Powertech Generator --engine not running right.
06-05-2007, 08:23
Pete- do you have a separate Racor filter for your generator. Maybe its a
fuel starvation problem? Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
06-05-2007, 12:19
Yesterday and again today, the Powertech 15kw generator started
acting up. The problem seems to be the Kubota diesel engine. The exhaust is black and sooty and the engine isn't putting out full power (noted that the voltage had dropped down to 100 vac from the usual 120 vac) I changed the air filter last summer -- solving a sooty exhaust problem (without any loss of power) at that time, but this seems more serious. A couple of weeks ago, I started the generator, I thought perhaps, prematurely without allowing the glow plugs to run long enough as the engine was clearly stumbling and not running on all cylinders. Looking at the engine, it appears that on injector has been replaced (from the look of the paint, etc.) so the engine may have had problems in the past. I'll call Powertech tomorrow, but I'd appreciate any thoughts anyone may care to offer. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Denver Colorado |
06-05-2007, 12:32
Black exhaust is overfueling. This could equal underairing. I'd check the air
filter again to see if it is clean. The other factor to consider is the elevation. Denver air is thin enough that unless the engine has an altitude compensator of some kind, you may be running rich simply due to the elevation. Diesels Only on West Alameda is a good shop if it turns out you need mechanical service. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > Yesterday and again today, the Powertech 15kw generator started > acting up. The problem seems to be the Kubota diesel engine. The > exhaust is black and sooty and the engine isn't putting out full > power (noted that the voltage had dropped down to 100 vac from the > usual 120 vac) > > I changed the air filter last summer -- solving a sooty exhaust > problem (without any loss of power) at that time, but this seems more > serious. A couple of weeks ago, I started the generator, I thought > perhaps, prematurely without allowing the glow plugs to run long > enough as the engine was clearly stumbling and not running on all > cylinders. > > Looking at the engine, it appears that on injector has been replaced > (from the look of the paint, etc.) so the engine may have had > problems in the past. > > I'll call Powertech tomorrow, but I'd appreciate any thoughts anyone > may care to offer. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Denver Colorado > |
06-05-2007, 13:37
No Racor for the genny. I replaced the fuel filter (a spin on one)
last summer when I changed the air filter. I have a spare with me ... I can put it on... But with all the soot and smoke, it seems like there's plenty of fuel -- it's just not burning right. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Denver Colorado On Jun 5, 2007, at 6:23 PM, erniecarpet@... wrote: > Pete- do you have a separate Racor filter for your generator. Maybe > its a > fuel starvation problem? > > Ernie Ekberg > 83PT40 > Livingston, Mt > > |
06-05-2007, 13:41
I considered the altitude. I had a bit of black smoke when I was
through here last year when I bought the coach ... but this is a _lot_ more black smoke. I was getting some while in Texas -- some 3000 ft lower elevation. I'll swap the air filter (I have a spare on board) and see if that helps. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' Sitting in the Camping World parking lot in Denver waiting for an AC service in the morning... On Jun 5, 2007, at 6:32 PM, davidkerryedwards wrote: > Black exhaust is overfueling. This could equal underairing. I'd > check the air filter again to > see if it is clean. The other factor to consider is the > elevation. Denver air is thin enough > that unless the engine has an altitude compensator of some kind, > you may be running rich > simply due to the elevation. > Diesels Only on West Alameda is a good shop if it turns out you > need mechanical service. > > Kerry > 82 FC 35 > Denver > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > >> >> Yesterday and again today, the Powertech 15kw generator started >> acting up. The problem seems to be the Kubota diesel engine. The >> exhaust is black and sooty and the engine isn't putting out full >> power (noted that the voltage had dropped down to 100 vac from the >> usual 120 vac) >> >> I changed the air filter last summer -- solving a sooty exhaust >> problem (without any loss of power) at that time, but this seems more >> serious. A couple of weeks ago, I started the generator, I thought >> perhaps, prematurely without allowing the glow plugs to run long >> enough as the engine was clearly stumbling and not running on all >> cylinders. >> >> Looking at the engine, it appears that on injector has been replaced >> (from the look of the paint, etc.) so the engine may have had >> problems in the past. >> >> I'll call Powertech tomorrow, but I'd appreciate any thoughts anyone >> may care to offer. >> >> Pete Masterson >> '95 Blue Bird Wanderlodge WBDA 42 >> aeonix1@... >> On the road at Denver Colorado >> > > > |
