Leveling system solenoid
07-04-2007, 19:05
Contact Stephen Birtles for the solenoid.
Curt Sprenger
Anaheim Hills, Calif.
truitt44@... wrote:
> Scott,
> Cole Hersee is the brand of solenoid on my coach. I would think it
> would be the same on yours. Google on Cole Hersee call home office and
> see if they have a distributor in Memphis. They will send you a
> catalog if you ask.
> Howard T., Sowega, 86 PT40
> > From: "Scott Forman" <sforman@...
> > Date: 2007/07/04 Wed PM 05:16:50 EDT
> > To: WanderlodgeForum@yahoogroups.com
> > Subject: [WanderlodgeForum] Re: Leveling system solenoid
> > Thanks for the response, but this is not what I need. I need a
> > solenoid, not a relay. The large metal cylindrical things often used
> > on older ignition circuits.
> > Scott
> > --- In WanderlodgeForum@yahoogroups.com
> , Pete Masterson
> > wrote:
> > > They're by Bosch and don't get cheap, Chinese-made replacements as
> > > they'll fail quickly. Better auto parts stores should carry them,
> > but
> > > you may need to ask. Often the cheap ones are in blister packs on
> > > racks in the automotive electrical department.
> > > I bought a bunch of Bosch relays to have on hand from an eBay
> > vendor
> > > -- about $1 each or so. Genuine Bosch in a 20/30 amp-rating. This
> > URL
> > > is similar to what I purchased:
> <http://cgi.ebay.com/ebaymotors/GENUINE-B...-Amp-SPDT-
> <http://cgi.ebay.com/ebaymotors/GENUINE-B...-Amp-SPDT->
> > > Auto-Relay-10-
> > PACK_W0QQcmdZViewItemQQcategoryZ33721QQihZ002QQitemZ120136828374QQrdZ1
> > > (You may need to piece this back together)
> > > Or just search eBay for "Bosch relay". You can get them with and
> > > without sockets.
> > > This URL is for a PDF with a bunch of wiring diagrams showing
> > > operation of a Bosch relay.
> > > <http://www.dlcparts.com/images/BoschGuide.pdf>
> > > And this web site has a great description of how a relay works:
> > > <http://www.classictruckshop.com/clubs/ea...cts/bosch/
> <http://www.classictruckshop.com/clubs/ea...cts/bosch/>
> > > relay.htm>
> > > Pete Masterson
> > > '95 Blue Bird Wanderlodge WBDA 42
> > > El Sobrante CA
> > > aeonix1@...
> > > On Jul 4, 2007, at 12:46 PM, Scott Forman wrote:
> > > > I am troubleshooting my inoperative levelers, and I think I have
> > > > identified the culprit in one of the three-pin solenoids mounted
> > under
> > > > the step well. When I jump the current cross the solenoid, the
> > motor
> > > > runs, so I am pretty sure this is the problem. It is the one
> > where
> > > > the
> > > > third pin must be grounded to deliver the current. Where can I
> > find
> > > > one of these?
> > > > I bought a generic solenoid that looks similar, but it isn't
> > getting
> > > > the job done.
> > > > Thanks
> > > > Scott Forman
> > > > 86 PT38
> > > > Memphis
> > > [Non-text portions of this message have been removed]
07-05-2007, 00:20
Scott,
The one I used was for the battery charging system. It was a Cole Hersee
Intermitant, 3 pole, 12 volt, steel case, model # V30 7400
Howard Truitt
Camilla, Ga.
86 PT40
> From: "Scott Forman" <sforman@...>
> Date: 2007/07/04 Wed PM 08:26:27 EDT
> Which model did you use?
> Scott
> --- In WanderlodgeForum@yahoogroups.com, wrote:
> > Scott,
> > I ordered my Cole Hersee solenoid from Ryder Fleet Services. If this
> leveling unit came with the solenoids from HWH they may have used a
> different brand.
> > Howard, Sowega, 86 PT40
07-05-2007, 01:44
Scott,
Go to napa with the solenoid and they can match one up... I took mine there and
they came out with an exact match, it is one with the curved base, they counter
uy said it was one for a tailgate lift...
HTH
Sea Ya
Larry
NYC
84 35FCSB
----- Original Message ----
Sent: Wednesday, July 4, 2007 5:16:50 PM
Scott
--- In WanderlodgeForum@ yahoogroups. com, Pete Masterson
but
vendor
URL
> <http://cgi.ebay. com/ebaymotors/ GENUINE-BOSCH- 12V-DC-20- 30-Amp-SPDT-
> Auto-Relay-10-
PACK_W0QQcmdZViewIt emQQcategoryZ337 21QQihZ002QQitem Z120136828374QQr dZ1
> without sockets.
> <http://www.dlcparts. com/images/ BoschGuide. pdf>
> <http://www.classict ruckshop. com/clubs/ earlyburbs/ projects/ bosch/
> relay.htm>
> Pete Masterson
> El Sobrante CA
> aeonix1@...
under
motor
where
> > the
find
> > one of these?
getting
> > the job done.
> > Thanks
> > Scott Forman
> > 86 PT38
> > Memphis
#ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;}
#ygrp-mlmsg table {font-size:inherit;font:100%;}
#ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean,
sans-serif;}
#ygrp-mlmsg pre, code {font:115% monospace;}
#ygrp-mlmsg * {line-height:1.22em;}
#ygrp-text{
font-family:Georgia;
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
padding-top:10px;font-family:Verdana;font-size:77%;margin:0;}
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;}
#ygrp-actbar .left{
float:left;white-space:nowrap;}
.bld{font-weight:bold;}
#ygrp-grft{
font-family:Verdana;font-size:77%;padding:15px 0;}
#ygrp-ft{
font-family:verdana;font-size:77%;border-top:1px solid #666;
padding:5px 0;
#ygrp-mlmsg #logo{
padding-bottom:10px;}
#ygrp-vital{
background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;}
#ygrp-vital #vithd{
font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\
ercase;}
#ygrp-vital ul{
padding:0;margin:2px 0;}
#ygrp-vital ul li{
list-style-type:none;clear:both;border:1px solid #e0ecee;
#ygrp-vital ul li .ct{
font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\
ght:.5em;}
#ygrp-vital ul li .cat{
font-weight:bold;}
#ygrp-vital a {
text-decoration:none;}
#ygrp-vital a:hover{
text-decoration:underline;}
#ygrp-sponsor #hd{
color:#999;font-size:77%;}
#ygrp-sponsor #ov{
padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;}
#ygrp-sponsor #ov ul{
padding:0 0 0 8px;margin:0;}
#ygrp-sponsor #ov li{
list-style-type:square;padding:6px 0;font-size:77%;}
#ygrp-sponsor #ov li a{
text-decoration:none;font-size:130%;}
#ygrp-sponsor #nc {
background-color:#eee;margin-bottom:20px;padding:0 8px;}
#ygrp-sponsor .ad{
padding:8px 0;}
#ygrp-sponsor .ad #hd1{
font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\
#ygrp-sponsor .ad a{
#ygrp-sponsor .ad a:hover{
#ygrp-sponsor .ad p{
margin:0;}
o {font-size:0;}
.MsoNormal {
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
blockquote{margin:0 0 0 4px;}
.replbq {margin:4;}
____
Don't pick lemons.
See all the new 2007 cars at Yahoo! Autos.
http://autos.yahoo.com/new_cars.html
