Macerators
08-08-2007, 11:24
Macerators
Hi folks,
Has anyone installed a macerating pump on a Bird? I'm looking at the Sani-Con 5800 (http://tinyurl.com/355ywu) and would love to hear any ideas on where one might install it. The pump would need to mount within a few feet of my drain valve, but on my '86 PT-40 I don't see any place to actually mount it and store the attached drain hose while maintaining clearance under the coach. Any thoughts? Where and how have others installed these systems, and which brand(s) of pump did you use? I simply want to be able to drain the tanks anywhere I go. Being able to pump the waste up to 350 feet away would make it easy to dump at home, at relatives' homes, etc. -Ryan '86 PT-40 8V92 Tri-Cities, WA |
08-08-2007, 12:27
Macerators
Ryan,
Bob Loomis has one installed on his Pt-40. He is not online now but in the next day or two I am sure he will chime in. His installation looked very nice with a switch at the dump station I believe. Al Johnson '96 BMC B10 Fayette, West Virginia heading out in the am going toward NC --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Hi folks, > > Has anyone installed a macerating pump on a Bird? I'm looking at the > Sani-Con 5800 (http://tinyurl.com/355ywu) and would love to hear any > ideas on where one might install it. The pump would need to mount > within a few feet of my drain valve, but on my '86 PT-40 I don't see > any place to actually mount it and store the attached drain hose while > maintaining clearance under the coach. > > Any thoughts? Where and how have others installed these systems, and > which brand(s) of pump did you use? > > I simply want to be able to drain the tanks anywhere I go. Being able > to pump the waste up to 350 feet away would make it easy to dump at > home, at relatives' homes, etc. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > |
08-08-2007, 13:02
Macerators
Ryan,
I had one on my GMC and really liked it. I bought the FloJet RV Waste Pump Kit and used it on Pokey and liked it as well. The complications of the transferable system were far outweighted by the ability to dump in my septic system. I tapped into the 12V outlets at the inverter/charger and it worked out fine ('81 FC35, yours is probably different). They really dislike plastics, if you catch my drift. Doug Engel, Gunnison, CO. 1981 FC35SB usta be, "Pokey", now lost in the world of Skoolie conversion, "Hormone Derange". Al Ryan, Bob Loomis has one installed on his Pt-40. He is not online now but in the next day or two I am sure he will chime in. His installation looked very nice with a switch at the dump station I believe. Al Johnson '96 BMC B10 Fayette, West Virginia heading out in the am going toward NC --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Hi folks, > > Has anyone installed a macerating pump on a Bird? I'm looking at the > Sani-Con 5800 (http://tinyurl.com/355ywu) and would love to hear any > ideas on where one might install it. The pump would need to mount > within a few feet of my drain valve, but on my '86 PT-40 I don't see > any place to actually mount it and store the attached drain hose while > maintaining clearance under the coach. > > Any thoughts? Where and how have others installed these systems, and > which brand(s) of pump did you use? > > I simply want to be able to drain the tanks anywhere I go. Being able > to pump the waste up to 350 feet away would make it easy to dump at > home, at relatives' homes, etc. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > Doug Engel, Gunnison, CO. Bird Usta Be, now 1990 Thomas Skoolie, "Hormone Derange" --------------------------------- Choose the right car based on your needs. Check out Yahoo! Autos new Car Finder tool. [Non-text portions of this message have been removed] |
08-08-2007, 13:21
Macerators
Let us know how it works out...
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Aug 8, 2007, at 4:24 PM, Ryan Wright wrote: > Hi folks, > > Has anyone installed a macerating pump on a Bird? I'm looking at the > Sani-Con 5800 (http://tinyurl.com/355ywu) and would love to hear any > ideas on where one might install it. <snip> [Non-text portions of this message have been removed] |
08-09-2007, 02:16
Macerators
I was interested in being able to empty my holding tanks during stays
at friend's homes, but couldn't see an easy way to alter my system to use the RV Sani-con 5800 series. When I saw a new RV Sani-Con System Tank Buddy Model 8102 for sale on eBay, I decided to try that one. It comes built into a portable plastic tool box, primarily for use on 5th wheels, and trailers, and has worked great! Seller included 2- 25 foot 1" diameter hoses. Anywhere I can find a sewer trap; I can cleanly empty my tanks. I liked the system so much, that when I found a 5800 for sale at a great price, I bought that one as a possible future project. If you decide to go that route, I'd be interested in how you decide to mount it. Michael Kramer 1986 PT40 8V92 San Diego, CA --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Hi folks, > > Has anyone installed a macerating pump on a Bird? I'm looking at the > Sani-Con 5800 (http://tinyurl.com/355ywu) and would love to hear any > ideas on where one might install it. The pump would need to mount > within a few feet of my drain valve, but on my '86 PT-40 I don't see > any place to actually mount it and store the attached drain hose while > maintaining clearance under the coach. > > Any thoughts? Where and how have others installed these systems, and > which brand(s) of pump did you use? > > I simply want to be able to drain the tanks anywhere I go. Being able > to pump the waste up to 350 feet away would make it easy to dump at > home, at relatives' homes, etc. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > |
