alternator issues
07-31-2007, 01:11
alternator issues
Flex gear wrenches are the busiest tools in my collection. The real fix for the
idler bracket is welding the nuts to the bracket. This reduces the number of hands needed to adjust the idler. MH ----- Original Message ----- From: John To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, July 31, 2007 1:57 AM Subject: [WanderlodgeForum] Re: alternator issues John, One tool that I found very valuable in removing the idler pulley and it is also handy when adjusting new belt tension on the idler pulley also, is a hinged box end ratchet wrench, this will allow you to do all of the adjusting and removal of the backside nut while you are positioned in front of the engine, of coarse this is if your 'Bird is equipped with a swing radiator. I can't bend my wrist as far as I used to and reaching back behind the mounting bracket, from underneath in my case would have required another person and I was by myself and my beagle was of no help at all...as usual, other than moral support. On my 'Bird I was able to see the idler pulley and its destroyed bearings from under the engine, while I laid on the ground looking up, there was a small area that allowed me to see it. You can see the condition of my old idler pulley by going to the link for my trip photos in my signature below. You can also view details of my problem solving of the idler pulley in my trip BLOG link. John Finn Finn's Inn Express '82 35FCRB BLUEBIRD WANDERLODGE "ON THE ROAD IN THOMPSON, ILL." TO SEE THE PHOTOS OF MY 2007 SUMMER TRIP GO TO; http://www.pbase.com/iamflagman/image/80800665 CHECK OUT MY BLOG AT; http://iamflagman.blogspot.com/ WELCOME TO THE "FINN'S INN Express" REMODELING ADVENTURE TO VISIT, CLICK ON THE LINK BELOW http://www.pbase.com/image/24977457 HOPKINS, SOUTH CAROLINA ////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > I am thinking along the same line Ernie because it comes and goes. > Obviously this will need to be attended too. I have some time at the > end of the week so stand by I may need some coaching on this. I am > pretty good at taking things apart and for the most part getting them > back together but it does seem that on a lot of these projects there > is that little bit of information or tool that you need to get it > done right. And again I appreciate all that you guys have done for me > from the beginning. > John Heckman > 1973 FC > Shippensburg Pa > > > > > > > John, I wonder if your idler pully is failing? John Finn had one of > his go > > out on his recent trip north. They are readily available. > > > > Ernie Ekberg > > 83PT40 > > Livingston, Mt > > > > > > > > > > ************************************** Get a sneak peek of the all- > new AOL at > > http://discover.aol.com/memed/aolcom30tour > > > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed] |
07-31-2007, 11:11
alternator issues
Mike,
Who makes a good set? David Brady Mike Hohnstein wrote: > > Flex gear wrenches are the busiest tools in my collection. The real > fix for the idler bracket is welding the nuts to the bracket. This > reduces the number of hands needed to adjust the idler. > MH > ----- Original Message ----- > From: John > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, July 31, 2007 1:57 AM > Subject: [WanderlodgeForum] Re: alternator issues > > John, > > One tool that I found very valuable in removing the idler pulley and > it is also handy when adjusting new belt tension on the idler pulley > also, is a hinged box end ratchet wrench, this will allow you to do > all of the adjusting and removal of the backside nut while you are > positioned in front of the engine, of coarse this is if your 'Bird is > equipped with a swing radiator. I can't bend my wrist as far as I > used to and reaching back behind the mounting bracket, from > underneath in my case would have required another person and I was by > myself and my beagle was of no help at all...as usual, other than > moral support. > > On my 'Bird I was able to see the idler pulley and its destroyed > bearings from under the engine, while I laid on the ground looking > up, there was a small area that allowed me to see it. You can see the > condition of my old idler pulley by going to the link for my trip > photos in my signature below. > > You can also view details of my problem solving of the idler pulley > in my trip BLOG link. > > John Finn > Finn's Inn Express > '82 35FCRB > BLUEBIRD WANDERLODGE > "ON THE ROAD IN THOMPSON, ILL." > TO SEE THE PHOTOS OF MY 2007 SUMMER TRIP GO TO; > http://www.pbase.com/iamflagman/image/80800665 > <http://www.pbase.com/iamflagman/image/80800665> > CHECK OUT MY BLOG AT; > http://iamflagman.blogspot.com/ <http://iamflagman.blogspot.com/> > WELCOME TO THE "FINN'S INN Express" REMODELING ADVENTURE > TO VISIT, CLICK ON THE LINK BELOW > http://www.pbase.com/image/24977457 <http://www.pbase.com/image/24977457> > HOPKINS, SOUTH CAROLINA > > ////////////////////////////////////////// > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > I am thinking along the same line