06-05-2007, 14:35
That parking lot is pretty clean. You might try running it for a minute with
the filter removed and see if you get enough air flow to solve the problem. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > I considered the altitude. I had a bit of black smoke when I was > through here last year when I bought the coach ... but this is a > _lot_ more black smoke. I was getting some while in Texas -- some > 3000 ft lower elevation. > > I'll swap the air filter (I have a spare on board) and see if that > helps. > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > Sitting in the Camping World parking lot in Denver waiting for an AC > service in the morning... > > > > > On Jun 5, 2007, at 6:32 PM, davidkerryedwards wrote: > > > Black exhaust is overfueling. This could equal underairing. I'd > > check the air filter again to > > see if it is clean. The other factor to consider is the > > elevation. Denver air is thin enough > > that unless the engine has an altitude compensator of some kind, > > you may be running rich > > simply due to the elevation. > > Diesels Only on West Alameda is a good shop if it turns out you > > need mechanical service. > > > > Kerry > > 82 FC 35 > > Denver > > > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > > >> > >> Yesterday and again today, the Powertech 15kw generator started > >> acting up. The problem seems to be the Kubota diesel engine. The > >> exhaust is black and sooty and the engine isn't putting out full > >> power (noted that the voltage had dropped down to 100 vac from the > >> usual 120 vac) > >> > >> I changed the air filter last summer -- solving a sooty exhaust > >> problem (without any loss of power) at that time, but this seems more > >> serious. A couple of weeks ago, I started the generator, I thought > >> perhaps, prematurely without allowing the glow plugs to run long > >> enough as the engine was clearly stumbling and not running on all > >> cylinders. > >> > >> Looking at the engine, it appears that on injector has been replaced > >> (from the look of the paint, etc.) so the engine may have had > >> problems in the past. > >> > >> I'll call Powertech tomorrow, but I'd appreciate any thoughts anyone > >> may care to offer. > >> > >> Pete Masterson > >> '95 Blue Bird Wanderlodge WBDA 42 > >> aeonix1@ > >> On the road at Denver Colorado > >> > > > > > > > |
06-05-2007, 14:48
Kerry,
Thanks ... I just put on a new filter, and the genny is back to normal. Voltage is up to 127 on my multimeter -- the exhaust is slightly black -- and _that_ I attribute to the altitude. I must have encountered more dust along the way than I thought. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' Sitting in a Camping World parking lot for the night in Denver Colorado. On Jun 5, 2007, at 8:35 PM, davidkerryedwards wrote: > That parking lot is pretty clean. You might try running it for a > minute with the filter > removed and see if you get enough air flow to solve the problem. > > Kerry > 82 FC 35 > Denver > > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > >> >> I considered the altitude. I had a bit of black smoke when I was >> through here last year when I bought the coach ... but this is a >> _lot_ more black smoke. I was getting some while in Texas -- some >> 3000 ft lower elevation. >> >> I'll swap the air filter (I have a spare on board) and see if that >> helps. >> >> Pete Masterson >> aeonix1@... >> '95 Blue Bird Wanderlodge WBDA 42' >> Sitting in the Camping World parking lot in Denver waiting for an AC >> service in the morning... >> >> >> >> >> On Jun 5, 2007, at 6:32 PM, davidkerryedwards wrote: >> >>> Black exhaust is overfueling. This could equal underairing. I'd >>> check the air filter again to >>> see if it is clean. The other factor to consider is the >>> elevation. Denver air is thin enough >>> that unless the engine has an altitude compensator of some kind, >>> you may be running rich >>> simply due to the elevation. >>> Diesels Only on West Alameda is a good shop if it turns out you >>> need mechanical service. >>> >>> Kerry >>> 82 FC 35 >>> Denver >>> >>> --- In