Trying to Pull Steering Wheel
08-25-2007, 04:12
Guys I am trying to get the steering wheel off the ole bus. I have the
correct tool and it will not budge. Placing a washer over the threaded
post I will damage the thread and have actually bent the bolts going
into the holds for this application. I can't believe its that tight?
Idea's suggestions etc. Don't see why there would be a problem. The
keeper nut screwed off easily enough and I can see the teeth of the
retaining gear, just will not move.
John Heckman
central Pa
1973 FC
08-25-2007, 06:21
--- In WanderlodgeForum@yahoogroups.com, "bubblerboy64"
threaded
tight?
> Sometimes it helps to tap the center bolt of your puller while it is
under pressure. Also rocking the steering wheel "over and under" might
help. To prevent damage to the threads, put the original nut back on
and screw it down about 4 turns then place another smaller nut or
thick wawasher on top of that nut and push against that with your
puller. I just pulled mine off a week ago and it surprised me as to
how much pressure it took for the hub to "pop" off. also grade 8 bolts
are a good idea....screw them as far as they will go into the wheel
hub.... jim sears 77FC
> John Heckman
> central Pa
> 1973 FC
08-25-2007, 13:03
Thanks Jim, I am going to soak the area with some penitrating oil
over night and see what gives tomorrow. Likely never off the bus in
35 years. Let ya know tomorrow. The idea with the grade 8 bolts is
good plus the nuts on threated shaft so thanks on those tips.
John Heckman
central Pa
1973 FC
have
> the
> threaded
going
> tight?
The
is
might
on
to
bolts
> > John Heckman
> > central Pa
> > 1973 FC
08-26-2007, 04:20
in
is
> John Heckman
> central Pa
> 1973 FC
> >Can i ask why you are pulling the steering wheel off? jim
> have
> > the
> > threaded
> going
> > tight?
problem.
> The
of
> the
it
> is
> might
back
> on
or
your
as
> to
> bolts
wheel
> > > John Heckman
> > > central Pa
> > > 1973 FC
08-26-2007, 05:05
Jim, You certainly can and I'll even tell ya :-) Two reasons. One
plain ole cosmetics and also the wheel is so large in diameter that a
guy of my stature has a problem. To get my feet to the brake and gas
my more then amble belly is rubbing on the wheel or very close to it.
I need to strink one or the other. Another thing I need to do if it
is in fact doable is the try to lighted up the pressure it takes to
keep the throttle applied. Seems like after a while driving the bus I
feel like I have to darned near stand on the gas to keep in going.
Haven't looked into this but hoping maybe a spring to the right place
might make the throttle a little lighter. I guess there is another
one for the group to help me with.
John Heckman
Shippensburg Pa
1973 FC
oil
> in
> is
> > John Heckman
> > central Pa
> > 1973 FC
> > have
> > > the
> > > threaded
bolts
> > going
that
> > > tight?
> problem.
> > The
> of
> > the
while
> it
> > is
under"
> > might
> back
> > on
> or
> your
> as
> > to
8
> > bolts
> wheel
> > > > John Heckman
> > > > central Pa
> > > > 1973 FC
08-26-2007, 09:07
In a message dated 8/26/2007 5:52:29 P.M. Mountain Standard Time,
gcyeaw@... writes:
The only concern I have is a power steering failure and the ability
to steer the coach to a safe stop
Ahhh- yes, I wonder what kind of muscle power would be needed to turn one of
those smaller wheels in event something like that happens?
83PT40
Livingston, Mt
--with that big wheel
08-26-2007, 12:47
John,
I sympathize with your loud pedal problem, I feel the same way. I
am often practically standing up to push the pedal as far as I can.
I think the reality is that it is only a mental deception that it
does any real good. I did get my cruise control working so my leg
gets a little break on the flats. As far as a slightly smaller
steering wheel, I agree that it would be nice. I seem to be bobbing
forward and backward to maneuver the coach into a campground space.
to steer the coach to a safe stop.
Gardner
78FC33
One
that a
gas
it.
it
to
bus I
going.
place
> John Heckman
> Shippensburg Pa
> 1973 FC
> oil
bus
> > in
bolts
> > is
> > > John Heckman
> > > central Pa
> > > 1973 FC
bus. I
> > > have
> > > > the
> > > > threaded
> bolts
> > > going
> that
> > > > tight?
> > problem.
