Hot Feet!
07-10-2007, 03:01
Hot Feet!
I am getting warm (Hot) air around my feet in the drivers area of our FC. I
have tries to check the obvious areas, Dog house seals etc. It's not coming from the heaters. Has anyone else run into this? Is there something I am overlooking? Any Ideas appreciated. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of pattypape Sent: Tuesday, July 10, 2007 5:54 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: seat and shoulder belts Try this School Bus parts place. http://www.schoolbu <http://www.schoolbuspartsco.com/WebPages...belts.html> spartsco.com/WebPages/safetyproducts/seatbelts.html Bill 88 FC Michigan --- In WanderlodgeForum@ yahoogroups.com, "bubblerboy64" wrote: > > My 1973 has had all the belts removed. I'd like to install shoulder > and lap belts. Found a location online selling belts brackets etc. > Any one with experience on this perhaps you would give me some basic > instructions. I am mostly concerned about the anchor point for the > shoulder part of the install. I assume that the floor area is pretty > straight forward. I am hoping that I can find and use the original > anchor points on the floor. Area has been re carpeted but hopefully > I can locate and use them. I told you guys I'd have lots of > questions. Its going well however for me and I am really enjoying > the process. > > John Heckman > Central Pa > 1973 FC > [Non-text portions of this message have been removed] |
07-10-2007, 03:19
Hot Feet!
--- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler"
> > I am getting warm (Hot) air around my feet in the drivers area of our FC. I > have tries to check the obvious areas, Dog house seals etc. It's not coming > from the heaters. Has anyone else run into this? Is there something I am > overlooking? Any Ideas appreciated. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX Did you close your vent up front? Kind of silly but it can happen. > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of pattypape > Sent: Tuesday, July 10, 2007 5:54 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: seat and shoulder belts > > > > > > Try this School Bus parts place. > > http://www.schoolbu > <http://www.schoolbuspartsco.com/WebPages...tbelts.htm l> > spartsco.com/WebPages/safetyproducts/seatbelts.html > > Bill 88 FC Michigan > > --- In WanderlodgeForum@ > yahoogroups.com, "bubblerboy64" > wrote: > > > > My 1973 has had all the belts removed. I'd like to install > shoulder > > and lap belts. Found a location online selling belts brackets etc. > > Any one with experience on this perhaps you would give me some > basic > > instructions. I am mostly concerned about the anchor point for the > > shoulder part of the install. I assume that the floor area is > pretty > > straight forward. I am hoping that I can find and use the original > > anchor points on the floor. Area has been re carpeted but > hopefully > > I can locate and use them. I told you guys I'd have lots of > > questions. Its going well however for me and I am really enjoying > > the process. > > > > John Heckman > > Central Pa > > 1973 FC > > > > > > > > [Non-text portions of this message have been removed] > |
07-10-2007, 03:40
Hot Feet!
Actually I opened it to cool my feet and that helped some. The only thing
different was we couldn't run the generator so we had the windows and vents open. This may have been drawing hot engine air in. It was much worse when the radiator fan came on so it is hot air leaking from the engine someplace. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jon Sent: Tuesday, July 10, 2007 10:20 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Hot Feet! --- In WanderlodgeForum@ yahoogroups.com, "Chuck Wheeler" > > I am getting warm (Hot) air around my feet in the drivers area of our FC. I > have tries to check the obvious areas, Dog house seals etc. It's not coming > from the heaters. Has anyone else run into this? Is there something I am > overlooking? Any Ideas appreciated. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX Did you close your vent up front? Kind of silly but it can happen. > > _____ > > From: WanderlodgeForum@ yahoogroups.com > [mailto:WanderlodgeForum@ yahoogroups.com] On Behalf Of pattypape > Sent: Tuesday, July 10, 2007 5:54 AM > To: WanderlodgeForum@ yahoogroups.com > Subject: [WanderlodgeForum] Re: seat and shoulder belts > > > > > > Try this School Bus parts place. > > http://www.schoolbu > <http://www.schoolbu <http://www.schoolbuspartsco.com/WebPages...tbelts.htm> spartsco.com/WebPages/safetyproducts/seatbelts.htm l> > spartsco.com/WebPages/safetyproducts/seatbelts.html > > Bill 88 FC Michigan > > --- In WanderlodgeForum@ > yahoogroups.com, "bubblerboy64" > wrote: > > > > My 1973 has had all the belts removed. I'd like to install > shoulder > > and lap belts. Found a location online selling belts brackets etc. > > Any one with experience on this perhaps you would give me some > basic > > instructions. I am mostly concerned about the anchor point for the > > shoulder part of the install. I assume that the floor area is > pretty > > straight forward. I am hoping that I can find and use the original > > anchor points on the floor. Area has been re carpeted but > hopefully > > I can locate and use them. I told you guys I'd have lots of > > questions. Its going well however for me and I am really enjoying > > the process. > > > > John Heckman > > Central Pa > > 1973 FC > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
07-10-2007, 04:14
Hot Feet!
