					Winter approaches
					08-15-2007, 05:10
				 Post: #1 | |||
| Winter approaches
					Hard to believe cold weather will be here soon. Just a few more weeks and I'll be needing heat at night. I need advice on surviving my first winter and I want to get a jump on any work I'll need to do to the coach, so I can do it while it's still warm outside. I'll be living in my coach all winter with 50 amp service available. I have many questions: 1. Where can I buy new electric heaters? At least a couple of mine do not work properly. 2. What might freeze or break, and how do I prevent it? 3. Are my holding tanks heated, and how? 4. The interior will be kept warm 24/7 so fresh water and plumbing should be OK - or will it? 5. There are thermostats with funky electric heaters under the beds and some of the plumbing appears to be wrapped in that heat tape stuff - any advice on dealing with this? 6. How do I dump my holding tanks when it's freezing outside? Same as usual? I'd planned on macerating into a sewer line but will the pump be OK? 7. How do I check my engine & battery heaters, & how do I get the 8V92 and the Yanmar genset started in the dead of winter? 8. Any other winter advice from the full timers? 9. Winter driving advice? I won't be doing much and will try to avoid snow, but may hit some visiting relatives in December. Will the PT-40 generally walk over it, or will I be prone to sliding off the road like I would in a pickup? I've never driven anything this heavy in the snow. Winter temps here aren't severe. Typical nights are in the 30's, but we do see a couple of weeks of 10-20 degree nights and, every few years, we get some 0 degree stuff. I've lived here over 25 years and can only recall one time temps dipped much below 0. -Ryan '86 PT-40 8V92 Tri-Cities, WA | |||
					08-15-2007, 05:29
				 Post: #2 | |||
| Winter approaches
					Ryan, MOVE TO FLORIDA! Jim Riordan 88 WBLW XXV Stuart, Fl. Ryan Wright Hard to believe cold weather will be here soon. Just a few more weeks and I'll be needing heat at night. I need advice on surviving my first winter and I want to get a jump on any work I'll need to do to the coach, so I can do it while it's still warm outside. I'll be living in my coach all winter with 50 amp service available. I have many questions: 1. Where can I buy new electric heaters? At least a couple of mine do not work properly. 2. What might freeze or break, and how do I prevent it? 3. Are my holding tanks heated, and how? 4. The interior will be kept warm 24/7 so fresh water and plumbing should be OK - or will it? 5. There are thermostats with funky electric heaters under the beds and some of the plumbing appears to be wrapped in that heat tape stuff - any advice on dealing with this? 6. How do I dump my holding tanks when it's freezing outside? Same as usual? I'd planned on macerating into a sewer line but will the pump be OK? 7. How do I check my engine & battery heaters, & how do I get the 8V92 and the Yanmar genset started in the dead of winter? 8. Any other winter advice from the full timers? 9. Winter driving advice? I won't be doing much and will try to avoid snow, but may hit some visiting relatives in December. Will the PT-40 generally walk over it, or will I be prone to sliding off the road like I would in a pickup? I've never driven anything this heavy in the snow. Winter temps here aren't severe. Typical nights are in the 30's, but we do see a couple of weeks of 10-20 degree nights and, every few years, we get some 0 degree stuff. I've lived here over 25 years and can only recall one time temps dipped much below 0. -Ryan '86 PT-40 8V92 Tri-Cities, WA --------------------------------- Ready for the edge of your seat? Check out tonight's top picks on Yahoo! TV. [Non-text portions of this message have been removed] | |||
					08-15-2007, 06:03
				 Post: #3 | |||
| Winter approaches