WanderlodgeForum@yahoogroups.com, Pete Masterson >>> >>>> >>>> Yesterday and again today, the Powertech 15kw generator started >>>> acting up. The problem seems to be the Kubota diesel engine. The >>>> exhaust is black and sooty and the engine isn't putting out full >>>> power (noted that the voltage had dropped down to 100 vac from the >>>> usual 120 vac) >>>> >>>> I changed the air filter last summer -- solving a sooty exhaust >>>> problem (without any loss of power) at that time, but this seems >>>> more >>>> serious. A couple of weeks ago, I started the generator, I thought >>>> perhaps, prematurely without allowing the glow plugs to run long >>>> enough as the engine was clearly stumbling and not running on all >>>> cylinders. >>>> >>>> Looking at the engine, it appears that on injector has been >>>> replaced >>>> (from the look of the paint, etc.) so the engine may have had >>>> problems in the past. >>>> >>>> I'll call Powertech tomorrow, but I'd appreciate any thoughts >>>> anyone >>>> may care to offer. >>>> >>>> Pete Masterson >>>> '95 Blue Bird Wanderlodge WBDA 42 >>>> aeonix1@ >>>> On the road at Denver Colorado >>>> >>> >>> >>> >> > > > > > > Yahoo! Groups Links > > > |
06-05-2007, 15:03
Glad it's fixed. It's a little late to be telling you this now, but the town of
Golden has a nice RV park along Clear Creek just west of you. It's not listed in any guidebook that I've seen but it's in town, right on the creek at the Whitewater Park adjacent to a very nice recreation center/park with a bike path that runs right along the creek. Just a short walk to Coors and it's tour. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > Kerry, > > Thanks ... I just put on a new filter, and the genny is back to > normal. Voltage is up to 127 on my multimeter -- the exhaust is > slightly black -- and _that_ I attribute to the altitude. I must have > encountered more dust along the way than I thought. > > Pete Masterson > |
06-05-2007, 15:19
Pete, the electric fan that cools the radiator creates major dust.
Good filters choak up fast. when you run a diesel rich for a period of time, it is always a good idea to change the oil. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > Kerry, > > Thanks ... I just put on a new filter, and the genny is back to > normal. Voltage is up to 127 on my multimeter -- the exhaust is > slightly black -- and _that_ I attribute to the altitude. I must have > encountered more dust along the way than I thought. > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > Sitting in a Camping World parking lot for the night in Denver Colorado. > > > > > On Jun 5, 2007, at 8:35 PM, davidkerryedwards wrote: > > > That parking lot is pretty clean. You might try running it for a > > minute with the filter > > removed and see if you get enough air flow to solve the problem. > > > > Kerry > > 82 FC 35 > > Denver > > > > > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > > >> > >> I considered the altitude. I had a bit of black smoke when I was > >> through here last year when I bought the coach ... but this is a > >> _lot_ more black smoke. I was getting some while in Texas -- some > >> 3000 ft lower elevation. > >> > >> I'll swap the air filter (I have a spare on board) and see if that > >> helps. > >> > >> Pete Masterson > >> aeonix1@ > >> '95 Blue Bird Wanderlodge WBDA 42' > >> Sitting in the Camping World parking lot in Denver waiting for an AC > >> service in the morning... > >> > >> > >> > >> > >> On Jun 5, 2007, at 6:32 PM, davidkerryedwards wrote: > >> > >>> Black exhaust is overfueling. This could equal underairing. I'd > >>> check the air filter again to > >>> see if it is clean. The other factor to consider is the > >>> elevation. Denver air is thin enough > >>> that unless the engine has an altitude compensator of some kind, > >>> you may be running rich > >>> simply due to the elevation. > >>> Diesels Only on West Alameda is a good shop if it turns out you > >>> need mechanical service. > >>> > >>> Kerry > >>> 82 FC 35 > >>> Denver > >>> > >>> --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > >>> > >>>> > >>>> Yesterday and again today, the Powertech 15kw generator started > >>>> acting up. The problem seems to be the Kubota diesel engine. The > >>>> exhaust is black and sooty and the engine isn't putting out full > >>>> power (noted that the voltage had dropped down to 100 vac from the > >>>> usual 120 vac) > >>>> > >>>> I changed the air filter last summer -- solving a sooty exhaust > >>>> problem (without any loss of power) at that time, but this seems > >>>> more > >>>> serious. A couple of weeks ago, I started the generator, I thought > >>>> perhaps, prematurely without allowing the glow plugs to run long > >>>> enough as the engine was clearly stumbling and not running on all > >>>> cylinders. > >>>> > >>>> Looking at the engine, it appears that on injector has been > >>>> replaced > >>>> (from the look of the paint, etc.) so the engine may have had > >>>> problems in the past. > >>>> > >>>> I'll call Powertech tomorrow, but I'd appreciate any thoughts > >>>> anyone > >>>> may care to offer. > >>>> > >>>> Pete Masterson > >>>> '95 Blue Bird Wanderlodge WBDA 42 > >>>> aeonix1@ > >>>> On the road at Denver Colorado > >>>> > >>> > >>> > >>> > >> > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > |
