Awning Problem
07-16-2007, 06:23
Awning Problem
Dru. I have had problems from lack of use and dirt and grime on the front
arm on my coach. ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
07-16-2007, 06:33
Awning Problem
Hello,
I am wanting to know if anyone has experienced problems with the telescoping portion of the ZipDee awning not extending. Mine is very much stuck, unless there is a release I am not seeing. Not really signs of corrosion, but it does not budge even the slightest. Thanks! Dru and Debora 1983 FC 35 RB |
07-16-2007, 06:35
Awning Problem
Dru. I have had trouble with my front arm sticking from lack of use and
grime. When it sticks i usually take a block of wood and a good size hammer and give it a good smack at the roller and it will come loose. When you get it loose you need to take the arm apart and give it a good cleaning especially the lower part and lube with silicone lube. Paul Downey Versailles Ky 83PT35 Our Rollin Home ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
07-16-2007, 08:49
Awning Problem
Yes, I did. And let me tell you it was not easy getting them apart.
Because they are disimilar metals the aluminum was corroded around the stainless steel. (Some call it "galling") Here's what I did to separate them. I removed the entire arm and then removed the bottom portion (grooved) that slides inside the arm. I found a piece of metal stock, (square) aluminum, that fit inside the arm. I heated the entire arm and started pounding. I repeated this step until I even considered buying a new one. (You'll need a vise and some rags to hold it in place) I used lots of penetrant. It took some serious pounding but it finally started to move. Continued pounding until it came apart, cleaned and lulubed it. It works fine now. Keith 84FC35 --- In WanderlodgeForum@yahoogroups.com, "D" > > Hello, > > I am wanting to know if anyone has experienced problems with the > telescoping portion of the ZipDee awning not extending. Mine is very > much stuck, unless there is a release I am not seeing. Not really > signs of corrosion, but it does not budge even the slightest. > Thanks! > > Dru and Debora > 1983 FC 35 RB > |
07-16-2007, 09:23
Awning Problem
Start soaking with PB Blaster, after a few days employ an electric heat gun to
the aluminum sleeve, the interior pole is steel. Not the best mix of materials but that's what they do. I had ZipDee install new arm assys. on my 83 FC, kinda costly, might be worth it to spend some time soaking and heating. Mike Hohnstein Germantown, Wl 83FC35rb ----- Original Message ----- From: D To: WanderlodgeForum@yahoogroups.com Sent: Monday, July 16, 2007 12:33 PM Subject: [WanderlodgeForum] Awning Problem Hello, I am wanting to know if anyone has experienced problems with the telescoping portion of the ZipDee awning not extending. Mine is very much stuck, unless there is a release I am not seeing. Not really signs of corrosion, but it does not budge even the slightest. Thanks! Dru and Debora 1983 FC 35 RB [Non-text portions of this message have been removed] |
07-16-2007, 09:46
Awning Problem
Not to be the spoiler but I tried the solvent/PB blaster approach.
All it did was run down the inside of the ss steel tube. IMHO there are only two ways to fix it. Heat (I used a propane torch)and brute force or a credit card. Keith 84FC35 --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Start soaking with PB Blaster, after a few days employ an electric heat gun to the aluminum sleeve, the interior pole is steel. Not the best mix of materials but that's what they do. I had ZipDee install new arm assys. on my 83 FC, kinda costly, might be worth it to spend some time soaking and heating. > Mike Hohnstein > Germantown, Wl > 83FC35rb > ----- Original Message ----- > From: D > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, July 16, 2007 12:33 PM > Subject: [WanderlodgeForum] Awning Problem > > > Hello, > > I am wanting to know if anyone has experienced problems with the > telescoping portion of the ZipDee awning not extending. Mine is very > much stuck, unless there is a release I am not seeing. Not really > signs of corrosion, but it does not budge even the slightest. > Thanks! > > Dru and Debora > 1983 FC 35 RB > > > > > > [Non-text portions of this message have been removed] > |
07-16-2007, 10:16
Awning Problem
I had the same problem...couldn't get one of the arms to move at all.
Called Zip Dee and had both pieces shipped to me. Cost was about 70 bucks each piece. Bob Lawrence 84 PT36 Taocma, Wa. > > > Hello, > > > > I am wanting to know if anyone has experienced problems with the > > telescoping portion of the ZipDee awning not extending. Mine is very > > much stuck, unless there is a release I am not seeing. Not really > > signs of corrosion, but it does not budge even the slightest. > > Thanks! > > > > Dru and Debora > > 1983 FC 35 RB > > > |
07-16-2007, 13:49
Awning Problem
Be also certaian that the arm is not bent from a "hit"
I spent a lot of time with this until I finally realized the arm was bent from an occurance unknown. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WLWB41 [Non-text portions of this message have been removed] |
07-17-2007, 04:14
Awning Problem
I really appreciate the response on this problem and I am glad I'm not the only
one, this time. Thanks to all. I plan to try the tricks before I buy. Thank All, Dru and Debora '83 FC 35 RB antique405@... wrote: Dru. I have had trouble with my front arm sticking from lack of use and grime. When it sticks i usually take a block of wood and a good size hammer and give it a good smack at the roller and it will come loose. When you get it loose you need to take the arm apart and give it a good cleaning especially the lower part and lube with silicone lube. Paul Downey Versailles Ky 83PT35 Our Rollin Home ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] Dru and Debora Corpus Christi, TX 1983 FC 35 RB [Non-text portions of this message have been removed] |