					On Aug 15, 2007, at 10:10 AM, Ryan Wright wrote: > <snip> > 1. Where can I buy new electric heaters? At least a couple of mine do > not work properly. If you're referring to the under-cabinet heaters, my coach seems to have the Perfectoe® under cabinet heaters. See info at this url: <http://www.cadetco.com/show_product.php?prodid=1005> Search the Internet for a good price. > 2. What might freeze or break, and how do I prevent it? Your coach is 9 years older than mine ... so I'm not sure. If you have a basement heater, be sure to turn it on. Get a thermometer that registers the high and low so you can check the extremes (and adjust the basement thermostat accordingly). I encountered some freezing temperatures in Denver this spring and had no difficulties beyond starting the engine when we decided to get the heck out of there.... > 3. Are my holding tanks heated, and how? Well, there in the basement -- that helps. Dump valves _can_ freeze up, though. > 4. The interior will be kept warm 24/7 so fresh water and plumbing > should be OK - or will it? It appears to be in my coach. I note that the '95 is pretty well insulated. While re-flooring my coach, I opened the wire chases and I was surprised to discover that some water pipes near the kitchen are wrapped with some-sort of electric stuff. Don't know what turns it on or how. > 5. There are thermostats with funky electric heaters under the beds > and some of the plumbing appears to be wrapped in that heat tape stuff > - any advice on dealing with this? Make sure it isn't deteriorated. Another 'bird owner had a (literal) melt down. > 6. How do I dump my holding tanks when it's freezing outside? Same as > usual? I'd planned on macerating into a sewer line but will the pump > be OK? I didn't have trouble in Denver's freezing temps -- but it was spring, not the heart of winter. I'd put the macerator pump into a warmer place in the basement. Have a hair dryer handy. Worst case, head south. > 7. How do I check my engine & battery heaters, & how do I get the 8V92 > and the Yanmar genset started in the dead of winter? The Series 60 was a bear to get started -- and I had the block heater on for 24 hours. It eventually started ... then stumbled on for quite some time. I was glad I'd been on shore power as I could use the bypass switch to join the house and engine batteries (and all were fully charged). The generator, however, wasn't all that bad. The glow plugs help the starting and by holding them on for an extra 10 seconds or so (about 40 seconds instead of about 30), then it kicked right over. > 8. Any other winter advice from the full timers? Head south -- as far south as you can go ... or to coastal California/ Oregon. > 9. Winter driving advice? I won't be doing much and will try to avoid > snow, but may hit some visiting relatives in December. Will the PT-40 > generally walk over it, or will I be prone to sliding off the road > like I would in a pickup? I've never driven anything this heavy in the > snow. Well, one FC is being 'parted out' because it flipped onto its side while entering a freeway on-ramp. Take it _really_ easy. I haven't had much experience driving my bird in the snow. I don't want the experience... > > Winter temps here aren't severe. Typical nights are in the 30's, but > we do see a couple of weeks of 10-20 degree nights and, every few > years, we get some 0 degree stuff. I've lived here over 25 years and > can only recall one time temps dipped much below 0. It's a little warmer here, but we do get bouts of "hard freezes" some winters ... but my spring stay in Denver dropped into the 20s or teens most nights but was up to as high as 40 during the day. I also spent 10 days near Ft. Bragg CA during a January freeze (nights in the 20s and low 30s, days in the 40s). Had no issues with the coach due to the weather. There are differences due to the relative ages of our coaches ... but I'm guessing there's a lot of similarities as well. Mostly use common sense, insulate what you can, and keep the heat on. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... [Non-text portions of this message have been removed] | |||
					08-15-2007, 12:01
				 Post: #4 | |||
| Winter approaches
					----- Original Message ----- From: Ryan Wright To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Wednesday, August 15, 2007 12:10 PM Subject: [WanderlodgeForum] Winter approaches Ryan I replace my bathroon heater bought it at Grainger Bob Loomas 1985 PT 36 Hard to believe cold weather will be here soon. Just a few more weeks and I'll be needing heat at night. I need advice on surviving my first winter and I want to get a jump on any work I'll need to do to the coach, so I can do it while it's still warm outside. I'll be living in my coach all winter with 50 amp service available. I have many questions: 1. Where can I buy new electric heaters? At least a couple of mine do not work properly. 