Ernie because it comes and goes. > > Obviously this will need to be attended too. I have some time at > the > > end of the week so stand by I may need some coaching on this. I am > > pretty good at taking things apart and for the most part getting > them > > back together but it does seem that on a lot of these projects > there > > is that little bit of information or tool that you need to get it > > done right. And again I appreciate all that you guys have done for > me > > from the beginning. > > John Heckman > > 1973 FC > > Shippensburg Pa > > > > > > > > > > > > John, I wonder if your idler pully is failing? John Finn had one > of > > his go > > > out on his recent trip north. They are readily available. > > > > > > Ernie Ekberg > > > 83PT40 > > > Livingston, Mt > > > > > > > > > > > > > > > ************************************** Get a sneak peek of the > all- > > new AOL at > > > http://discover.aol.com/memed/aolcom30tour > <http://discover.aol.com/memed/aolcom30tour> > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > [Non-text portions of this message have been removed] > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.10.25/926 - Release Date: 7/29/2007 11:14 PM > [Non-text portions of this message have been removed] |
07-31-2007, 12:52
alternator issues
All made in the Pacific Rim, go with the good price. I got mine from Northern
Hydraulics in Milwaukee. MH ----- Original Message ----- From: David Brady To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, July 31, 2007 5:11 PM Subject: Re: [WanderlodgeForum] Re: alternator issues Mike, Who makes a good set? David Brady Mike Hohnstein wrote: > > Flex gear wrenches are the busiest tools in my collection. The real > fix for the idler bracket is welding the nuts to the bracket. This > reduces the number of hands needed to adjust the idler. > MH > ----- Original Message ----- > From: John > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, July 31, 2007 1:57 AM > Subject: [WanderlodgeForum] Re: alternator issues > > John, > > One tool that I found very valuable in removing the idler pulley and > it is also handy when adjusting new belt tension on the idler pulley > also, is a hinged box end ratchet wrench, this will allow you to do > all of the adjusting and removal of the backside nut while you are > positioned in front of the engine, of coarse this is if your 'Bird is > equipped with a swing radiator. I can't bend my wrist as far as I > used to and reaching back behind the mounting bracket, from > underneath in my case would have required another person and I was by > myself and my beagle was of no help at all...as usual, other than > moral support. > > On my 'Bird I was able to see the idler pulley and its destroyed > bearings from under the engine, while I laid on the ground looking > up, there was a small area that allowed me to see it. You can see the > condition of my old idler pulley by going to the link for my trip > photos in my signature below. > > You can also view details of my problem solving of the idler pulley > in my trip BLOG link. > > John Finn > Finn's Inn Express > '82 35FCRB > BLUEBIRD WANDERLODGE > "ON THE ROAD IN THOMPSON, ILL." > TO SEE THE PHOTOS OF MY 2007 SUMMER TRIP GO TO; > http://www.pbase.com/iamflagman/image/80800665 > <http://www.pbase.com/iamflagman/image/80800665> > CHECK OUT MY BLOG AT; > http://iamflagman.blogspot.com/ <http://iamflagman.blogspot.com/> > WELCOME TO THE "FINN'S INN Express" REMODELING ADVENTURE > TO VISIT, CLICK ON THE LINK BELOW > http://www.pbase.com/image/24977457 <http://www.pbase.com/image/24977457> > HOPKINS, SOUTH CAROLINA > > ////////////////////////////////////////// > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > I am thinking along the same line Ernie because it comes and goes. > > Obviously this will need to be attended too. I have some time at > the > > end of the week so stand by I may need some coaching on this. I am > > pretty good at taking things apart and for the most part getting > them > > back together but it does seem that on a lot of these projects > there > > is that little bit of information or tool that you need to get it > > done right. And again I appreciate all that you guys have done for > me > > from the beginning. > > John Heckman > > 1973 FC > > Shippensburg Pa > > > > > > > > > > > > John, I wonder if your idler pully is failing? John Finn had one > of > > his go > > > out on his recent trip north. They are readily available. > > > > > > Ernie Ekberg > > > 83PT40 > > > Livingston, Mt > > > > > > > > > > > > > > > ************************************** Get a sneak peek of the > all- > > new AOL at > > > http://discover.aol.com/memed/aolcom30tour > <http://discover.aol.com/memed/aolcom30tour> > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > [Non-text portions of this message have been removed] > > > ---------------------------------------------------------- > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.10.25/926 - Release Date: 7/29/2007 11:14 PM > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
