Replace Roof AC units - 1992 WB40
06-10-2007, 17:10
Well I lost another roof AC unit (cracked copper tubing, again), so
that's it, I am going to replace them now.
How do you get the lower unit cover off (these are the stock units
that came from BlueBird, so they are the vinyl covered lower
covers)?
I can not seem to figure out how they are attached so I can get to the
two rear most bolts through the AC unit.
Still debating between the Dometics or Carrier units. Probably go
with Penguins so I don't have to change a bunch of wires. But I will
be stuck to what I can get this week as we go on our trip starting
next weekend.....
06-11-2007, 01:58
My inside covers are plastic -- and the screws holding them are
reachable inside after you remove the 'return' screen.
While the Dometic Penguins are low profile (and probably exact
replacements for what you currently have) you might consider the
Dometic Brisk-air "High Efficiency" units. I replaced 2 of my 3
Penguins with these units. They only draw 10 amps (each) instead of
the 15 amps of the Penguins. The Dometic brand will work (usually)
work with the Dometic thermostats (if you have that arrangement) and
simplify the wiring necessary.
The downside is that the Brisk-Air units are several inches taller,
costing you some clearance. On my coach, the King Dome is already
taller -- so the Brisk-Air units didn't really affect my clearance
anyway...
The high efficiency units are slightly more expensive than the
"normal" units -- but you may appreciate being able to run them when
available current is limited -- it just gives you that much more
margin when using a 30 amp connection, etc.
Pete Masterson
aeonix1@...
currently at Chief Hosa, Colorado
> covers)?
> next weekend.....
06-11-2007, 06:43
Well because Dometic Tech Support is so bad, and the fact that I
could not get anyone to really tell me what I had to do with the
Thermostats (could I convert the wiring etc., which I know I can, but
the techs are clueless), I purchased 2 Carrier Heat Pumps which have
the sensors in the lower units and hand operated remote controls.
I will replace both forward AC's and put new lower units in as
well.
My current lower units are plywood wrapped with vinyl and I can not
see how they are attached to the ceiling. I can find the two
forward AC bolts in the return air side, but I thought there are two
that would be located in ducted air side as well. But I can not get
the lower unit off to see or get to them. Yes I can remove the metal
grill that holds the air filter in, but that does not let the lower
unit come down.
Now that I had to purchase new lower units for the Carrier I can man
handle them if I have to because if I destroy them it does not
matter. But I would rather not do that. Guess I will call Jessie at
BB and see if he can tell me how they are attached.
Michael Brundridge
1992 WB40
Georgetown, TX
of
taller,
> anyway...
when
> Pete Masterson
> aeonix1@...
so
> > covers)?
to the
will
> > next weekend.....
06-11-2007, 07:28
I have been trying to figure out how to get that lower cover off.
Please post your results Thanks, Thomas 93 wlwb
06-11-2007, 12:00
Well I got them off. I purchased two Carrier AirV 15K BTU Heat Pumps,
I have had some internmittent issue with the Primus, so the heat pumps
give me heat without the need for Propane as long as the outside temp
does not get too low. They also solve the issues of having to replace
the dometic thermostats and get the special adapters to convert the
ribbon cable to RJ11 as they come with remote thermostats and a built
in head in the new lower unit.
If your lower units are like mine, where they match the ceiling
material, they are attached with four plastic push in retainers. I
will send you a picture from the side of the panel. The push pins are
located about 3 1/2" in from each corner.
To remove the grill:
1) Remove the 6 screws attaching the return air grill to the vinyl
covered lower unit
2) Grasp the lower unit with your fingers located on the inside edge of
the covers forward edge, and your thumbs on the outside edge about 4"
from each corner and pull down. This takes a little force as there are
four plastic pins that go from the lower panel up into the coaches
roof. These plastic pins have many small retaining fingers that cause
the panel to stay and place and you must over come their resistance.
3) Once the front comes lose you will be able to grab the back edge and
pull the rear of the unit down in the same fashion.
NOTE: I take no responsibility for these instructions, your mileage may
vary Smile
Michael Brundridge
1992 WB40
Georgetown, TX
--- In WanderlodgeForum@yahoogroups.com, "Thomas Rembert"
06-11-2007, 12:06
I replaced a dometic with a carrier heat pump in my 1981 FC but i didn't like
it. the carrier moves a lot more air and seemed a lot noisier even on the
lowest setting. i would be interested in your opinion on them after you get
them installed.
Thanks
Dan
81FC33
Jackson, MS
Sent: Monday, June 11, 2007 7:00 PM
Subject: [WanderlodgeForum] Re: Replace Roof AC units - 1992 WB40
covered lower unit
vary Smile
Michael Brundridge
1992 WB40
Georgetown, TX
Checked by AVG Free Edition.
Version: 7.5.472 / Virus Database: 269.8.13/843 - Release Date: 6/10/2007 1:39
PM
06-11-2007, 12:21
I would say the same thing about the Colemans. We installed the
Coleman Mach 3PS (10AMP units) on our last coach and damn near never
got any sleep as the unit's where so noisy. That is one reason I am
not replacing the one in the bedroom at this time as the Dometic is
nice and quite, especially with the 1/2" thick padded plywood cover
that came with it from BB.
Michael Brundridge
1992 WB40
Georgetown, TX
didn't like it. the carrier moves a lot more air and seemed a lot
noisier even on the lowest setting. i would be interested in your
opinion on them after you get them installed.
> Thanks
> Dan
> 81FC33
> Jackson, MS
> From: mbrund
Pumps,
pumps
temp
replace
built
I
are
vinyl
> covered lower unit
edge of
about 4"
there are
coaches
cause
resistance.
edge and
mileage may
> vary Smile
> Michael Brundridge
> 1992 WB40
> Georgetown, TX
off.
6/10/2007 1:39 PM
06-11-2007, 12:38
Picture of unit posted here:
http://autos.ph.groups.yahoo.com/group/W...os/view/d7
f3?b=1
Pumps,
pumps
temp
replace
built
are
> covered lower unit
edge of
4"
are
cause
may
> vary Smile
> Michael Brundridge
> 1992 WB40
> Georgetown, TX
06-11-2007, 12:50
One thing we found with the Brisk air is to regularly exercise the fan
or it will seize on the bearing and there is no way to free them up
without replacing the fan motor
We replaced 2 that were only 2 years old they were covered under
warranty but it is a pain in the butt
Stephen 77fc35 dometic service parts and appliances available
> f3?b=1
> Pumps,
> pumps
> temp
> replace
> built
> are
> > covered lower unit
> edge of
> 4"
> are
> cause
> and
> may
> > vary Smile
> > Michael Brundridge
> > 1992 WB40
> > Georgetown, TX
06-11-2007, 13:26
Isn't your system ducted? I run the front or center unit at night and
it keeps the bedroom reasonably cool (having cooled the bedroom down
with the rear unit first) with little noise.
Pete Masterson
aeonix1@...
El Sobrante, CA
> Michael Brundridge
> 1992 WB40
> Georgetown, TX
>> Thanks
<snip>