2. What might freeze or break, and how do I prevent it? 3. Are my holding tanks heated, and how? 4. The interior will be kept warm 24/7 so fresh water and plumbing should be OK - or will it? 5. There are thermostats with funky electric heaters under the beds and some of the plumbing appears to be wrapped in that heat tape stuff - any advice on dealing with this? 6. How do I dump my holding tanks when it's freezing outside? Same as usual? I'd planned on macerating into a sewer line but will the pump be OK? 7. How do I check my engine & battery heaters, & how do I get the 8V92 and the Yanmar genset started in the dead of winter? 8. Any other winter advice from the full timers? 9. Winter driving advice? I won't be doing much and will try to avoid snow, but may hit some visiting relatives in December. Will the PT-40 generally walk over it, or will I be prone to sliding off the road like I would in a pickup? I've never driven anything this heavy in the snow. Winter temps here aren't severe. Typical nights are in the 30's, but we do see a couple of weeks of 10-20 degree nights and, every few years, we get some 0 degree stuff. I've lived here over 25 years and can only recall one time temps dipped much below 0. -Ryan '86 PT-40 8V92 Tri-Cities, WA [Non-text portions of this message have been removed] | |||
					08-15-2007, 13:13
				 Post: #5 | |||
| Winter approaches
					Ryan, One of the common problems is the shower drain freezing. Since it has a P trap it is very vulnerable. Heaters are one answer, but I would suggest a little pink stuff after your morning shower to insure a non-freeze condition the next morning. I believe Ernie Ekberg suffered that problem last winter. Once frozen it is a real pain to thaw it out. Other than that, wherever there is water there needs to be some system for preventing freeze-ups. Heat tapes, area heaters, tank heaters, etc. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "bloomas" wrote: > > > ----- Original Message ----- > From: Ryan Wright > To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com > Sent: Wednesday, August 15, 2007 12:10 PM > Subject: [WanderlodgeForum] Winter approaches > Ryan I replace my bathroon heater bought it at Grainger > Bob Loomas 1985 PT 36 > > > > Hard to believe cold weather will be here soon. Just a few more weeks > and I'll be needing heat at night. > > I need advice on surviving my first winter and I want to get a jump on > any work I'll need to do to the coach, so I can do it while it's still > warm outside. I'll be living in my coach all winter with 50 amp > service available. I have many questions: > > 1. Where can I buy new electric heaters? At least a couple of mine do > not work properly. > 2. What might freeze or break, and how do I prevent it? > 3. Are my holding tanks heated, and how? > 4. The interior will be kept warm 24/7 so fresh water and plumbing > should be OK - or will it? > 5. There are thermostats with funky electric heaters under the beds > and some of the plumbing appears to be wrapped in that heat tape stuff > - any advice on dealing with this? > 6. How do I dump my holding tanks when it's freezing outside? Same as > usual? I'd planned on macerating into a sewer line but will the pump > be OK? > 7. How do I check my engine & battery heaters, & how do I get the 8V92 > and the Yanmar genset started in the dead of winter? > 8. Any other winter advice from the full timers? > 9. Winter driving advice? I won't be doing much and will try to avoid > snow, but may hit some visiting relatives in December. Will the PT-40 > generally walk over it, or will I be prone to sliding off the road > like I would in a pickup? I've never driven anything this heavy in the > snow. > > Winter temps here aren't severe. Typical nights are in the 30's, but > we do see a couple of weeks of 10-20 degree nights and, every few > years, we get some 0 degree stuff. I've lived here over 25 years and > can only recall one time temps dipped much below 0. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > > > > > [Non-text portions of this message have been removed] > | |||
					08-15-2007, 14:24
				 Post: #6 | |||
| Winter approaches
