Engine Water Temp
07-01-2007, 05:10
Engine Water Temp
can anyone help with the correct running temperature for the CAT 3208T
in my 82 FC-35? The wanderlodge manual says 100 degrees over the
outside temperature. Mine is running at about 200 degrees which is
about 20 degrees higher. I am about to take it into the mountains so
what is your advice before I travel?
82 FC-35 "Perfect Weekend"
07-01-2007, 05:15
Engine Water Temp
The temp gauge on my old FC indicated 15-20 degrees higher than
actual. If you have access to an infrared heat gun, I would check on
the accuracy first.
Scott
86 PT38
--- In WanderlodgeForum@yahoogroups.com, "jmoorelewy"
07-01-2007, 05:54
Engine Water Temp
Can you tell when your fan clutch kicks in? Mine kicks in around 195 degrees or
so and
immediately starts bringing down the temperature. If your gauge is accurate, I
believe your
fan clutch should be kicking in before it gets to the temperature you're seeing.
Kerry
82 FC 35
Denver
07-01-2007, 11:00
Engine Water Temp
To me, it sounds like your fan may not be coming on or isn't
funtioning well when it does. Have you checked the radiator cap. It
may not be holding adequate pressure. On my '85FC the fan will hold
the temp to 190, + or - a couple of deg. This is on any hard pull.
Like Scott says, check your gage first.
Harold Prescott
'85 FC35
Northern California
07-01-2007, 15:13
Engine Water Temp
The fan clutch kicks in around 190 - 200 i think. I will check if this
drops the temp, as far as I remember the temp stays constant at just
under 200. I have checked the rad cap it seems fine and the coolant
level is right too.
07-02-2007, 01:40
Engine Water Temp
I notice that the water temp will hang around 190 once I let it get
hot enough to turn the fan on. So, if I hammer on it too hard and the
fan comes on it stays on until we drop off a very long hill.
The fan comes on around 190 and turns off when the temp reaches 185.
I have replaced my thermostats. They require 180deg.thermostats.
Someone had put 160deg thermostats in, trying to get it to run cooler,
I suppose.
I think 160's made it smoke more. Caterpiller says 180's are correct.
I don't know if all this will help or not.
Harold Prescott
'85 FC35
Northern California
