00 + s&h. Chuck Harrison Akron, Ohio 90SP36 --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > Came home today- after riding in a 1/4 million dollar ride- Packard- my > cool-o-matic motor went south. smelled all kinds of electrical smell- > anyone have a model numnber and contact number? Thanks, Ernie-83PT40 in > Montana > |
06-04-2007, 03:39
cool a matic fan
As far as we can tell it works fine. I called Kool-O-Matic right after
mine failed and I was able to get through but the replacement motor was $119.00 + S&H. Chuck Harrison Akron, Ohio 90SP36 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > will it move the volume of air like the kool-o-matic? > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
06-04-2007, 03:51
cool a matic fan
Thanks, Chuck- what hp is your motor?
User(s) browsing this thread: 11 Guest(s)