					Hi Ryan, We head south in Nov (finally retire), but maybe I can tell you what we do. We live in our rig fulltime for the past 4 years and have had some freezing temps here in tacky Tacoma (Lakewood). > > 1. Where can I buy new electric heaters? At least a couple of mine do not work properly. I disconnected mine cause didn't trust them (age thing). Since we live in it fulltime, the heat is adaquate to keep the pipes warm. > 2. What might freeze or break, and how do I prevent it? Anything outside can freeze. On ours the shower drain pipes are not foamed so any water in it will freeze at the drains. Put in some pink rv stuff after each use of sinks and shower and it will help. > 3. Are my holding tanks heated, and how? I would guess your tanks are like mine..none heated. They have heating pads (120v) that can be placed on the bottom of the tank. Have to scrape away the foam to install them tho. > 4. The interior will be kept warm 24/7 so fresh water and plumbing > should be OK - or will it? Should be, except for bathroom..may have to leave door open a crack or put a vent in the bottom of door. > 5. There are thermostats with funky electric heaters under the beds > and some of the plumbing appears to be wrapped in that heat tape stuff > - any advice on dealing with this? I disconnected them because of age and don't trust the heat tapes that are this old. > 6. How do I dump my holding tanks when it's freezing outside? Same as usual? I'd planned on macerating into a sewer line but will the pump be OK? Drain might not be able to be pulled open. Have a hair dryer handy. > 7. How do I check my engine & battery heaters, & how do I get the 8V92 > and the Yanmar genset started in the dead of winter? My 6v92 has an engine heater switch behind bed. I have put an electric heating pad over genset to keep it warm and didn't have any problem starting it. > 8. Any other winter advice from the full timers? Maybe if you can, could you put something around the bottom of the rig to keep the cold air from whistling through underneath? > 9. Winter driving advice? I won't be doing much and will try to avoid > snow, but may hit some visiting relatives in December. Will the PT- 40 > generally walk over it, or will I be prone to sliding off the road > like I would in a pickup? I've never driven anything this heavy in the > snow. Hit snow last winter in Anacortes..worst storm we had here in years. Had to get back to Lakewood, so went for it. Dumped the tag air, putting more weight on drives and went down I-5 passing cars that couldn't get traction and were headed for the ditch...scary..but no problem Bob Lawrence 84 PT36 Tacoma, Wa. > > Winter temps here aren't severe. Typical nights are in the 30's, but > we do see a couple of weeks of 10-20 degree nights and, every few > years, we get some 0 degree stuff. I've lived here over 25 years and > can only recall one time temps dipped much below 0. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > | |||
					08-15-2007, 15:36
				 Post: #7 | |||
| Winter approaches
					Due to our winter trips north, I got some two part foam from Grainger and sprayed it up around the trap and other places. When dry it looks like the original foam insulation. It cures in about 15 sec. So far been in -5 with nothing frozen. I will have to cut it out if I ever have to get at the trap. I used the same stuff to re-insulate after we changed the power steering unit. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gardner Yeaw Sent: Wednesday, August 15, 2007 8:13 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Winter approaches Ryan, One of the common problems is the shower drain freezing. Since it has a P trap it is very vulnerable. Heaters are one answer, but I would suggest a little pink stuff after your morning shower to insure a non-freeze condition the next morning. I believe Ernie Ekberg suffered that problem last winter. Once frozen it is a real pain to thaw it out. Other than that, wherever there is water there needs to be some system for preventing freeze-ups. Heat tapes, area heaters, tank heaters, etc. Gardner 78FC33 --- In WanderlodgeForum@ yahoogroups.com, "bloomas" wrote: > > > ----- Original Message ----- > From: Ryan Wright > To: WanderlodgeForum@ yahoogroups.com ; wanderlodge@ > Sent: Wednesday, August 15, 2007 12:10 PM > Subject: [WanderlodgeForum] Winter approaches > Ryan I replace my bathroon heater bought it at Grainger > Bob Loomas 1985 PT 36 > > > > Hard to believe cold weather will be here soon. Just a few more weeks > and I'll be needing heat at night. > > I need advice on surviving my first winter and I want to get a jump on > any work I'll need to do to the coach, so I can do it while it's still > warm outside. I'll be living in my coach all winter with 50 amp > service available. I have many questions: > > 1. Where can