Fuel guage or sending unit?
08-01-2007, 06:21
Chet, I believe your sending unit is at the foot of the bed in the aisle.
You can pull your carpet and pad back and see the plate. Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour [Non-text portions of this message have been removed] |
08-01-2007, 10:05
Last week I filled up with fuel on my way to SPI and about an hour
later the fuel guage would occasionaly flicker between full and 3/4 full. This went on for about half an hour then the needle went to full empty and has not moved for the last 700 miles. Is this a bad guage or sending unit or some other problem. All other guages are working fine. If this is a sending unit does anyone know where to look for the access panel. My guess is somewhere in front of the night stand between the twin beds. Has anyone done a replacement on a similar coach? Chet Geist 1981 FC33 SB, Austin, Texas |
08-01-2007, 10:09
Aww, man Chet! You went to SPI without the rest of us?!
=8^) Mike Bulriss 1991 WB40 "texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "chetgeist" > > Last week I filled up with fuel on my way to SPI and about an hour > later the fuel guage would occasionaly flicker between full and 3/4 > full. This went on for about half an hour then the needle went to full > empty and has not moved for the last 700 miles. Is this a bad guage or > sending unit or some other problem. All other guages are working fine. > If this is a sending unit does anyone know where to look for the access > panel. My guess is somewhere in front of the night stand between the > twin beds. Has anyone done a replacement on a similar coach? > > Chet Geist > 1981 FC33 SB, Austin, Texas > |