Chuck, have you replaced the insulation in your dog house? On my FC, that
was the culprit. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
07-10-2007, 07:23
Hot Feet!
Chuck,
I get the same right hotfoot from mine also... My isulattion is in excellent shape also... probably not much can be done unless you put the enginr in the rear...;o) Sea Ya Larry NYC 84 35FCSB ----- Original Message ---- From: Chuck Wheeler To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, July 10, 2007 11:01:06 AM Subject: [WanderlodgeForum] Hot Feet! I am getting warm (Hot) air around my feet in the drivers area of our FC. I have tries to check the obvious areas, Dog house seals etc. It's not coming from the heaters. Has anyone else run into this? Is there something I am overlooking? Any Ideas appreciated. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@ yahoogroups. com [mailto:WanderlodgeForum@ yahoogroups. com] On Behalf Of pattypape Sent: Tuesday, July 10, 2007 5:54 AM To: WanderlodgeForum@ yahoogroups. com Subject: [WanderlodgeForum] Re: seat and shoulder belts Try this School Bus parts place. http://www.schoolbu <http://www.schoolbu spartsco. com/WebPages/ safetyproducts/ seatbelts. html> spartsco.com/ WebPages/ safetyproducts/ seatbelts. html Bill 88 FC Michigan --- In WanderlodgeForum@ yahoogroups. com, "bubblerboy64" wrote: > > My 1973 has had all the belts removed. I'd like to install shoulder > and lap belts. Found a location online selling belts brackets etc. > Any one with experience on this perhaps you would give me some basic > instructions. I am mostly concerned about the anchor point for the > shoulder part of the install. I assume that the floor area is pretty > straight forward. I am hoping that I can find and use the original > anchor points on the floor. Area has been re carpeted but hopefully > I can locate and use them. I told you guys I'd have lots of > questions. Its going well however for me and I am really enjoying > the process. > > John Heckman > Central Pa > 1973 FC > [Non-text portions of this message have been removed] <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a { text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc { background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o {font-size:0;} .MsoNormal { margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> ________________________________________________________________________________\ ____Ready for the edge of your seat? Check out tonight's top picks on Yahoo! TV. http://tv.yahoo.com/ [Non-text portions of this message have been removed] |
07-10-2007, 10:19
Hot Feet!
I had the same problem, you have to have real good seals at every point of
the dog house to stop leaks when a window is open. I used high heat tape. To seal where the doghouse meets the fire wall. That was the largest leak. I also added sound / heat insulation to the are right of the throttle pedal to stop radiant heat from the radiator. With 60 mph + wind on the nose and any window open, the smallest opening lets a lot of heat through. Jim From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Chuck Wheeler Sent: Tuesday, July 10, 2007 8:41 AM To: WanderlodgeForum@yahoogroups.com Subject: RE: [WanderlodgeForum] Re: Hot Feet! Actually I opened it to cool my feet and that helped some. The only thing different was we couldn't run the generator so we had the windows and vents open. This may have been drawing hot engine air in. It was much worse when the radiator fan came on so it is hot air leaking from the engine someplace. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com Sent: Tuesday, July 10, 2007 10:20 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Hot Feet! --- In WanderlodgeForum@ yahoogroups.com, "Chuck Wheeler" > > I am getting warm (Hot) air around my feet in the drivers area of our FC. I > have tries to check the obvious areas, Dog house seals etc. It's not coming > from the heaters. Has anyone else run into this? Is there something I am > overlooking? Any Ideas appreciated. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX Did you close your vent up front? Kind of silly but it can happen. > > _____ > > From: WanderlodgeForum@ yahoogroups.com > [mailto:WanderlodgeForum@ yahoogroups.com] On Behalf Of pattypape > Sent: Tuesday, July 10, 2007 5:54 AM > To: WanderlodgeForum@ yahoogroups.com > Subject: [WanderlodgeForum] Re: seat and shoulder belts > > > > > > Try this School Bus parts place. > > http://www.schoolbu > <http://www.schoolbu <http://www.schoolbuspartsco.com/WebPages...tbelts.htm> spartsco.com/WebPages/safetyproducts/seatbelts.htm l> > spartsco.com/WebPages/safetyproducts/seatbelts.html > > Bill 88 FC Michigan > > --- In WanderlodgeForum@ > yahoogroups.com, "bubblerboy64" > wrote: > > > > My 1973 has had all the belts removed. I'd like to install > shoulder > > and lap belts. Found a location online selling belts brackets etc. > > Any one with experience on this perhaps you would give me some > basic > > instructions. I am mostly concerned about the anchor point for the > > shoulder part of the install. I assume that the floor area is > pretty > > straight forward. I am hoping that I can find and use the original > > anchor points on the floor. Area has been re carpeted but > hopefully > > I can locate and use them. I told you guys I'd have lots of > > questions. Its going well however for me and I am really enjoying > > the process. > > > > John Heckman > > Central Pa > > 1973 FC > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
07-10-2007, 11:47
Hot Feet!