I buy new electric heaters? At least a couple of mine do > not work properly. > 2. What might freeze or break, and how do I prevent it? > 3. Are my holding tanks heated, and how? > 4. The interior will be kept warm 24/7 so fresh water and plumbing > should be OK - or will it? > 5. There are thermostats with funky electric heaters under the beds > and some of the plumbing appears to be wrapped in that heat tape stuff > - any advice on dealing with this? > 6. How do I dump my holding tanks when it's freezing outside? Same as > usual? I'd planned on macerating into a sewer line but will the pump > be OK? > 7. How do I check my engine & battery heaters, & how do I get the 8V92 > and the Yanmar genset started in the dead of winter? > 8. Any other winter advice from the full timers? > 9. Winter driving advice? I won't be doing much and will try to avoid > snow, but may hit some visiting relatives in December. Will the PT-40 > generally walk over it, or will I be prone to sliding off the road > like I would in a pickup? I've never driven anything this heavy in the > snow. > > Winter temps here aren't severe. Typical nights are in the 30's, but > we do see a couple of weeks of 10-20 degree nights and, every few > years, we get some 0 degree stuff. I've lived here over 25 years and > can only recall one time temps dipped much below 0. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] | |||
					08-16-2007, 02:16
				 Post: #8 | |||
| Winter approaches
					Ryan -- We have done some winter "camping" without too much difficulty. My adivce: 1. Buy a heating element for your waterhose. Available at Home Depot and other such stores fro $15-20. After installing, cover your hose with 1" pipe foam pipe insulation, also readily available and cheap, and then wrap the whole thing in duct tape. With this setup you can leave your water connection open all the time. 2. If you're sitting still for any length of time, skirting the Rv helps a LOT. You can spend money on custom skirting or use hay bales (really good insulation) or even heavy duty plastic held on by duct tape. Ugly but functional. Skirting also help to keep your floor a lot warmer as well as preventing plumbing freezing. 3. Keep your heaters on. We kept our electric heater on 24/7 and supplemented with propane. If you're sitting still, a supplemental propane bottle, available from local supplier, is a good idea, cause you'll use a lot of propane. 4. Don't drive when it's snowing and head south as soon as possible. Trudy & Lisa 1985 PT 40 - "The Catbird Seat" Currently in Rock Springs, WY and headed to Colorado after Labor Day -- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Hard to believe cold weather will be here soon. Just a few more weeks > and I'll be needing heat at night. > > I need advice on surviving my first winter and I want to get a jump on > any work I'll need to do to the coach, so I can do it while it's still > warm outside. I'll be living in my coach all winter with 50 amp > service available. I have many questions: > > 1. Where can I buy new electric heaters? At least a couple of mine do > not work properly. > 2. What might freeze or break, and how do I prevent it? > 3. Are my holding tanks heated, and how? > 4. The interior will be kept warm 24/7 so fresh water and plumbing > should be OK - or will it? > 5. There are thermostats with funky electric heaters under the beds > and some of the plumbing appears to be wrapped in that heat tape stuff > - any advice on dealing with this? > 6. How do I dump my holding tanks when it's freezing outside? Same as > usual? I'd planned on macerating into a sewer line but will the pump > be OK? > 7. How do I check my engine & battery heaters, & how do I get the 8V92 > and the Yanmar genset started in the dead of winter? > 8. Any other winter advice from the full timers? > 9. Winter driving advice? I won't be doing much and will try to avoid > snow, but may hit some visiting relatives in December. Will the PT-40 > generally walk over it, or will I be prone to sliding off the road > like I would in a pickup? I've never driven anything this heavy in the > snow. > > Winter temps here aren't severe. Typical nights are in the 30's, but > we do see a couple of weeks of 10-20 degree nights and, every few > years, we get some 0 degree stuff. I've lived here over 25 years and > can only recall one time temps dipped much below 0. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
