Fridge problem
07-03-2007, 07:09
Fridge problem
You might need to take that unit apart and clean it. Mine did the same and
that corrected the problem.
83PT40
Livingston, Mt
07-03-2007, 09:37
Fridge problem
The alarm below our Fridge keeps going off. The fridge seems to be
lighting and working well but after a day of operation the alarm
starts to sound intermittently. I have checked for gas leaks and there
doesn't seem to be any. Does anyone have any advice on trouble
shooting this?
Wishing all of you a happy and safe 4th!
1982 FC35 "Perfect Weekend"
07-03-2007, 09:50
Fridge problem
Make sure your 12 volt battery system is charging properly. Sounds like
you only have the alarm turn on after you have run for a day. Are you
plugging into shore power or starting the generator to charge the
batteries? If all the 12 volt lights etc are ok, then you may have a
loose connector to the alarm or possibly you do have a leak in the
propane line? You need 12 volts to operate the valve for the propane
line to the fridge. Good luck & have a safe 4th.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
> shooting this?
07-03-2007, 10:49
Fridge problem
Last weekend my friend had a similar problem while we were camping. It
turned out to be his wife's hairspray setting it off.
- Chuck Wheeler -
82 FC 31 SB
Fort Worth, TX
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of jmoorelewy
Sent: Tuesday, July 03, 2007 4:37 PM
Subject: [WanderlodgeForum] Fridge problem
shooting this?
07-03-2007, 15:30
Fridge problem
--- In WanderlodgeForum@yahoogroups.com, "jmoorelewy"
> shooting this?
07-04-2007, 00:13
Fridge problem
I had the same problem on our 94 BB BMC 37' and finally replaced the
propane detector. I think only CCI now sells a detector with the auto
propane shut off system.
I went with the CCI Control Electronic LP Gas Detector model 50859.
When a gas leak is detected in the RV, it sounds an alarm -- and it
shuts off the gas supply by controlling a UL listed LP gas valve. It
also has a on/off switch, that will open and close the external gas
valve.
This is what the original Atwood did minus the on/off switch, the new
ones that I found from Atwood did not have the shutoff feature. The CCI
is flush mount, but a different size than the Atwood. I had to lengthen
the mounting hole, and make a cover plate to decrease the width. I
mounted it vertically versus horizontially, with the sensor at the
bottom. I tested the CCI and it does indeed shutoff the original LP
valve on my 94 BB BMC 37'.
http://www.pplmotorhomes.com/parts/lp-ga...rce=google
http://www.pplmotorhomes.com/parts/lp-ga...e-tell.htm
Dan NM
> shooting this?