I think that you are probably on to my problem Jim! I drove it far enough
to get warmed up and then set the idle up with the fan engaged. I could feel warm air moving. I have some work to do! - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of James Hutchings Sent: Tuesday, July 10, 2007 5:20 PM To: WanderlodgeForum@yahoogroups.com Subject: RE: [WanderlodgeForum] Re: Hot Feet! I had the same problem, you have to have real good seals at every point of the dog house to stop leaks when a window is open. I used high heat tape. To seal where the doghouse meets the fire wall. That was the largest leak. I also added sound / heat insulation to the are right of the throttle pedal to stop radiant heat from the radiator. With 60 mph + wind on the nose and any window open, the smallest opening lets a lot of heat through. Jim From: WanderlodgeForum@ yahoogroups.com [mailto:WanderlodgeForum@ yahoogroups.com] On Behalf Of Chuck Wheeler Sent: Tuesday, July 10, 2007 8:41 AM To: WanderlodgeForum@ yahoogroups.com Subject: RE: [WanderlodgeForum] Re: Hot Feet! Actually I opened it to cool my feet and that helped some. The only thing different was we couldn't run the generator so we had the windows and vents open. This may have been drawing hot engine air in. It was much worse when the radiator fan came on so it is hot air leaking from the engine someplace. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@ yahoogroups.com [mailto:WanderlodgeForum@ yahoogroups.com Sent: Tuesday, July 10, 2007 10:20 AM To: WanderlodgeForum@ yahoogroups.com Subject: [WanderlodgeForum] Re: Hot Feet! --- In WanderlodgeForum@ yahoogroups.com, "Chuck Wheeler" > > I am getting warm (Hot) air around my feet in the drivers area of our FC. I > have tries to check the obvious areas, Dog house seals etc. It's not coming > from the heaters. Has anyone else run into this? Is there something I am > overlooking? Any Ideas appreciated. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX Did you close your vent up front? Kind of silly but it can happen. > > _____ > > From: WanderlodgeForum@ yahoogroups.com > [mailto:WanderlodgeForum@ yahoogroups.com] On Behalf Of pattypape > Sent: Tuesday, July 10, 2007 5:54 AM > To: WanderlodgeForum@ yahoogroups.com > Subject: [WanderlodgeForum] Re: seat and shoulder belts > > > > > > Try this School Bus parts place. > > http://www.schoolbu > <http://www.schoolbu <http://www.schoolbu <http://www.schoolbuspartsco.com/WebPages...tbelts.htm> spartsco.com/WebPages/safetyproducts/seatbelts.htm> spartsco.com/WebPages/safetyproducts/seatbelts.htm l> > spartsco.com/WebPages/safetyproducts/seatbelts.html > > Bill 88 FC Michigan > > --- In WanderlodgeForum@ > yahoogroups.com, "bubblerboy64" > wrote: > > > > My 1973 has had all the belts removed. I'd like to install > shoulder > > and lap belts. Found a location online selling belts brackets etc. > > Any one with experience on this perhaps you would give me some > basic > > instructions. I am mostly concerned about the anchor point for the > > shoulder part of the install. I assume that the floor area is > pretty > > straight forward. I am hoping that I can find and use the original > > anchor points on the floor. Area has been re carpeted but > hopefully > > I can locate and use them. I told you guys I'd have lots of > > questions. Its going well however for me and I am really enjoying > > the process. > > > > John Heckman > > Central Pa > > 1973 FC > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