> > > The
teeth
> > of
> > > the
> while
> > it
> > > is
> under"
> > > might
nut
> > back
> > > on
nut
> > or
> > your
me
> > as
> > > to
grade
> 8
> > > bolts
> > wheel
> > > > > John Heckman
> > > > > central Pa
> > > > > 1973 FC
08-27-2007, 08:03
Gardner,
I have a smaller wheel on my bus and it is very good, I also have the old big
wheel... Here is a link to a pix of the wheel in my bus;
http://www.pbase.com/rdupree1/image/62623511
HTH
Sea Ya
Larry
NYC
84 35FCSB
----- Original Message ----
Sent: Sunday, August 26, 2007 8:47:49 PM
Subject: [WanderlodgeForum] Re: Trying to Pull Steering Wheel
John,
Gardner
78FC33
--- In WanderlodgeForum@ yahoogroups. com, "bubblerboy64"
One
that a
gas
it.
it
to
bus I
going.
place
> John Heckman
> Shippensburg Pa
> 1973 FC
> oil
bus
> > in
bolts
> > is
> > > John Heckman
> > > central Pa
> > > 1973 FC
bus. I
> > > have
> > > > the
> > > > threaded
> bolts
> > > going
> that
> > > > tight?
> > problem.
> > > The
teeth
> > of
> > > the
> while
> > it
> > > is
> under"
> > > might
nut
> > back
> > > on
nut
> > or
> > your
me
> > as
> > > to
grade
> 8
> > > bolts
> > wheel
> > > > > John Heckman
> > > > > central Pa
> > > > > 1973 FC
____
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onesea...fer=1ONXIC
08-27-2007, 12:56
Larry,
Thanks for the picture, it looks real nice. Now, if only I could
get my interior to look that good.
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, Larry Dill
> Gardner,
the old big wheel... Here is a link to a pix of the wheel in my bus;
> HTH
> Sea Ya
> Larry
> NYC
> 84 35FCSB
> From: Gardner Yeaw
> John,
can.
bobbing
space.
ability
> Gardner
> 78FC33
> One
> that a
> gas
to
> it.
> it
> to
> bus I
> going.
> place
another
> > John Heckman
> > Shippensburg Pa
> > 1973 FC
penitrating
> > oil
> bus
> > > in
> bolts
> > > is
tips.
> > > > John Heckman
> > > > central Pa
> > > > 1973 FC
> bus. I
> > > > have
> > > > > the
over
> the
> > > > > threaded
> > bolts
> > > > going
> > that
> > > > > tight?
> > > problem.
> > > > The
> teeth
> > > of
> > > > the
> > while
> > > it
> > > > is
> > under"
> > > > might
> nut
> > > back
> > > > on
> nut
> > > or
with
> > > your
> me
> > > as
> > > > to
> grade
> > 8
> > > > bolts
> the
> > > wheel
> > > > > > John Heckman
> > > > > > central Pa
> > > > > > 1973 FC
_______________
08-30-2007, 04:59
UPS just delivered the wheel. It is beautiful, I forget the cost but
I think with shipping it was under $250. No seconds available (Gary
Miller suggested seconds) I think this will go a long way towards
dressing up the bus and I am very impressed with the quality and
service from VIP. I have four days to work on the bus and with a
little luck I will have a lot accomplished by Monday evening. I am
working on interior cosmetics.
John Heckman
Shippensburg Pa
1973 FC
> Gardner,
> HTH
> Sea Ya
> Larry
> NYC
> 84 35FCSB
> From: Gardner Yeaw
> John,
> Gardner
> 78FC33
> One
> that a
> gas
> it.
> it
> to
> bus I
> going.
> place
another
> > John Heckman
> > Shippensburg Pa
> > 1973 FC
> > oil
> bus
> > > in
> bolts
> > > is
> > > > John Heckman
> > > > central Pa
> > > > 1973 FC
> bus. I
> > > > have
> > > > > the
> the
> > > > > threaded
> > bolts
> > > > going
> > that
> > > > > tight?
> > > problem.
> > > > The
> teeth
> > > of
> > > > the
> > while
> > > it
> > > > is
> > under"
> > > > might
> nut
> > > back
> > > > on
> nut
> > > or
with
> > > your
> me
> > > as
> > > > to
> grade
> > 8
> > > > bolts
> the
> > > wheel
> > > > > > John Heckman
> > > > > > central Pa
> > > > > > 1973 FC
______________