06-06-2007, 00:49
A frenchman with a flamingo posted that the crank case breather on
the powertecs vent too close to the airfilter and the paper element gets a oily residu which gums up with dust quickly. I plan to take Randys advice, heed the warning of Petes discovery and vent the crankcase tube out of the airtight compartment. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Pete, the electric fan that cools the radiator creates major dust. > Good filters choak up fast. when you run a diesel rich for a period > of time, it is always a good idea to change the oil. > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > > > > Kerry, > > > > Thanks ... I just put on a new filter, and the genny is back to > > normal. Voltage is up to 127 on my multimeter -- the exhaust is > > slightly black -- and _that_ I attribute to the altitude. I must > have > > encountered more dust along the way than I thought. > > > > Pete Masterson > > aeonix1@ > > '95 Blue Bird Wanderlodge WBDA 42' > > Sitting in a Camping World parking lot for the night in Denver > Colorado. > > > > > > > > > > On Jun 5, 2007, at 8:35 PM, davidkerryedwards wrote: > > > > > That parking lot is pretty clean. You might try running it for > a > > > minute with the filter > > > removed and see if you get enough air flow to solve the problem. > > > > > > Kerry > > > 82 FC 35 > > > Denver > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > > > > >> > > >> I considered the altitude. I had a bit of black smoke when I was > > >> through here last year when I bought the coach ... but this is a > > >> _lot_ more black smoke. I was getting some while in Texas -- some > > >> 3000 ft lower elevation. > > >> > > >> I'll swap the air filter (I have a spare on board) and see if > that > > >> helps. > > >> > > >> Pete Masterson > > >> aeonix1@ > > >> '95 Blue Bird Wanderlodge WBDA 42' > > >> Sitting in the Camping World parking lot in Denver waiting for > an AC > > >> service in the morning... > > >> > > >> > > >> > > >> > > >> On Jun 5, 2007, at 6:32 PM, davidkerryedwards wrote: > > >> > > >>> Black exhaust is overfueling. This could equal underairing. > I'd > > >>> check the air filter again to > > >>> see if it is clean. The other factor to consider is the > > >>> elevation. Denver air is thin enough > > >>> that unless the engine has an altitude compensator of some kind, > > >>> you may be running rich > > >>> simply due to the elevation. > > >>> Diesels Only on West Alameda is a good shop if it turns out you > > >>> need mechanical service. > > >>> > > >>> Kerry > > >>> 82 FC 35 > > >>> Denver > > >>> > > >>> --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > > >>> > > >>>> > > >>>> Yesterday and again today, the Powertech 15kw generator started > > >>>> acting up. The problem seems to be the Kubota diesel engine. > The > > >>>> exhaust is black and sooty and the engine isn't putting out > full > > >>>> power (noted that the voltage had dropped down to 100 vac from > the > > >>>> usual 120 vac) > > >>>> > > >>>> I changed the air filter last summer -- solving a sooty exhaust > > >>>> problem (without any loss of power) at that time, but this > seems > > >>>> more > > >>>> serious. A couple of weeks ago, I started the generator, I > thought > > >>>> perhaps, prematurely without allowing the glow plugs to run > long > > >>>> enough as the engine was clearly stumbling and not running on > all > > >>>> cylinders. > > >>>> > > >>>> Looking at the engine, it appears that on injector has been > > >>>> replaced > > >>>> (from the look of the paint, etc.) so the engine may have had > > >>>> problems in the past. > > >>>> > > >>>> I'll call Powertech tomorrow, but I'd appreciate any thoughts > > >>>> anyone > > >>>> may care to offer. > > >>>> > > >>>> Pete Masterson > > >>>> '95 Blue Bird Wanderlodge WBDA 42 > > >>>> aeonix1@ > > >>>> On the road at Denver Colorado > > >>>> > > >>> > > >>> > > >>> > > >> > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > |
